  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. voxl2 unbrick
voxl2 unbrick
8 Posts 4 Posters 1.9k Views 1 Watching
  • N Offline
    N Offline
    Nishkala
    How to unbrick voxl2?
    Arjun JainA 1 Reply Last reply
    • N Nishkala
      Arjun JainA Offline
      Arjun JainA Offline
      Arjun Jain
      @Nishkala please write a more meaningful question so that people on this forum can help you. What are the symptoms? Why do you think it is bricked? What all did you try?
      • N Offline
        N Offline
        Nishkala
        wrote on last edited by Nishkala
        @Chad-Sweet @modaltb
        1. I was installing MAVSDK on voxl2 by following the instructions on 'https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk-python/-/tree/master/' under the heading 'Pull Image from Registry'.
        2. On voxl2, when I ran the command 'voxl-configure-docker-support enable' for the first time, I got a message saying install docker using 'voxl-configure-docker-support install'. Docker installation was successful after running 'voxl-configure-docker-support install'.
        3. After running 'voxl-configure-docker-support enable' and following instructions on under 'Pull Image from Registry', I was able to install MAVSDK onto the board. I was able to run example scripts (python3 takeoff_and_land2.py udp://:14551) present in the repo. I was able to run it successfully
        4. When I ran 'voxl-inspect-services' after running 'voxl-configure-docker-support enable', 'docker-autorun' and 'docker-daemon' was running and enabled.
        5. I powered off the voxl2 after testing the example script (python3 takeoff_and_land2.py udp://:14551) in 'https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk-python/-/tree/master/'.
        Post this, when I powered on voxl2 and ran 'adb shell', I got an output 'no devices/emulators found'.
        I followed the issue, seen in this thread
        How to solve this issue? If the voxl2 has bricked, how to unbrick it?
        • modaltbM Offline
          modaltbM Offline
          modaltb
          @Nishkala ,
          On VOXL2, Docker should work natively without the need for voxl-configure-docker-support. We will need to see if this script is causing an issue, but please just use Docker natively without these helper scripts.
          If not booting, first we can try to boot into fastboot, there's a video showing how to force VOXL2 into fastboot: https://docs.modalai.com/voxl2-system-image/#force-voxl-2-into-fastboot
          Once in fast boot, you can flash the system image. On VOXL2, we use a "Platform Release" which flashes the system image and then loads the VOXL SDK. The latest is Voxl2 Platform 1.3.1-0.8 and this can be downloaded from: https://downloads.modalai.com/
          If that fails, there's a lower level flashing process we call QDL that can be used, and is captured here: https://docs.modalai.com/voxl2-qdl/
          Jose Alfredo Rosas CordovaJ 1 Reply Last reply
          • N Offline
            N Offline
            Nishkala
            @modaltb
            Thank you for the instructions, will give them a try!
            • N Nishkala
              @modaltb
              Jose Alfredo Rosas CordovaJ Offline
              wrote on last edited by Jose Alfredo Rosas Cordova
              @Nishkala did you manage to get MAVSDK working?
              • modaltbM modaltb
                @Nishkala ,
                Hello, @modaltb
                with the "native Docker support" do you mean the voxl-docker command?. I've been trying to pull the registry as shown in the guide by using it but it does not seem to support the pull argument.
                I am somewhat new with using Docker so I wanted to ask if I was missin something obvious perhaps?
                • modaltbM Offline
                  modaltbM Offline
                  modaltb
                  Hi @Jose-Alfredo-Rosas-Cordova ,
                  Sorry for the confusion, "native" meaning nothin special "extra" should be needed when compared to desktop Ubuntu, e.g. --> you should be able to follow this: https://docs.docker.com/engine/install/ubuntu/
                  For VOXL1, we needed to do some special sauce for Docker, but VOXL2 it should work like you're used to on desktop (from my experience).
