    Cannot connect QGroundControl to internal PX4 (VOXL2)
    • M
      mlarsen
      Hi All,
      I can't get QGroundControl to connect to the internal PX4. I ran voxl-vision-px4 to setup the mavlink connection. voxl inspect shows the following.
      docker-daemon | Disabled | Not Running |
      modallink-relink | Disabled | Not Running |
      voxl-camera-server | Enabled | Not Running |
      voxl-cpu-monitor | Disabled | Not Running |
      voxl-imu-server | Enabled | Running | 0.0
      voxl-mavlink-server | Enabled | Running | 0.0
      voxl-modem | Disabled | Not Running |
      voxl-portal | Disabled | Not Running |
      voxl-px4 | Enabled | Running | 0.0
      voxl-qvio-server | Disabled | Not Running |
      voxl-remote-id | Disabled | Not Running |
      voxl-softap | Disabled | Not Running |
      voxl-streamer | Disabled | Not Running |
      voxl-tflite-server | Disabled | Not Running |
      voxl-vision-px4 | Enabled | Not Running |
      The voxl-vision-px4.conf shows:
      "config_file_version": 1,
      "qgc_ip": "10.4.107.57",
      "en_secondary_qgc": false,
      "secondary_qgc_ip": "192.168.1.214",
      "qgc_udp_port_number": 14550,
      "udp_mtu": 512,
      "en_localhost_mavlink_udp": true,
      "localhost_udp_port_number": 14551,
      "vio_pipe": "qvio",
      "en_vio": true,
      "en_send_vio_to_qgc": false,
      "vio_warmup_s": 3,
      "send_odom_while_failed": false,
      "horizon_cal_tolerance": 0.5,
      "offboard_mode": "off",
      "follow_tag_id": 0,
      "figure_eight_move_home": true,
      "robot_radius": 0.300000011920929,
      "collision_sampling_dt": 0.1,
      "max_lookahead_distance": 1,
      "en_tag_fixed_frame": false,
      "fixed_frame_filter_len": 5,
      "en_transform_mavlink_pos_setpoints_from_fixed_frame": false,
      "en_voa": true,
      "en_send_voa_to_qgc": false,
      "voa_upper_bound_m": -0.15000000596046448,
      "voa_lower_bound_m": 0.15000000596046448,
      "voa_memory_s": 1,
      "voa_inputs": [{
      "enabled": true,
      "type": "point_cloud",
      "input_pipe": "dfs_point_cloud",
      "frame": "stereo_l"
      "enabled": true,
      "input_pipe": "stereo_front_pc",
      "frame": "stereo_front_l"
      "enabled": true,
      "input_pipe": "stereo_rear_pc",
      "frame": "stereo_rear_l"
      "enabled": true,
      "type": "tof",
      "input_pipe": "tof",
      "frame": "tof"
      "enabled": true,
      "type": "rangefinder",
      "input_pipe": "rangefinders",
      "frame": "body"
      and the IP is correct. Nothing shows up at the QGroundControl client side.
      • Chad SweetC
        Chad Sweet ModalAI Team
        Can you ping 192.168.1.214 from the computer that you are running QGC to make sure there is proper network connectivity between the two?
        • M
          mlarsen @Chad Sweet
          @Chad-Sweet I haven't tried. However, I manage to get it working by doing a factory reset configuration of the VOXL2. Don't know why it made a difference though.
