    Voxl_mpa_to_ros
    1383
    • G
      gauravshukla914
      For some reason, when I do -
      roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
      it doesn't seem to work fully. Here's the output -
      voxl:~$ roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
      ... logging to /home/root/.ros/log/7da4c736-3eb2-11ed-b715-18473db1be57/roslaunch-apq8096-3745.log
      Checking log directory for disk usage. This may take awhile.
      Press Ctrl-C to interrupt
      Done checking log file disk usage. Usage is <1GB.
      started roslaunch server http://localhost:57891/
      SUMMARY
      PARAMETERS
       * /rosdistro: indigo
       * /rosversion: 1.11.21
      NODES
          voxl_mpa_to_ros_node (voxl_mpa_to_ros/voxl_mpa_to_ros_node)
      auto-starting new master
      process[master]: started with pid [3764]
      ROS_MASTER_URI=http://localhost:11311
      setting /run_id to 7da4c736-3eb2-11ed-b715-18473db1be57
      process[rosout-1]: started with pid [3777]
      started core service [/rosout]
      process[voxl_mpa_to_ros_node-2]: started with pid [3780]
      MPA to ROS app is now running
      Found new interface: qvio_overlay
      Found new interface: stereo
      Found new interface: tracking
      Found new interface: imu1
      And it stops after this. When I do rostopic list on the other terminal, it says unable to communicate with the Master. My bashrc file is correct with correct ROS_MASTER_IP and ROS_IP. Even rqt says the same thing. I plan to see the output of the camera in the rqt viewer.
      Dong LiuD 1 Reply Last reply Reply Quote 0
      • G
        gauravshukla914
        Can someone help me with this? Thanks!
        • T
          tangotoo
          I don't know if its related to your problem, but I had a lack of communication issue between voxl-vision and my PX4 and it was due to an additional process, voxl-mavlink-server not running. You may want to check if there are any other supporting processes you need running first in order to bring up ROS. I'm not a ROS user, so I can't help too much in that regard.
          • G
            gauravshukla914
            @modaltb @Ed-Sutter @tom @Alex-Gardner anyone?
            • Dong LiuD
              Dong Liu @gauravshukla914
              @gauravshukla914
              Don't know it is related. But I had the same experience. You can't rostopic list because the ROS_MASTER_URI and ROS_IP are not set correctly.
              There is file /home/root/my_ros_env.sh which defines these two variables. Need to be changed to reflect the real values.
              Dong
              • G
                gauravshukla914
                @Dong-Liu yes that's correct. Everytime a master ip or ros ip changes, I make sure to give the corrects IPs in the bachrc file and source it. This is not the issue, but thanks for the suggestion though!
                • G
                  gauravshukla914
                  This is solved. I'm made to source my_ros_env.sh file everytime before launching the mpa file. But this never used to happen before. Anyway for now its working by sourcing the my_ros_env.sh everytime. Thanks all!
                  • Dong LiuD
                    @gauravshukla914 I also noticed it. Somehow on the drone's ROS indigo system. roslaunch voxl_mpa_to_ros voxl_map_to_ros.launch won't honor the existing ROS_MASTER_URI, it always source ROS_MASTER_URI etc from my_ros_env.sh
