    IOT Sim-card integration
    Cellular Modems
    1177
    • A
      Arrowtec
      Hey there,
      we want to switch from using a normal sim-card to an IOT one which basically only means that certain IP-addresses are valid to connect to and receive a connection from.
      I think that this is a problem since the Modem won't boot/show up unless the connection is valid and the means of confirming a valid connection probably have something to do with my issue of the Modem not starting properly.
      Any Ideas?
      ~ # systemctl status -l voxl-modem
      ● voxl-modem.service - Modem Initialization
      Loaded: loaded (/etc/systemd/system/voxl-modem.service; enabled; vendor preset: enabled)
      Active: active (running) since Tue 2021-04-06 13:43:08 UTC; 31min ago
      Process: 4223 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
      Main PID: 4225 (voxl-modem-star)
      CGroup: /system.slice/voxl-modem.service
      ├─4225 /bin/bash /usr/bin/voxl-modem-start.sh
      ├─7565 /usr/bin/python /usr/bin/sierra.py
      └─7636 uqmi -P -d /dev/cdc-wdm0 --get-msisdn
      Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: "plmn_mnc": 2,
      Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: "plmn_description": "vodafone.de",
      Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: "roaming": true
      Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: }
      Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: ]
      Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: Successfully registered with the network
      Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: Starting network
      Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: Checking connection status
      Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: "disconnected"
      Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: Connection failed
        tom admin
        Hi @Arrowtec ,
        Just so I fully understand the situation:
        You have a modem that you were able to connect to the network successfully with previously and now you want to use a different SIM card with the same modem?
        If that is the case it is possible that the APN of the SIM has changed, especially if it is a different carrier. Have you ran through voxl-configure-modem again and entered the correct APN for this new SIM card?
        • A
          Arrowtec
          @tom Yes exactly it is a new Sim and I went through the voxl-configure-modem setup.
          The Problem that I think I am having is that in order to figure out if the connection works Voxl tries to ping a server and if it can't reach it it will say it is not connected. With the IOT-Sim it only allows to speak to certain predetermined IPs meaning it cant reach the IP to confirm the connection.
            tom admin
            Which modem are you using, the WP7610 or the WP7607 and where are you located? I want to make sure you're using the correct hardware.
            • A
              Arrowtec
              I am using the WP7607. The carrier is Vodafone and I am located in Germany.
              The APN I am using is: web.vodafone.de
              It worked with another Sim-Card so the compatibility shouldn't be the issue here
                tom admin
                Got it, from the output you posted earlier it looks like the APN it is trying to use is vodafone.de. Is that the previous APN? The APN might not be setting properly in the setup script.
                • A
                  Arrowtec
                  That should be the name of the Carrier and not the APN but I went through the voxl-configure-modem multiple times and it should be set right.
                  As already mentioned here:
                  I am thinking the Problem is with the restricted access to certain IPs and the checking of one not in those in the startup process. Do you know what happens during the startup of the modem and how it checks to see if its connected to the internet?
                    tom admin
                    @Arrowtec I don't believe that it pings a specific address that your SIM cannot access, we use this same modem with our private LTE networks.
                    Can you run the following to check what APN is set on the modem?
                    echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2
                    I understand that you have run voxl-configure-modem multiple times but I have seen on rare occasion where the APN doesn't set correctly.
                      tom admin
                      And could you please post the contents of /etc/modalai/voxl-modem.conf? I want to make sure I'm not missing anything obvious.
                      • A
                        Arrowtec
                        Will do when I get in the office, thanks
                          tom admin @Arrowtec
                          @Arrowtec Thanks 🙂
                          • A
                            Arrowtec
                            The APN seems to default to "internet" but after the voxl-configure-modem its set correctly as seen below. After that it is still not working / showing up.
                            Here is echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2:
                            ~ # echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2
                            AT+CGDCONT?
                            +CGDCONT: 1,"IP","web.vodafone.de","0.0.0.0",0,0,0,0
                            +CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
                            +CGDCONT: 3,"IPV4V6","sos","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,1
                            OK
                            Here is the content of /etc/modalai/voxl-modem.conf:
                            ~ # cat /etc/modalai/voxl-modem.conf
                            	"modem_type":	"v2",
                            	"apn":	"spe.inet4g.gdsp",
                            	"world":	"true",
                            	"microhard_ip": "192.168.168.100",
                            	"modallink":	"false",
                            	"placeholder": "hello world"
                            And here again the systemctl status -l voxl-modem:
                               Active: active (running) since Wed 2021-04-07 09:19:38 UTC; 11min ago
                              Process: 4400 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
                             Main PID: 4401 (voxl-modem-star)
                                       ├─4401 /bin/bash /usr/bin/voxl-modem-start.sh
                                       └─5666 /usr/bin/python /usr/bin/sierra.py
                            Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: "plmn_mnc": 2,
                            Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: "plmn_description": "vodafone.de",
                            Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: "roaming": true
                            Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: }
                            Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: ]
                            Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: Successfully registered with the network
                            Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: Starting network
                            Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: Checking connection status
                            Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: "disconnected"
                            Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: Connection failed
                            Furthermore here is ifconfig if that helps:
                            ~ # ifconfig
                            docker0   Link encap:Ethernet  HWaddr 02:42:DD:11:4A:98
                                      inet addr:172.17.0.1  Bcast:0.0.0.0  Mask:255.255.0.0
                                      inet6 addr: fe80::42:ddff:fe11:4a98/64 Scope:Link
                                      UP BROADCAST MULTICAST  MTU:1500  Metric:1
                                      TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
                                      collisions:0 txqueuelen:0
                                      RX bytes:152 (152.0 B)  TX bytes:216 (216.0 B)
                            lo        Link encap:Local Loopback
                                      inet addr:127.0.0.1  Mask:255.0.0.0
                                      UP LOOPBACK RUNNING  MTU:65536  Metric:1
                                      TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
                                      RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
                            wlan0     Link encap:Ethernet  HWaddr EC:5C:68:CD:21:5B
                                      inet addr:192.168.7.122  Bcast:192.168.7.255  Mask:255.255.255.0
                                      inet6 addr: fe80::ee5c:68ff:fecd:215b/64 Scope:Link
                                      inet6 addr: fd48:4c86:10be:e600:ee5c:68ff:fecd:215b/64 Scope:Global
                                      inet6 addr: 2a01:598:b00c:e53c:ee5c:68ff:fecd:215b/64 Scope:Global
                                      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
                                      RX packets:110 errors:0 dropped:0 overruns:0 frame:0
                                      TX packets:104 errors:0 dropped:0 overruns:0 carrier:0
                                      collisions:0 txqueuelen:3000
                                      RX bytes:11644 (11.3 KiB)  TX bytes:15615 (15.2 KiB)
                            Let me know if you can troubleshoot anything off the new information 🙂
                            • A
                              Arrowtec
                              The echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2 is btw from when I was using the old APN so dont get confused by that, here is the new one:
                              AT+CGDCONT?
                              +CGDCONT: 1,"IP","spe.inet4g.gdsp","0.0.0.0",0,0,0,0
                              OK
                                tom admin
                                @Arrowtec Okay this all looks normal, have you tested this SIM card in a different device to confirm that it is indeed functional?
