Unable to flash VOXL2 image after installing QDL image
I tried to flash the voxl2_platform_0.9.tar.gz platform release onto a VOXL2. This failed and device was no longer visible with
adb devices, even after resets of device and restarting adb. I followed https://docs.modalai.com/voxl2-qdl/ instructions to recover the device using QDL. Installing the QDL image succeeded.However multiple attempts to reinstall the voxl platform release failed (including when forcing fastboot). I varied usb cable used; deploying from Mac vs Ubuntu; forcing fastboot; re-imaging the QDL image. Ultimately I was able to redeploy (retrying the forcing fastboot instructions, using an Ubuntu machine) but I am concerned that many attempts failed.
Below are the various errors I saw. Please can you give an indication of possible causes for them so I try to avoid in future? Any help much appreciated.
1) Failure to boot to fastmode:
./install.sh [INFO] adb installed [INFO] fastboot installed ----Starting System Image Flash---- Detected OS: Linux Installer Version: 0.8 Image Version: 1.4.1 [INFO] Found adb device, rebooting to fastboot [ERROR] Failed to reboot to fastboot [INFO] Failed to put device in fastboot mode, exitingDo you know what causes this?
2) Unable to write to partition
Multiple times I saw
voxl2-platform % ./install.sh [INFO] adb installed [INFO] fastboot installed ----Starting System Image Flash---- Detected OS: OSX Installer Version: 0.8 Image Version: 1.4.1 [INFO] Found adb device, rebooting to fastboot [INFO] Found fastboot device [WARNING] This system image flash is intended only for the following platform: VOXL2 (m0054) Make sure that the device that will be flashed is correct. Flashing a device with an incorrect system image will lead the device to be stuck in fastboot. Would you like to continue with the VOXL2 (m0054) system image flash? 1) Yes 2) No #? 1 [INFO] {system::0xD3B5D7000} partition returned size {0x1A435F3000}, expected {0xD3B5D7000} [WARNING] Partition layout was found to be incorrect, this requires flashing the full partition table. Flashing the partition table will also flash every partition causing all data on the device to be lost. When doing a full flash, make sure to backup any important files Would you like to continue with the full wipe/flash now? 1) Yes 2) No #? 1 [INFO] Found all required files [ERROR] Failed to flash partition: partition:0 Sending 'partition:0' (0 KB) OKAY [ 0.006s] Writing 'partition:0' FAILED (remote: 'Error Updating partition Table ') fastboot: error: Command failed3) Low power warning
On one instance I saw the following. We were using the power supply that came with dev kit though with a US->UK adapter.
... [ERROR] Failed to flash partition: partition:0 target reported max download size of 805306368 bytes sending 'partition:0' (44 KB)... OKAY [ 0.007s] writing 'partition:0'... FAILED (remote: Warning: battery's capacity is very low ) finished. total time: 0.020s -
@MartinP This is a bug that we have since fixed but requires flashing that the image you're trying to flash in order to fix...
However, a work-around is to do the following when forcing the board into fastboot:
- disconnect power and USB
- press and hold fastboot button
- attach power
- attach usb
- wait a few seconds
- now release fastboot button
