  3. ERROR: failed to initialize IMU0
flight-deck
9 Posts 3 Posters 1.8k Views
  • JP DroneJ Offline
    JP DroneJ Offline
    JP Drone
    I got new VOXL Flight Deck.
    But it seems imu0 is not detected.
    voxl-imu-server.conf is default.
    Do I need to do any configuration to use IMU0?
    / # voxl-list-pipes | grep "imu"
    imu1
    / # journalctl -u voxl-imu-server
    -- Logs begin at Thu 1970-01-01 00:00:04 UTC, end at Mon 2022-06-27 07:43:07 UT
    C. --
    Jan 01 00:00:07 apq8096 systemd[1]: Starting voxl-imu-server...
    Jan 01 00:00:09 apq8096 systemd[1]: Started voxl-imu-server.
    Jan 01 00:00:09 apq8096 voxl-imu-server[2782]: ERROR: imu_detect failed to find a valid part
    Jan 01 00:00:09 apq8096 voxl-imu-server[2782]: ERROR: failed to initialize IMU0
    M0019-REV B
    • James StrawsonJ Offline
      James Strawson
      Do you mind sharing the output of voxl-imu-server --test and voxl-version thanks!
      VIO can be configured to use either IMU, to select IMU1 just run voxl-configure-qvio and select IMU1 when prompted which to use.
      • JP DroneJ Offline
        JP DroneJ Offline
        JP Drone
        voxl:~$ voxl-imu-server --test
        exising instance of voxl-imu-server found, attempting to stop it
        detected ICM20948 on spi bus[id] 1
        Starting self-test on ICM20948 on SPI bus 1
        gyro axis: 0 ratio: 1.009 response: 15858 factory: 15709 offset_dps: -0.97
        gyro axis: 1 ratio: 1.012 response: 18092 factory: 17878 offset_dps: -0.08
        gyro axis: 2 ratio: 1.004 response: 20218 factory: 20145 offset_dps: -0.22
        accl axis: 0 ratio: 0.998 response:  6729 factory:  6742
        accl axis: 1 ratio: 1.001 response:  7094 factory:  7086
        accl axis: 2 ratio: 1.017 response:  8710 factory:  8561
        RESULT FOR IMU0 on SPI BUS 10
        GYRO X: FAIL
        GYRO Y: FAIL
        GYRO Z: FAIL
        ACCL X: FAIL
        ACCL Y: FAIL
        ACCL Z: FAIL
        OVERALL FAIL: COULD NOT COMMUNICATE WITH IMU
        RESULT FOR IMU1 on SPI BUS 1
        GYRO X: PASS
        GYRO Y: PASS
        GYRO Z: PASS
        ACCL X: PASS
        ACCL Y: PASS
        ACCL Z: PASS
        OVERALL PASS
        This self-test required the voxl-imu-server service to stop
        You can restart it if desired with:  systemctl restart voxl-imu-server
        Exiting Cleanly
        voxl:~$ voxl-version
        cat: /etc/modalai/voxl-software-bundle-version.txt: No such file or directory
        system-image:    ModalAI 3.6.0 BUILDER: ekatzfey BUILD_TIME: 2022-02-28_23:47
        kernel:          #1 SMP PREEMPT Mon Feb 28 23:55:47 UTC 2022 3.18.71-perf
        factory-bundle:  1.0.1 (Yocto installation)
        architecture:    aarch64
        processor:       apq8096
        os:              GNU/Linux
        voxl-suite:
        Package: voxl-suite
        Version: 0.5.0
        Depends: libjpeg_turbo (>= 9.0.4), libmodal_exposure (>= 0.0.2), libmodal_json (>= 0.3.6), libmodal_pipe (>= 2.1.1), librc_math (>= 1.1.5), libvoxl_cutils (>= 0.0.2), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.2), mongoose (>= 7.3.0), opencv (>= 4.5.2-2), openmp (>= 10.0.2), voxl-camera-calibration (>= 0.1.1), voxl-camera-server (>= 0.8.1), voxl-cpu-monitor (>= 0.2.0), voxl-dfs-server (>= 0.2.2), voxl-docker-support (>= 1.1.3), voxl-gphoto2 (>= 0.0.5), voxl-imu-server (>= 0.9.1), voxl-mavlink (>= 0.0.2), voxl-modem (>= 0.12.0), voxl-mpa-tools (>= 0.3.6), voxl-nodes (>= 0.2.0), voxl-portal (>= 0.1.2), voxl-qvio-server (>= 0.3.4), voxl-streamer (>= 0.2.6), voxl-tag-detector (>= 0.0.2), voxl-tflite (>= 2.2.3), voxl-tflite-server (>= 0.1.5), voxl-utils (>= 0.8.4), voxl-vision-px4 (>= 0.9.5), voxl-vpn (>= 0.0.3)
        Section: base
        Architecture: all
        Maintainer: james@modalai.com
        MD5Sum: f55ec020942e92ff12bc137c2aa8d2a5
        Filename: voxl-suite_0.5.0.ipk
        Description: meta-package for voxl-suite software collection
        Installed-Time: 1656138820
        Package: voxl-suite
        Version: 0.2.0
        Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
        Section: base
        Architecture: armv7a
        MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
        Filename: voxl-suite_0.2.0.ipk
        Description: meta-package to install all of the voxl-suite
        Yes, VIO works if I select IMU1 (default is IMU0).
        I flashed system image to 3.6.0 (preserve the /data/ parition).
        I didn't confirm whether IMU0 was working at 3.3.0.
        If necessary, I can re-install 3.3.0 and check again.
        • JP DroneJ Offline
          JP DroneJ Offline
          JP Drone
          @James-Strawson Could you please check the outputs?
          I want to know whether this is hardware issue or configuration issue.
          • JP DroneJ Offline
            JP DroneJ Offline
            JP Drone
            I flashed system image v3.3.0.
            But imu0 still doesn't work.
            / # voxl-imu-server --test
            gyro axis: 0 ratio: 1.009 response: 15851 factory: 15709 offset_dps: -0.92
            gyro axis: 1 ratio: 1.010 response: 18051 factory: 17878 offset_dps: -0.08
            gyro axis: 2 ratio: 1.003 response: 20198 factory: 20145 offset_dps: -0.17
            accl axis: 0 ratio: 0.997 response:  6724 factory:  6742
            accl axis: 1 ratio: 1.009 response:  7151 factory:  7086
            accl axis: 2 ratio: 1.001 response:  8572 factory:  8561
            GYRO X: FAIL
            GYRO Y: FAIL
            GYRO Z: FAIL
            ACCL X: FAIL
            ACCL Y: FAIL
            ACCL Z: FAIL
            GYRO X: PASS
            GYRO Y: PASS
            GYRO Z: PASS
            ACCL X: PASS
            ACCL Y: PASS
            ACCL Z: PASS
            OVERALL PASS
            Exiting Cleanly
            / # voxl-version
            system-image:    ModalAI 3.3.0 BUILDER: ekatzfey BUILD_TIME: 2021-06-06_19:28
            kernel:          #1 SMP PREEMPT Sun Jun 6 19:41:01 UTC 2021 3.18.71-perf
            processor:       apq8096
            os:              GNU/Linux
            voxl-suite:
            Package: voxl-suite
            Version: 0.5.0
            Architecture: all
            Installed-Time: 218
            • JP DroneJ Offline
              JP DroneJ Offline
              JP Drone
              @James-Strawson
              When I upgrade to v3.8, voxl-imu-server no longer starts.
              I think imu0 is not available, it is an initial defect.
              root@apq8096:~# voxl-version
              system-image: 3.8.0
              kernel:       #1 SMP PREEMPT Tue Apr 26 18:08:39 UTC 2022 3.18.71-perf
              hw version:   VOXL
              voxl-suite:   0.7.0
              root@apq8096:~# voxl-imu-server --test
              received SIGINT Ctrl-C
              gyro axis: 0 ratio: 1.012 response: 15893 factory: 15709 offset_dps: -0.99
              gyro axis: 1 ratio: 1.013 response: 18108 factory: 17878 offset_dps: -0.10
              gyro axis: 2 ratio: 1.005 response: 20253 factory: 20145 offset_dps: -0.18
              accl axis: 0 ratio: 0.999 response:  6735 factory:  6742
              accl axis: 1 ratio: 1.008 response:  7146 factory:  7086
              accl axis: 2 ratio: 1.000 response:  8562 factory:  8561
              GYRO X: FAIL
              GYRO Y: FAIL
              GYRO Z: FAIL
              ACCL X: FAIL
              ACCL Y: FAIL
              ACCL Z: FAIL
              GYRO X: PASS
              GYRO Y: PASS
              GYRO Z: PASS
              ACCL X: PASS
              ACCL Y: PASS
              ACCL Z: PASS
              OVERALL PASS
              Exiting Cleanly
              root@apq8096:~# voxl-inspect-services
               modallink-relink     | Disabled  | Not Running |
               voxl-camera-server   |  Enabled  |   Running   |     4.9
               voxl-cpu-monitor     |  Enabled  |   Running   |     0.0
               voxl-dfs-server      | Disabled  | Not Running |
               voxl-imu-server      |  Enabled  | Not Running |
               voxl-mavlink-server  |  Enabled  |   Running   |     0.0
               voxl-portal          |  Enabled  |   Running   |     0.0
               voxl-qvio-server     |  Enabled  |   Running   |     0.0
               voxl-streamer        | Disabled  | Not Running |
               voxl-tag-detector    | Disabled  | Not Running |
               voxl-tflite-server   | Disabled  | Not Running |
               voxl-vision-px4      |  Enabled  |   Running   |     0.0
              The log showed that the service was stuck in a restart loop due to "Service hold-off time over, scheduling restart".
              root@apq8096:~# journalctl -u voxl-imu-server
              -- Logs begin at Thu 1970-01-01 00:34:23 UTC, end at Mon 2022-08-22 06:05:16 UTC. --
              Jan 01 00:34:27 apq8096 systemd[1]: Starting voxl-imu-server...
              Jan 01 00:34:29 apq8096 systemd[1]: Started voxl-imu-server.
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: ERROR: imu_detect failed to find a valid part
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: ERROR in imu_detect_board detecting imu0
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: loading calibration file
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: =================================================================
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: calibration for IMU0:
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: Gyro Offsets (rad/s): X:   0.000 Y:   0.000 Z:   0.000
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: Accl Offsets (m/s^2): X:   0.000 Y:   0.000 Z:   0.000
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: Accl Scale          : X:   1.000 Y:   1.000 Z:   1.000
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: has_baseline_temp:      0
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: gyro_baseline_temp (C):  30.000
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: accl_baseline_temp (C):  30.000
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: has_temp_cal:          0
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: gyro_drift_coeff: X:   0.000000   0.000000   0.000000
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: gyro_drift_coeff: Y:   0.000000   0.000000   0.000000
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: gyro_drift_coeff: Z:   0.000000   0.000000   0.000000
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: accl_drift_coeff: X:   0.000000   0.000000   0.000000
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: accl_drift_coeff: Y:   0.000000   0.000000   0.000000
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: accl_drift_coeff: Z:   0.000000   0.000000   0.000000
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: calibration for IMU1:
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: calibration for IMU2:
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: calibration for IMU3:
              Jan 01 00:34:29 apq8096 systemd[1]: [[1;39mvoxl-imu-server.service: Main process exited, code=exited, status=255/n/a[[0
              m
              Jan 01 00:34:29 apq8096 systemd[1]: [[1;39mvoxl-imu-server.service: Unit entered failed state.[[0m
              Jan 01 00:34:29 apq8096 systemd[1]: [[1;39mvoxl-imu-server.service: Failed with result 'exit-code'.[[0m
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: loading config file
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: imu0_enable:                     1
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: imu0_bus:                        10
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: imu0_sample_rate_hz:             1000.0
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: imu0_lp_cutoff_freq_hz:          92.0
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: imu0_rotate_common_frame         1
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: imu0_read_every_n_samples:       10
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: imu1_enable:                     1
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: imu1_bus:                        1
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: imu1_sample_rate_hz:             1000.0
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: imu1_lp_cutoff_freq_hz:          92.0
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: imu1_rotate_common_frame         1
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: imu1_read_every_n_samples:       10
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: aux_imu2_enable:                 0
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: aux_imu2_spi_bus:                9
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: aux_imu2_sample_rate_hz:         1000.0
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: aux_imu2_lp_cutoff_freq_hz:      92.0
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: aux_imu2_read_every_n_samples:   10
              Jan 01 00:34:29 apq8096 voxl-imu-server[2894]: aux_imu2_spi_bus:                11
              Jan 01 00:34:29 apq8096 systemd[1]: voxl-imu-server.service: Service hold-off time over, scheduling restart.
              Jan 01 00:34:29 apq8096 systemd[1]: Stopped voxl-imu-server.
              Jan 01 00:34:29 apq8096 systemd[1]: Starting voxl-imu-server...
              S 1 Reply Last reply
              • JP DroneJ JP Drone
                @James-Strawson
                system-image: 3.8.0
                hw version:   VOXL
                voxl-suite:   0.7.0
                GYRO X: FAIL
                GYRO Y: FAIL
                GYRO Z: FAIL
                ACCL X: FAIL
                ACCL Y: FAIL
                ACCL Z: FAIL
                GYRO X: PASS
                GYRO Y: PASS
                GYRO Z: PASS
                ACCL X: PASS
                ACCL Y: PASS
                ACCL Z: PASS
                OVERALL PASS
                Exiting Cleanly
                m
                S Offline
                S Offline
                stevedan
                @JP-Drone were you able to fix it?
                • JP DroneJ Offline
                  JP DroneJ Offline
                  JP Drone
                  @stevedan Couldn't find the way to solve so we sent back to ModalAI with RMA.
                  I wonder what was the issue of this.
                    S Offline
                    S Offline
                    stevedan
                    @JP-Drone In my case, I was using the rb5 so the correct service was voxl-px4-imu-server, which was already running. The qvio, vison-px4 takes imu from imu_px4 not imu0. This is specific for the rb5.
