  3. voxl-streamer does not handle "teardown-request" signal correctly
rb5
7 Posts 4 Posters 1.7k Views 1 Watching
  • S Offline
    S Offline
    stevedan
    See https://forum.modalai.com/topic/1615/issue-with-voxl-streamer-not-reconnecting?_=1672332432641 for more context. It seems that the problem is that when a client initially disconnects, it returns a "teardown-request" not a "closed" signal, rtsp-client signal specifically, which never closes the client correctly. What happens then is that when the client tries to reconnect, it does not and disconnects automatically. Is there a better way of handling this, is there a way of closing the pipeline when a "teardown-request" is received. I have tried running the
    gst_rtsp_client_close
    and the
    static gboolean
    remove_sessions (GstRTSPServer * server)
      GstRTSPSessionPool *pool;
      pool = gst_rtsp_server_get_session_pool (server);
      guint removed = gst_rtsp_session_pool_cleanup (pool);
      g_object_unref (pool);
      M_PRINT("Removed %d sessions\n", removed);
      return TRUE;
    but it seems not to work and just gives me the following error of pthread, is there something I am not taking into consideration?
    Section of code that was modified from the original main.c file can be below:
    static gboolean
      return TRUE;
    static void rtsp_client_tear_down_request(GstRTSPClient* self, context_data *data) {
        M_PRINT("An existing client has requested tear down from the RTSP server\n");
        // remove_sessions(data->rtsp_server);
        gst_rtsp_client_close(self);
        pthread_mutex_lock(&data->lock);
        data->num_rtsp_clients--;
        if ( ! data->num_rtsp_clients) {
            data->input_frame_number = 0;
            data->output_frame_number = 0;
            data->need_data = 0;
            data->initial_timestamp = 0;
            data->last_timestamp = 0;
        pthread_mutex_unlock(&data->lock);
    // This is called by the RTSP server when a client has connected.
    static void rtsp_client_connected(GstRTSPServer* self, GstRTSPClient* object,
        M_PRINT("A new client has connected to the RTSP server\n");
        data->num_rtsp_clients++;
        // Install the disconnect callback with the client.
        g_signal_connect(object, "closed", G_CALLBACK(rtsp_client_disconnected), data);
        // Install tear down callback with the client
        g_signal_connect(object, "teardown-request", G_CALLBACK(rtsp_client_tear_down_request), data);
    • S Offline
      S Offline
      stevedan
      It seems that the problem is the first ip port never gets closed which causes a conflict.
      ec 30 14:50:04 robot133 voxl-streamer[5967]: Stream available at rtsp://127.0.0.1:8900/live
      Dec 30 14:50:04 robot133 voxl-streamer[5967]: A new client has connected to the RTSP server
      Dec 30 14:50:04 robot133 voxl-streamer[5967]: [1]A new client rtsp://92.185.19.128:56804(null) has connected
      Dec 30 14:50:04 robot133 voxl-streamer[5967]: gbm_create_device(156): Info: backend name is: msm_drm
      Dec 30 14:50:44 robot133 voxl-streamer[5967]: A new client has connected to the RTSP server
      Dec 30 14:50:44 robot133 voxl-streamer[5967]: [2]A new client rtsp://92.185.19.128:38300(null) has connected
      Dec 30 14:51:46 robot133 voxl-streamer[5967]: A new client has connected to the RTSP server
      • ? Offline
        For clarification, if you lose your stream via losing wifi connection or similar, the stream does not return when wifi returns?
        This is RB5 drone and what does voxl-version say for full software listing?
        • S Offline
          S Offline
          stevedan
          wrote on last edited by stevedan
          @RichieRich said in voxl-streamer does not handle "teardown-request" signal correctly:
          listing
          we were able to find a workaround.
          The voxl version is the following.
          system-image: 1.4.1-M0052-14.1a-perf
          kernel:       #1 SMP PREEMPT Thu Oct 13 18:59:44 UTC 2022 4.19.125
          hw version:   M0052
          voxl-suite:   0.9.4
          Packages:
          Last Updated: 2022-12-27 18:53:03
          List:
          	libmodal-cv              0.2.3
          	libmodal-exposure        0.0.7
          	libmodal-journal         0.2.1
          	libmodal-json            0.4.3
          	libmodal-pipe            2.6.0
          	libqrb5165-io            0.1.0
          	libvoxl-cci-direct       0.1.5
          	libvoxl-cutils           0.1.1
          	mv-voxl                  0.1-r0
          	qrb5165-bind             0.1-r0
          	qrb5165-dfs-server       0.1.0
          	qrb5165-imu-server       0.5.0
          	qrb5165-slpi-test-sig    01-r0
          	qrb5165-system-tweaks    0.1.5
          	qrb5165-tflite           2.8.0-2
          	voxl-bind                0.0.1
          	voxl-camera-calibration  0.2.3
          	voxl-camera-server       1.3.5
          	voxl-cpu-monitor         0.3.0
          	voxl-docker-support      1.2.4
          	voxl-gphoto2-server      0.0.10
          	voxl-jpeg-turbo          2.1.3-4
          	voxl-libgphoto2          0.0.4
          	voxl-libuvc              1.0.7
          	voxl-logger              0.3.4
          	voxl-mavlink             0.1.0
          	voxl-mavlink-server      0.2.0
          	voxl-modem               0.16.1
          	voxl-mongoose            7.7.0-1
          	voxl-mpa-to-ros          0.3.6
          	voxl-mpa-tools           0.7.6
          	voxl-opencv              4.5.5-1
          	voxl-portal              0.4.2
          	voxl-px4                 1.12.31
          	voxl-px4-imu-server      0.1.2
          	voxl-qvio-server         0.8.2
          	voxl-remote-id           0.0.5
          	voxl-streamer            0.4.1
          	voxl-suite               0.9.4
          	voxl-tag-detector        0.0.4
          	voxl-tflite-server       0.3.1
          	voxl-utils               1.2.2
          	voxl-uvc-server          0.1.3
          	voxl-vision-px4          1.4.0
          We were able to solve the problem. @RichieRich . I will make a branch in voxl-streamer branch with the solution.
          Since I cant push the changes to the voxl-streamer gitlab repo, I will add the files changed.
          cmake_minimum_required(VERSION 3.3)
          project(voxl-streamer)
          add_definitions(-D_GNU_SOURCE)
          set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -O0 -g -std=c11 -Wall -pedantic")
          set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -D_XOPEN_SOURCE=500 -fno-strict-aliasing")
          set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -fdata-sections -fno-zero-initialized-in-bss")
          set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -Wall -Wextra -Wno-unused-parameter")
          set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -Wno-unused-function")
          set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -Wno-cast-align")
          set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -Wno-missing-braces -Wno-strict-aliasing")
          set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -D__FILENAME__='\"$(subst ${CMAKE_SOURCE_DIR}/,,$(abspath $<))\"'")
          include_directories( SYSTEM /usr/include/gstreamer-1.0 )
          include_directories( SYSTEM /usr/include/glib-2.0 )
          include_directories( include/ )
          if(${BUILDSIZE} MATCHES 64)
              message("BUILDSIZE matches 64")
              include_directories( SYSTEM /usr/lib/aarch64-linux-gnu/glib-2.0/include )
              find_library(MODAL_JSON    modal_json    HINTS /usr/lib64)
              find_library(MODAL_PIPE    modal_pipe    HINTS /usr/lib64)
              find_library(MODAL_JOURNAL modal_journal HINTS /usr/lib64)
          else()
              message("BUILDSIZE does not match 64")
              include_directories( SYSTEM /usr/lib/glib-2.0/include )
              find_library(MODAL_JSON    modal_json    HINTS /usr/lib)
              find_library(MODAL_PIPE    modal_pipe    HINTS /usr/lib)
              find_library(MODAL_JOURNAL modal_journal HINTS /usr/lib)
          endif()
          add_executable( voxl-streamer
              src/util.c
              src/pipeline.c
              src/configuration.c
              src/main.c
          target_link_libraries(voxl-streamer
              pthread
              gstreamer-1.0
              gstvideo-1.0
              gstrtspserver-1.0
              gobject-2.0
              gstapp-1.0
              glib-2.0
              gstrtsp-1.0
              ${MODAL_JSON}
              ${MODAL_PIPE}
              ${MODAL_JOURNAL}
          add_executable( voxl-configure-streamer
              config/voxl-configure-streamer.c
          target_link_libraries(voxl-configure-streamer
              ${MODAL_JSON}
          install(
              TARGETS voxl-streamer voxl-configure-streamer
              DESTINATION /usr/bin
          main.c
           * Copyright 2020 ModalAI Inc.
           * Redistribution and use in source and binary forms, with or without
           * modification, are permitted provided that the following conditions are met:
           * 1. Redistributions of source code must retain the above copyright notice,
           *    this list of conditions and the following disclaimer.
           * 2. Redistributions in binary form must reproduce the above copyright notice,
           *    this list of conditions and the following disclaimer in the documentation
           *    and/or other materials provided with the distribution.
           * 3. Neither the name of the copyright holder nor the names of its contributors
           *    may be used to endorse or promote products derived from this software
           *    without specific prior written permission.
           * 4. The Software is used solely in conjunction with devices provided by
           *    ModalAI Inc.
           * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
           * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
           * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
           * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
           * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
           * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
           * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
           * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
           * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
           * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
           * POSSIBILITY OF SUCH DAMAGE.
          #include <stdio.h>
          #include <stdint.h>
          #include <getopt.h>
          #include <string.h>
          #include <inttypes.h>
          #include <sys/types.h>
          #include <sys/stat.h>
          #include <fcntl.h>
          #include <unistd.h>
          #include <gst/gst.h>
          #include <gst/video/video.h>
          #include <gst/app/gstappsrc.h>
          #include <glib-object.h>
          #include <modal_pipe.h>
          #include <modal_journal.h>
          #include "context.h"
          #include "pipeline.h"
          #include "configuration.h"
          #include "gst/rtsp/gstrtspconnection.h"
          // This is the main data structure for the application. It is passed / shared
          // with other modules as needed.
          static context_data context;
          // called whenever we connect or reconnect to the server
          static void _cam_connect_cb(__attribute__((unused)) int ch, __attribute__((unused)) void* context)
              M_PRINT("Camera server Connected\n");
          // called whenever we disconnect from the server
          static void _cam_disconnect_cb(__attribute__((unused)) int ch, __attribute__((unused)) void* context)
              M_PRINT("Camera server Disconnected\n");
          // camera helper callback whenever a frame arrives
          static void _cam_helper_cb(
              __attribute__((unused))int ch,
                                     camera_image_metadata_t meta,
                                     char* frame,
                                     void* context)
              static int dump_meta_data = 1;
              context_data *ctx = (context_data*) context;
              GstMapInfo info;
              GstFlowReturn status;
              if (dump_meta_data) {
                  M_DEBUG("Meta data from incoming frame:\n");
                  M_DEBUG("\tmagic_number 0x%X \n", meta.magic_number);
                  M_DEBUG("\ttimestamp_ns: %" PRIu64 "\n", meta.timestamp_ns);
                  M_DEBUG("\tframe_id: %d\n", meta.frame_id);
                  M_DEBUG("\twidth: %d\n", meta.width);
                  M_DEBUG("\theight: %d\n", meta.height);
                  M_DEBUG("\tsize_bytes: %d\n", meta.size_bytes);
                  M_DEBUG("\tstride: %d\n", meta.stride);
                  M_DEBUG("\texposure_ns: %d\n", meta.exposure_ns);
                  M_DEBUG("\tgain: %d\n", meta.gain);
                  M_DEBUG("\tformat: %d\n", meta.format);
                  dump_meta_data = 0;
              // Initialize the input parameters based on the incoming meta data
              if ( ! ctx->input_parameters_initialized) {
                  // We need to estimate our frame rate. So get a timestamp from the
                  // very first frame and then on the second frame figure out the delta time
                  // between the two frames. Estimate frame rate based on that delta.
                  if (ctx->last_timestamp == 0) {
                      ctx->last_timestamp = (guint64) meta.timestamp_ns;
                      M_DEBUG("First frame timestamp: %" PRIu64 "\n", ctx->last_timestamp);
                      return;
                  } else {
                      M_DEBUG("Second frame timestamp: %" PRIu64 "\n", (guint64) meta.timestamp_ns);
                      guint64  delta_frame_time_ns = (guint64) meta.timestamp_ns - ctx->last_timestamp;
                      M_DEBUG("Calculated frame delta in ns: %" PRIu64 "\n", delta_frame_time_ns);
                      uint32_t delta_frame_time_100us = delta_frame_time_ns / 100000;
                      M_DEBUG("Calculated frame delta in 100us: %u\n", delta_frame_time_100us);
                      ctx->input_frame_rate = (uint32_t) ((10000.0 / (double) delta_frame_time_100us) + 0.5);
                      M_DEBUG("Calculated input frame rate is: %u\n", ctx->input_frame_rate);
                      ctx->input_frame_rate /= ctx->output_frame_decimator;
                      ctx->output_frame_rate = ctx->input_frame_rate;
                      M_DEBUG("Output frame rate will be: %u\n", ctx->input_frame_rate);
                  if(ctx->output_stream_rotation == 90 || ctx->output_stream_rotation == 270){
                      ctx->output_stream_height = meta.width;
                      ctx->output_stream_width = meta.height;
                  } else {
                      ctx->output_stream_height = meta.height;
                      ctx->output_stream_width = meta.width;
                  switch (meta.format) {
                  case IMAGE_FORMAT_RAW8:
                  case IMAGE_FORMAT_STEREO_RAW8:
                      strncpy(ctx->input_frame_format, "gray8",
                              MAX_IMAGE_FORMAT_STRING_LENGTH);
                      break;
                  //For stereo color images we only send the first one, treat it as if only one came through
                  case IMAGE_FORMAT_STEREO_NV12:
                      meta.size_bytes /= 2;
                  case IMAGE_FORMAT_NV12:
                      strncpy(ctx->input_frame_format, "nv12",
                      break;
                  case IMAGE_FORMAT_STEREO_NV21:
                  case IMAGE_FORMAT_NV21:
                      strncpy(ctx->input_frame_format, "nv21",
                      break;
                  case IMAGE_FORMAT_YUV422:
                      strncpy(ctx->input_frame_format, "yuyv",
                      break;
                  case IMAGE_FORMAT_YUV422_UYVY:
                      strncpy(ctx->input_frame_format, "uyvy",
                      break;
                  case IMAGE_FORMAT_YUV420:
                      strncpy(ctx->input_frame_format, "yuv420",
                      break;
                  case IMAGE_FORMAT_RGB:
                      strncpy(ctx->input_frame_format, "rgb",
                      break;
                  case IMAGE_FORMAT_RAW16:
                      strncpy(ctx->input_frame_format, "gray16",
                      break;
                  default:
                      M_ERROR("Unsupported frame format %d\n", meta.format);
                      main_running = 0;
                      break;
                  if ( ! main_running) return;
                  ctx->input_frame_width = meta.width;
                  if (meta.format == IMAGE_FORMAT_STEREO_RAW8) {
                      // The 2 stereo images are stacked on top of each other
                      // so have to double the height to account for both of them
                      M_DEBUG("Got stereo raw8 as input format\n");
                      ctx->input_frame_height = meta.height * 2;
                  } else {
                      ctx->input_frame_height = meta.height;
                  configure_frame_format(ctx->input_frame_format, ctx);
                  if (ctx->input_frame_size != (uint32_t) meta.size_bytes) {
                      M_ERROR("Frame size mismatch %d %d\n",
                              meta.size_bytes,
                              ctx->input_frame_size);
                      main_running = 0;
                      return;
                  ctx->input_parameters_initialized = 1;
              // Allocate a gstreamer buffer to hold the frame data
              GstBuffer *gst_buffer = gst_buffer_new_and_alloc(ctx->input_frame_size);
              gst_buffer_map(gst_buffer, &info, GST_MAP_WRITE);
              if (info.size < ctx->input_frame_size) {
                  M_ERROR("Not enough memory for the frame buffer\n");
                  main_running = 0;
                  return;
              memcpy(info.data, frame, ctx->input_frame_size);
              // The need_data flag is set by the pipeline callback asking for
              // more data.
              if (ctx->need_data) {
                  // If the input frame rate is higher than the output frame rate then
                  // we ignore some of the frames.
                  if ( ! (ctx->input_frame_number % ctx->output_frame_decimator)) {
                      pthread_mutex_lock(&ctx->lock);
                      // To get minimal latency make sure to set this to the timestamp of
                      // the very first frame that we will be sending through the pipeline.
                      if (ctx->initial_timestamp == 0) ctx->initial_timestamp = (guint64) meta.timestamp_ns;
                      // Do the timestamp calculations.
                      // It is very important to set these up accurately.
                      // Otherwise, the stream can look bad or just not work at all.
                      // TODO: Experiment with taking some time off of pts???
                      GST_BUFFER_TIMESTAMP(gst_buffer) = ((guint64) meta.timestamp_ns - ctx->initial_timestamp);
                      GST_BUFFER_DURATION(gst_buffer) = ((guint64) meta.timestamp_ns) - ctx->last_timestamp;
                      pthread_mutex_unlock(&ctx->lock);
                      M_VERBOSE("Output frame %d %" PRIu64 " %" PRIu64 "\n",
                          ctx->output_frame_number,
                          GST_BUFFER_TIMESTAMP(gst_buffer),
                          GST_BUFFER_DURATION(gst_buffer));
                      ctx->output_frame_number++;
                      // Signal that the frame is ready for use
                      g_signal_emit_by_name(ctx->app_source, "push-buffer", gst_buffer, &status);
                      if (status == GST_FLOW_OK) {
                          M_VERBOSE("Frame %d accepted\n", ctx->output_frame_number);
                      } else {
                          M_ERROR("New frame rejected\n");
                  ctx->input_frame_number++;
              } else {
                  M_VERBOSE("*** Skipping buffer ***\n");
              // Release the buffer so that we don't have a memory leak
              gst_buffer_unmap(gst_buffer, &info);
              gst_buffer_unref(gst_buffer);
          // This callback lets us know when an RTSP client has disconnected so that
          // we can stop trying to feed video frames to the pipeline and reset everything
          // for the next connection.
          static void rtsp_client_disconnected(GstRTSPClient* self, context_data *data) {
              M_PRINT("An existing client has disconnected from the RTSP server\n");
          // Gts client information
          static void print_client_info(GstRTSPClient* object)
              GstRTSPConnection *connection = gst_rtsp_client_get_connection(object);
              if (connection == NULL)
                  M_PRINT("Could not get RTSP connection\n");
                  // DEBUG_EXIT;
                  return;
              GstRTSPUrl *url = gst_rtsp_connection_get_url(connection);
              if (url == NULL)
                  M_PRINT("Could not get RTSP connection URL\n");
                  // DEBUG_EXIT;
                  return;
              gchar* uri = gst_rtsp_url_get_request_uri(url);
              M_PRINT("A new client %s has connected\n",uri);
              g_free(uri);
              print_client_info(object);
          /* this timeout is periodically run to clean up the expired sessions from the
           * pool. This needs to be run explicitly currently but might be done
           * automatically as part of the mainloop. */
          static gboolean
          timeout (gpointer data)
            context_data *context_data_local = (context_data *)data;
            pool = gst_rtsp_server_get_session_pool (context_data_local->rtsp_server);
          //   M_PRINT("Removed sessions: %d\n", removed);
            if (removed > 0)
              pthread_mutex_lock(&context_data_local->lock);
              context_data_local->num_rtsp_clients--;
              if ( ! context_data_local->num_rtsp_clients) {
                  context_data_local->input_frame_number = 0;
                  context_data_local->output_frame_number = 0;
                  context_data_local->need_data = 0;
                  context_data_local->initial_timestamp = 0;
                  context_data_local->last_timestamp = 0;
              pthread_mutex_unlock(&context_data_local->lock);
            return TRUE;
          // This callback is setup to happen at 1 second intervals so that we can
          // monitor when the program is ending and exit the main loop.
          gboolean loop_callback(gpointer data) {
              if ( ! main_running) {
                  M_PRINT("Trying to stop loop\n");
                  g_main_loop_quit((GMainLoop*) data);
              return TRUE;
          // This will cause all remaining RTSP clients to be removed
          GstRTSPFilterResult stop_rtsp_clients(GstRTSPServer* server,
                                                GstRTSPClient* client,
                                                gpointer user_data) {
              return  GST_RTSP_FILTER_REMOVE;
          static void PrintHelpMessage()
              M_PRINT("\nCommand line arguments are as follows:\n\n");
              M_PRINT("-b --bitrate    <#>     | Use specified bitrate instead of one in config file\n");
              M_PRINT("-d --decimator  <#>     | Use specified decimator instead of one in config file\n");
              M_PRINT("-h --help               | Print this help message\n");
              M_PRINT("-i --input-pipe <name>  | Use specified input pipe instead of one in config file\n");
              M_PRINT("-p --port       <#>     | Use specified port number for the RTSP URI instead of config file\n");
              M_PRINT("-r --rotation   <#>     | Use specified rotation instead of one in config file\n");
              M_PRINT("-s --software-encode    | Use software h264 encoder instead of OMX hardware encoder.\n");
              M_PRINT("-v --verbosity  <#>     | Log verbosity level (Default 2)\n");
              M_PRINT("                      0 | Print verbose logs\n");
              M_PRINT("                      1 | Print >= info logs\n");
              M_PRINT("                      2 | Print >= warning logs\n");
              M_PRINT("                      3 | Print only fatal logs\n");
          static int ParseArgs(int         argc,                 ///< Number of arguments
                               char* const argv[])               ///< Argument list
              static struct option LongOptions[] =
                  {"bitrate",          required_argument,  0, 'b'},
                  {"decimator",        required_argument,  0, 'd'},
                  {"help",             no_argument,        0, 'h'},
                  {"input-pipe",       required_argument,  0, 'i'},
                  {"port",             required_argument,  0, 'p'},
                  {"rotation",         required_argument,  0, 'r'},
                  {"software-encode",  no_argument,        0, 's'},
                  {"verbosity",        required_argument,  0, 'v'},
              int optionIndex = 0;
              int option;
              while ((option = getopt_long (argc, argv, ":b:d:hi:p:r:sv:", &LongOptions[0], &optionIndex)) != -1)
                  switch (option) {
                      case 'v':{
                          int verbosity;
                          if (sscanf(optarg, "%d", &verbosity) != 1)
                              M_ERROR("Failed to parse debug level specified after -d flag\n");
                              return -1;
                          if (verbosity >= PRINT || verbosity < VERBOSE)
                              M_ERROR("Invalid debug level specified: %d\n", verbosity);
                              return -1;
                          M_JournalSetLevel((M_JournalLevel) verbosity);
                          break;
                      case 'b':
                          if(sscanf(optarg, "%u", &context.output_stream_bitrate) != 1){
                              M_ERROR("Failed to get valid integer for bitrate from: %s\n", optarg);
                              return -1;
                          break;
                      case 'd':
                          if(sscanf(optarg, "%u", &context.output_frame_decimator) != 1){
                              M_ERROR("Failed to get valid integer for decimator from: %s\n", optarg);
                              return -1;
                          break;
                      case 'r':
                          if(sscanf(optarg, "%u", &context.output_stream_rotation) != 1){
                              M_ERROR("Failed to get valid integer for rotation from: %s\n", optarg);
                              return -1;
                          if( context.output_stream_rotation != 0   &&
                              context.output_stream_rotation != 90  &&
                              context.output_stream_rotation != 180 &&
                              context.output_stream_rotation != 270 ) {
                              M_ERROR("Invalid rotation: %u, must be 0, 90, 180, or 270\n", context.output_stream_rotation);
                              return -1;
                          break;
                      case 'i':
                          strncpy(context.input_pipe_name, optarg, MODAL_PIPE_MAX_PATH_LEN);
                          break;
                      case 'p':
                          strncpy(context.rtsp_server_port, optarg, MAX_RTSP_PORT_SIZE);
                          break;
                      case 's':
                          M_PRINT("Enabling software h264 encoder instead of OMX\n");
                          context.use_sw_h264 = 1;
                          break;
                      case 'h':
                          PrintHelpMessage();
                          return -1;
                      case ':':
                          M_ERROR("Option %c needs a value\n\n", optopt);
                          PrintHelpMessage();
                          return -1;
                      case '?':
                          M_ERROR("Unknown option: %c\n\n", optopt);
                          PrintHelpMessage();
                          return -1;
              // optind is for the extra arguments which are not parsed
              if(optind < argc){
                  M_WARN("extra arguments:\n");
                  for (; optind < argc; optind++) {
                      M_WARN("\t%s\n", argv[optind]);
              return 0;
          //  Main
          int main(int argc, char *argv[]) {
              GstRTSPMountPoints *mounts;
              GstRTSPMediaFactory *factory;
              GMainContext* loop_context;
              GMainLoop *loop;
              GSource *loop_source;
              GSource *time_loop_source;
              strncpy(context.rtsp_server_port, DEFAULT_RTSP_PORT, MAX_RTSP_PORT_SIZE);
              // Have the configuration module fill in the context data structure
              // with all of the required parameters to support the given configuration
              // in the given configuration file.
              if (prepare_configuration(&context)) {
                  M_ERROR("Could not parse the configuration data\n");
                  return -1;
              if(ParseArgs(argc, argv)){
                  M_ERROR("Failed to parse args\n");
                  return -1;
              // start signal handler so we can exit cleanly
              main_running = 1;
              if(enable_signal_handler()==-1){
                  M_ERROR("Failed to start signal handler\n");
                  return -1;
              M_DEBUG("Using input:     %s\n", context.input_pipe_name);
              M_DEBUG("Using RTSP port: %s\n", context.rtsp_server_port);
              M_DEBUG("Using bitrate:   %d\n", context.output_stream_bitrate);
              M_DEBUG("Using roatation: %d\n", context.output_stream_rotation);
              M_DEBUG("Using decimator: %d\n", context.output_frame_decimator);
              // Pass a pointer to the context to the pipeline module
              pipeline_init(&context);
              // Initialize Gstreamer
              gst_init(NULL, NULL);
              pipe_client_set_connect_cb(0, _cam_connect_cb, NULL);
              pipe_client_set_disconnect_cb(0, _cam_disconnect_cb, NULL);
              pipe_client_set_camera_helper_cb(0, _cam_helper_cb, &context);
              pipe_client_open(0, context.input_pipe_name, "voxl-streamer", EN_PIPE_CLIENT_CAMERA_HELPER, 0);
              while (main_running) {
                  if (context.input_parameters_initialized) break;
                  usleep(500000);
              if (context.input_parameters_initialized) {
                  M_DEBUG("Input parameters initialized\n");
              } else {
                  M_ERROR("Timeout on input parameter initialization\n");
                  return -1;
              // Create the RTSP server
              context.rtsp_server = gst_rtsp_server_new();
              if (context.rtsp_server) {
                  M_DEBUG("Made rtsp_server\n");
              } else {
                  M_ERROR("couldn't make rtsp_server\n");
                  return -1;
              // Configure the RTSP server port
              g_object_set(context.rtsp_server, "service", context.rtsp_server_port, NULL);
              // Setup the callback to alert when a new connection has come in
              g_signal_connect(context.rtsp_server, "client-connected",
                               G_CALLBACK(rtsp_client_connected), &context);
              // Setup the glib loop for the RTSP server to use
              loop_context = g_main_context_new();
              if (loop_context) {
                  M_DEBUG("Created RTSP server main loop context\n");
              } else {
                  M_ERROR("Couldn't create loop context\n");
                  return -1;
              loop = g_main_loop_new(loop_context, FALSE);
              if (loop) {
                  M_DEBUG("Created RTSP server main loop\n");
              } else {
                  M_ERROR("Couldn't create loop\n");
                  return -1;
              // Add an event source to the loop context. This will generate a callback
              // at 1 second intervals. We can use this to detect when the program is
              // ending and exit the loop
              loop_source = g_timeout_source_new_seconds(1);
              if (loop_source) {
                  M_DEBUG("Created RTSP server main loop source for callback\n");
              } else {
                  M_ERROR("Couldn't create loop source for callback\n");
                  return -1;
              g_source_set_callback(loop_source, loop_callback, loop, NULL);
              g_source_attach(loop_source, loop_context);
                // attach timeout to out loop
              time_loop_source = g_timeout_source_new_seconds(2);
              if (time_loop_source) {
                  M_DEBUG("Created timeout loop source for callback\n");
              } else {
                  M_ERROR("Couldn't create timeout loop source for callback\n");
                  return -1;
              g_source_set_callback(time_loop_source, timeout, &context, NULL);
              g_source_attach(time_loop_source, loop_context);
              g_main_context_unref(loop_context);
              g_source_unref(loop_source);
              g_source_unref(time_loop_source);
              // get the mount points for the RTSP server, every server has a default object
              // that will be used to map uri mount points to media factories
              mounts = gst_rtsp_server_get_mount_points(context.rtsp_server);
              if ( ! mounts) {
                  M_ERROR("Couldn't get mount points\n");
                  return -1;
              // We override the create element function with our own so that we can use
              // our custom pipeline instead of a launch line.
              factory = gst_rtsp_media_factory_new();
              if ( ! factory) {
                  M_ERROR("Couldn't create new media factory\n");
                  return -1;
              // Set as shared to consider video disconnects
              gst_rtsp_media_factory_set_shared (factory, TRUE);
              GstRTSPMediaFactoryClass *memberFunctions = GST_RTSP_MEDIA_FACTORY_GET_CLASS(factory);
              if ( ! memberFunctions) {
                  M_ERROR("Couldn't get media factory class pointer\n");
                  return -1;
              memberFunctions->create_element = create_custom_element;
              char *link_name = "/live";
              gst_rtsp_mount_points_add_factory(mounts, link_name, factory);
              g_object_unref(mounts);
              // Attach the RTSP server to our loop
              int source_id = gst_rtsp_server_attach(context.rtsp_server, loop_context);
              M_DEBUG("Got %d from gst_rtsp_server_attach\n", source_id);
              if ( ! source_id) {
                  M_ERROR("gst_rtsp_server_attach failed\n");
                  return -1;
              // Indicate how to connect to the stream
              M_PRINT("Stream available at rtsp://127.0.0.1:%s%s\n", context.rtsp_server_port,
                     link_name);
              // Start the main loop that the RTSP Server is attached to. This will not
              // exit until it is stopped.
              g_main_loop_run(loop);
              g_main_loop_unref(loop);
              // Main loop has exited, time to clean up and exit the program
              M_DEBUG("g_main_loop exited\n");
              // Wait for the buffer processing thread to exit
              pipe_client_close_all();
              // Stop any remaining RTSP clients
              (void) gst_rtsp_server_client_filter(context.rtsp_server, stop_rtsp_clients, NULL);
              // Clean up gstreamer
              gst_deinit();
              M_PRINT("Exited Cleanly\n");
              return 0;
            this is very helpful, thank you. We will try to incorporate. We do accept pull requests on our gitlab for future reference
            • S Offline
              S Offline
              stevedan
              @Chad-Sweet @RichieRich Just created a pull request, I though I couldn't. It is here https://gitlab.com/voxl-public/voxl-sdk/services/voxl-streamer/-/merge_requests/24. Would love to follow up on this, in case any changes are made from your side to incorporate in on our side.
              • ? Offline
                Everything looks good, gave it a glance and a quick test, it's been merged to our dev and staging branches in v0.4.2 and will be in the next release, thanks!
