  2. VOXL Accessories
  3. Cellular Modems
  4. IOT Sim-card integration
Scheduled Pinned Locked Moved Cellular Modems
14 Posts 2 Posters 2.4k Views 2 Watching
  • A Offline
    Arrowtec
    Hey there,
    we want to switch from using a normal sim-card to an IOT one which basically only means that certain IP-addresses are valid to connect to and receive a connection from.
    I think that this is a problem since the Modem won't boot/show up unless the connection is valid and the means of confirming a valid connection probably have something to do with my issue of the Modem not starting properly.
    Any Ideas?
    ~ # systemctl status -l voxl-modem
    ● voxl-modem.service - Modem Initialization
    Loaded: loaded (/etc/systemd/system/voxl-modem.service; enabled; vendor preset: enabled)
    Active: active (running) since Tue 2021-04-06 13:43:08 UTC; 31min ago
    Process: 4223 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
    Main PID: 4225 (voxl-modem-star)
    CGroup: /system.slice/voxl-modem.service
    ├─4225 /bin/bash /usr/bin/voxl-modem-start.sh
    ├─7565 /usr/bin/python /usr/bin/sierra.py
    └─7636 uqmi -P -d /dev/cdc-wdm0 --get-msisdn
    Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: "plmn_mnc": 2,
    Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: "plmn_description": "vodafone.de",
    Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: "roaming": true
    Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: }
    Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: ]
    Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: Successfully registered with the network
    Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: Starting network
    Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: Checking connection status
    Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: "disconnected"
    Apr 06 14:14:29 apq8096 voxl-modem-start.sh[4225]: Connection failed
      Hi @Arrowtec ,
      Just so I fully understand the situation:
      You have a modem that you were able to connect to the network successfully with previously and now you want to use a different SIM card with the same modem?
      If that is the case it is possible that the APN of the SIM has changed, especially if it is a different carrier. Have you ran through voxl-configure-modem again and entered the correct APN for this new SIM card?
      • A Offline
        Arrowtec
        @tom Yes exactly it is a new Sim and I went through the voxl-configure-modem setup.
        The Problem that I think I am having is that in order to figure out if the connection works Voxl tries to ping a server and if it can't reach it it will say it is not connected. With the IOT-Sim it only allows to speak to certain predetermined IPs meaning it cant reach the IP to confirm the connection.
          Which modem are you using, the WP7610 or the WP7607 and where are you located? I want to make sure you're using the correct hardware.
          • A Offline
            Arrowtec
            I am using the WP7607. The carrier is Vodafone and I am located in Germany.
            The APN I am using is: web.vodafone.de
            It worked with another Sim-Card so the compatibility shouldn't be the issue here
              Got it, from the output you posted earlier it looks like the APN it is trying to use is vodafone.de. Is that the previous APN? The APN might not be setting properly in the setup script.
              • A Offline
                Arrowtec
                wrote on last edited by Arrowtec
                That should be the name of the Carrier and not the APN but I went through the voxl-configure-modem multiple times and it should be set right.
                As already mentioned here:
                I am thinking the Problem is with the restricted access to certain IPs and the checking of one not in those in the startup process. Do you know what happens during the startup of the modem and how it checks to see if its connected to the internet?
                  @Arrowtec I don't believe that it pings a specific address that your SIM cannot access, we use this same modem with our private LTE networks.
                  Can you run the following to check what APN is set on the modem?
                  echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2
                  I understand that you have run voxl-configure-modem multiple times but I have seen on rare occasion where the APN doesn't set correctly.
                    And could you please post the contents of /etc/modalai/voxl-modem.conf? I want to make sure I'm not missing anything obvious.
                    • A Offline
                      Arrowtec
                      Will do when I get in the office, thanks
                      • A Arrowtec
                        @Arrowtec Thanks 🙂
                        • A Offline
                          Arrowtec
                          #12
                          The APN seems to default to "internet" but after the voxl-configure-modem its set correctly as seen below. After that it is still not working / showing up.
                          Here is echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2:
                          ~ # echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2
                          AT+CGDCONT?
                          +CGDCONT: 1,"IP","web.vodafone.de","0.0.0.0",0,0,0,0
                          +CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
                          +CGDCONT: 3,"IPV4V6","sos","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,1
                          OK
                          Here is the content of /etc/modalai/voxl-modem.conf:
                          ~ # cat /etc/modalai/voxl-modem.conf
                          	"modem_type":	"v2",
                          	"apn":	"spe.inet4g.gdsp",
                          	"world":	"true",
                          	"microhard_ip": "192.168.168.100",
                          	"modallink":	"false",
                          	"placeholder": "hello world"
                          And here again the systemctl status -l voxl-modem:
                             Active: active (running) since Wed 2021-04-07 09:19:38 UTC; 11min ago
                            Process: 4400 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
                           Main PID: 4401 (voxl-modem-star)
                                     ├─4401 /bin/bash /usr/bin/voxl-modem-start.sh
                                     └─5666 /usr/bin/python /usr/bin/sierra.py
                          Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: "plmn_mnc": 2,
                          Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: "plmn_description": "vodafone.de",
                          Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: "roaming": true
                          Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: }
                          Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: ]
                          Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: Successfully registered with the network
                          Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: Starting network
                          Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: Checking connection status
                          Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: "disconnected"
                          Apr 07 09:30:38 apq8096 voxl-modem-start.sh[4401]: Connection failed
                          Furthermore here is ifconfig if that helps:
                          ~ # ifconfig
                          docker0   Link encap:Ethernet  HWaddr 02:42:DD:11:4A:98
                                    inet addr:172.17.0.1  Bcast:0.0.0.0  Mask:255.255.0.0
                                    inet6 addr: fe80::42:ddff:fe11:4a98/64 Scope:Link
                                    UP BROADCAST MULTICAST  MTU:1500  Metric:1
                                    TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
                                    collisions:0 txqueuelen:0
                                    RX bytes:152 (152.0 B)  TX bytes:216 (216.0 B)
                          lo        Link encap:Local Loopback
                                    inet addr:127.0.0.1  Mask:255.0.0.0
                                    UP LOOPBACK RUNNING  MTU:65536  Metric:1
                                    TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
                                    RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
                          wlan0     Link encap:Ethernet  HWaddr EC:5C:68:CD:21:5B
                                    inet addr:192.168.7.122  Bcast:192.168.7.255  Mask:255.255.255.0
                                    inet6 addr: fe80::ee5c:68ff:fecd:215b/64 Scope:Link
                                    inet6 addr: fd48:4c86:10be:e600:ee5c:68ff:fecd:215b/64 Scope:Global
                                    inet6 addr: 2a01:598:b00c:e53c:ee5c:68ff:fecd:215b/64 Scope:Global
                                    UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
                                    RX packets:110 errors:0 dropped:0 overruns:0 frame:0
                                    TX packets:104 errors:0 dropped:0 overruns:0 carrier:0
                                    collisions:0 txqueuelen:3000
                                    RX bytes:11644 (11.3 KiB)  TX bytes:15615 (15.2 KiB)
                          Let me know if you can troubleshoot anything off the new information 🙂
                          • A Offline
                            Arrowtec
                            The echo -ne "AT+CGDCONT?\r" | busybox microcom -t 1000 /dev/ttyUSB2 is btw from when I was using the old APN so dont get confused by that, here is the new one:
                            AT+CGDCONT?
                            +CGDCONT: 1,"IP","spe.inet4g.gdsp","0.0.0.0",0,0,0,0
                            OK
                              @Arrowtec Okay this all looks normal, have you tested this SIM card in a different device to confirm that it is indeed functional?
