  3. Is it possible to use uORB directly in a voxl module?
voxl-2
9 Posts 4 Posters 2.3k Views 3 Watching
  • D Offline
    D Offline
    Dan
    Hi ModalAI devs,
    I'm wondering if it's possible to subscribe to a uORB topic in a voxl module. I want to subscribe to the barometer sensor and there isn't an MPA server for this.
    The reason I ask is that when using the voxl-cross docker container I'm unsure which dependency is required to install to get access to the uORB headers etc.
    Dan
    • ? Offline
      Hi Dan,
      You can directly subscribe to the mavlink output using the mavlink_to_px4 pipe and check for messages of type MAVLINK_MSG_ID_ALTITUDE to receive barometer updates in an MPA server.
      See here for a code example.
      D 1 Reply Last reply
      • ? A Former User
        Hi Dan,
        D Offline
        D Offline
        Dan
        @Matt-Turi
        Hi Matt,
        Thanks for the quick reply and thanks for the example that's super useful.
        Just to clarify what you're saying. From my understanding when I do uorb top the topic name sensor_baro is available and I can call px4-listener sensor_baro to get an update from what I believe to be a uorb message? Are you saying that there are mavlink messages also published that will give me the same information and I can use something similar to your example to then create a barometer MPA server?
        • D Dan
          Hi ModalAI devs,
          Dan
          @Dan There is no uorb to pipe bridge so not really possible. But you can run the system command px4-listener and parse the output of it. Or if what you really need is something in a Mavlink message then you can go the route Matt suggested.
          • ? Offline
            There is a mavlink message you can parse for barometer data, that is the code example I sent above. In that file as well, there is an example of calling px4-listener programmatically and parsing its output - see here
              D Offline
              D Offline
              Dan
              No problem. I was wondering if I could do that bridging myself by subscribing to the uORB topic sensor_baro and then publishing onto a barometer MPA server but wasn't sure if it was possibly to subscribe to uORB topics in the voxl SDK.
              @Matt-Turi
              Thanks for the clarification. I'll take a look at the px4-listener parsing too.
              • ? A Former User
                D Offline
                D Offline
                Dan
                @Matt-Turi
                Apologies. Final question for now. Who is the producer of the mavlink message for the barometer data?
                  The PX4 flight control software
                  • Chad SweetC Chad Sweet
                    D Offline
                    D Offline
                    Dan
                    @Chad-Sweet
                    Thanks Chad.👍
