  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. Artefacts and poor image quality on high frame-rates using the hardware encoder
voxl-streamerstreamingh264voxl-camera
4 Posts 3 Posters 1.8k Views 1 Watching
  • Viorel BaicuV Offline
    Viorel Baicu
    I'm trying to use the VOXL streamer to create an RTSP Stream that I can record and further streamer over the internet from my UAV. However, I'm not able to get a quality stream at an acceptable framerate. For my Application, 15 to 20 FPS would be enough.
    I have the following settings for the voxl-camera-server:
    voxl2:~$ cat /etc/modalai/voxl-camera-server.conf
    	"version":	0.1,
    	"cameras":	[{
    			"name":	"tracking",
    			"enabled":	true,
    			"frame_rate":	30,
    			"type":	"ov7251",
    			"camera_id":	0,
    			"ae_desired_msv":	60,
    			"ae_filter_alpha":	0.600000023841858,
    			"ae_ignore_fraction":	0.20000000298023224,
    			"ae_slope":	0.05000000074505806,
    			"ae_exposure_period":	1,
    			"ae_gain_period":	1
    			"name":	"hires",
    			"enabled":	true,
    			"frame_rate":	24,
    			"api":	"hal3",
    			"type":	"imx214",
    			"camera_id":	1,
    			"decimator":	2,
    			"preview_width":	1920,
    			"preview_height":	1080,
    			"snapshot_width":	3840,
    			"snapshot_height":	2160
    and the following config for the vxol-streamer
    voxl2:~$ cat /etc/modalai/voxl-streamer.conf
    	"input-pipe":	"hires",
    	"bitrate":	1000000,
    	"decimator":	1,
    	"port":	8900,
    	"rotation":	0
    With this config, the stream indeed has 24 FPS,l but the image is full of artefacts and at a very low quality, resembling a low bitrate stream. Increasing or decreasing the bitrate has no effect on the stream quality
    If I put the decimator to 4, I get ~4FPS, but the image quality is perfect, crisp with no artefacts.
    If I try to use the software encoder, the image quality at 24FPS is much, better, but the image itself is distorted. This gives me the impression that there is some issue with the hardware encoder.
    The MJPEG stream provided within the VOXL portal has an overall acceptable image quality, but the MJPEG bandwidth requirements are too high for my application.
    Also, when a client connects to the MJPEG stream, the VOXL streamer RTSP streams dies, and requires a service restart. This is different issue and I believe you already knew about it.
    Any help in regards to increasing the quality of the image on the RTSP stream would be helpful.
    I could provide video recordings of the RTSP stream to observes the quality issues.
    I have raised a ticket on gitlab for support on this issue:
    Link Preview Image
    Artefacts and poor image quality on high frame-rates using the hardware encoder (#5) · Issues · voxl / VOXL SDK / Services / voxl-streamer · GitLab
    I'm trying to use the VOXL streamer to create an RTSP Stream that I can record and further streamer over the internet from my UAV. However, I'm not...
    favicon
    GitLab (gitlab.com)
      This all points to your radio link not having enough bandwidth.
      Can you try using WiFi with good coverage to eliminate radio issues?
      Tuning the video pipeline to match your radio bandwidth is important. Can you measure the throughput of your radio link? Your bitrate settings should be about 90% of your radio capacity. If your bitrate settings are too high you will have issues
        Viorel Baicu
        I recorded the RSTP stream locally, on the device, using the ffmpeg. The bandwidth cannot be an influence.
        ffmpeg -i rtsp://localhost:8900/live -c copy -f segment -strftime 1 -segment_time 300 -segment_format mpegts /var/lib/rdars/recording/saved_%Y-%m-%d_%H-%M-%S.ts
        The recording shows the bad quality of the stream.
        • P Offline
          P Offline
          PSI
          1,000,000 bps (1Mbps) seems low for a FHD stream. What bitrates did you try? Did you try increasing it to 10,000,000 or even 30,000,000 to see if that makes a difference? I'm running 1920x1080 @ 20 FPS with no major artifacts using this.
          The alternative would be either changing resolution or trying to switch to a different codec such as H265 or VP9 (which appear to be supported on the VOXL2 by just searching the gst-inspect-1.0 output), but that would require changes to the voxl-streamer source.
