    voxl-mpa-to-ros high system usage due to repeating invoking voxl-list-pipes
    • Dong LiuD
      Dong Liu
      When we start t voxl-mpa-to-ros, the system usage becomes very high, the CPU is overheat very quickly. I found out it is because it constantly executing shell script voxl-list-pipes. Although it is doing it at 1 second interval, but that script is quite complicated, it invokes a lot other shell commands, such as cat, grep, tr, sort ... I disabled this repeating invoking voxl-list-pipes, the system usage went down. The CPU was not overhead.
      The purpose for repeating invoking voxl-list-pipes is for handle pipe added after voxl-mpa-to-ros started. But in most case we start voxl-map-to-ros after the services are started. I think at least it should make this function configurable.
      • Chad SweetC
        Chad Sweet ModalAI Team
        This is great feedback, thank you! We keep our code open for just this purpose. We are happy to review a Pull Request if you have one?
        Dong LiuD 1 Reply Last reply Reply Quote 0
        • Dong LiuD
          Dong Liu
          I'll create one
          • Dong LiuD
            Dong Liu @Chad Sweet
            @Chad-Sweet I also added skip n frame feature in the camera interfaces, It is quite useful to reduce the network traffic. Do you think should submit one full request with bother features or two pull requests?
