  3. Trouble with EM7565 startup...
24 Posts 3 Posters 6.7k Views 3 Watching
  • Ed SutterE Ed Sutter
    @tom Well, when I plug the modem into my Ubuntu host using one of these testers it shows a suspiciously low current (10mA), but it also doesn't quite work (yet) on that system. The command mmcli --modem=0 shows (snippets):
      Hardware |         manufacturer: Sierra Wireless, Incorporated
               |                model: EM7565
               |             revision: SWI9X50C_01.08.04.00 dbb5d0 jenkins 2018/08/21 21:40:11
               |         h/w revision: 10001
               |            supported: gsm-umts, lte
               |              current: gsm-umts, lte
               |         equipment id: 353533100239592
      System   |               device: /sys/devices/pci0000:00/0000:00:14.0/usb1/1-1
               |              drivers: qcserial, qmi_wwan
               |               plugin: Sierra
               |         primary port: cdc-wdm0
               |                ports: ttyUSB0 (qcdm), ttyUSB2 (at), cdc-wdm0 (qmi),
               |                       wwp0s20f0u1i8 (net)
      Numbers  |                  own: 17327793967
      Status   |                 lock: sim-pin2
               |       unlock retries: sim-pin (3), sim-pin2 (3), sim-puk (10), sim-puk2 (10)
               |                state: registered
               |          power state: on
               |          access tech: lte
               |       signal quality: 59% (recent)
    and the interface only comes up if I manually bring it up with ifconfig wwp0s20fu1i8 up ...
    wwp0s20f0u1i8: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
            inet6 fe80::2495:2f9d:cec5:53f  prefixlen 64  scopeid 0x20<link>
            unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 1000  (UNSPEC)
            RX packets 0  bytes 0 (0.0 B)
            TX packets 11  bytes 528 (528.0 B)
    Notice, there's no inet address likely because [for some reason I have yet to understand] POINTOPOINT,NOARP flags are set. Any thoughts on that? (meanwhile I will get a powered USB hub for now just to see if it makes any difference).
    @Ed-Sutter The other thing you have to check is the USB vendor / device id. The Linux device drivers often have those hard coded into them for support. If those id's aren't in the driver then it won't set it up.
    Ed SutterE 1 Reply Last reply
      Ed SutterE Offline
      Ed SutterE Offline
      Ed Sutter
      @Eric-Katzfey That shows up with lsusb...
      Bus 001 Device 002: ID 1199:9091 Sierra Wireless, Inc.
      but I assume you're talking about something more specific to wwan? Do you know what I would look for to see if my host meets that requirement? I've obviously got modemmanager, libmbim-utils and libqmi-utils installed, but maybe I need newer versions?
        @Ed-Sutter I'm speaking specifically of VOXL, not your host computer, but it's the same idea. It's the actual Linux device driver for that piece of hardware. For example: https://gitlab.com/voxl-public/system-image-build/apq8096-kernel/-/blob/main/drivers/net/usb/qmi_wwan.c#L772
        Ed SutterE 5 Replies Last reply
          Ed SutterE Offline
          Ed SutterE Offline
          Ed Sutter
          @Eric-Katzfey got it... Thanks!
            Ed SutterE Offline
            Ed SutterE Offline
            Ed Sutter
              Ed SutterE Offline
              Ed SutterE Offline
              Ed Sutter
              @Eric-Katzfey Update... I don't have your USB expansion board yet (being ordered), but I was able to get things working by just using a powered USB hub; so I'm assuming it will work the same with the new expansion board.
                @Ed-Sutter Do you know how much power the m.2 to USB adapter you're plugging in is pulling? Depending on which add-on board you're plugging it into on VOXL, it may not be able to provide the required current. Some of our add-on boards' USB ports max out at 0.5 A (M0030, M0017, M0048).
                When we've tested with 3rd party modem USB adapters in the past we've had to use our debug board v2 (M0078): https://www.modalai.com/products/voxl-debug-board-v2?_pos=4&_sid=bc3d50f8c&_ss=r
                which allows you to provide a higher current to the USB port.
                Source for uqmi lives here: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-modem/-/tree/master/src/modem/uqmi
                Ed SutterE Offline
                Ed SutterE Offline
                Ed Sutter
                #10
                @tom I received the new USB add-on (M0078). I just wanna be sure I understand this... All I need to do to get more current is to move the jumper over to the USB-VBUS position? I assume that just bypasses any current-limiting protection that would be provided by the USB driver?
                true?
                  @Ed-Sutter You'll actually have the jumper on the USB PWR side as seen in this photo: b1cb3851-0bd7-4729-9655-23228ccef458-image.png
                  but otherwise yes you've got the right idea
                    Ed SutterE Offline
                    Ed SutterE Offline
                    Ed Sutter
                    @tom Cool! Just tried it with the EM7565...
                    ifconfig wwan0
                    wwan0     Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
                              inet addr:10.234.85.224  P-t-P:10.234.85.224  Mask:255.255.255.192
                              UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
                              TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
                              collisions:0 txqueuelen:1000
                              RX bytes:604 (604.0 B)  TX bytes:656 (656.0 B)
                    The modem came right up!
                      @Ed-Sutter Beautiful! Glad to hear that
                        Ed SutterE Offline
                        Ed SutterE Offline
                        Ed Sutter
                        @tom Do you guys have any plans to support the EM7565 with an alternative adapter?
                          @Ed-Sutter Not that I know of at the moment. Is there a specific reason why you're choosing to go with this card as opposed to others? I know you mentioned earlier that it supports certain bands you need.
                            Ed SutterE Offline
                            Ed SutterE Offline
                            Ed Sutter
                            @tom Yea, that's it, we need a band that is not supported by any of the modems that fit your add-on board. 😞
                            Anyway, now that I've had some time to work with it (the EM7565), things aren't as good as I initially thought...
                            I've been testing this in various ways and just getting more confused... Initially I was using voxl-streamer to push video over LTE to VLC on another machine. It starts up just fine (video is clean), but the video just stops after some random time (usually less than an hour). So I thought -maybe- my LTE service (I'm using a SIM card on my own AT&T account that is supposed to be used with a flip phone) was doing some throttling. I reduced the load to just open a TCP connection and send small messages (over LTE) every second. Same thing happens. Then I tried running the same thing but now just using WiFi while the wwan0 is up and alive... Same thing even on WiFi! Once it gets in this state, I can't ping out at all (on either interface), but all interfaces are up and I am able to ssh into VOXL. If I remove the EM7565, things are fine on WiFi.
                            Does this make any sense at all?
                            Can you think of anything I can do to diagnose this?
                            I have a small (cheap) USB power monitor in line with the modem and it never exceeds 100mA on the display.
                              @Ed-Sutter Does it work if you only have one of the network interfaces up at once? For example, only having wwan0 up or only having wlan0 up? I'm wondering if some weird routing issue happens
                                Ed SutterE Offline
                                Ed SutterE Offline
                                Ed Sutter
                                @tom Good thought! I'll try turning down wlan0 while using wwan0...
                                  @Ed-Sutter And to be safe if you're in station mode I would set your ssid and pass to dummy values, i.e voxl-wifi station tmp tmp because I've seen in the past where wlan0 will try to bring itself back up after you manually force it down.
                                  Ed SutterE 3 Replies Last reply
                                    Ed SutterE Offline
                                    Ed SutterE Offline
                                    Ed Sutter
                                    #20
                                    @tom Ok, I tried what you said (good idea by the way)... I turned down the wlan0 link and did a very minimial TCP/IP data transfer loop (about 25 characters a second) and after about 15 minutes things just got wonky. I terminated the test, and again, I wasn't able to ping out.
                                    So this morning I was going to reverse the interfaces (enable wlan0 and turn down wwan0) and repeat, but didn't get that far cause I noticed this...
                                    $: adb shell
                                    / # ifconfig
                                    docker0   Link encap:Ethernet  HWaddr 02:42:A2:AB:4C:25
                                              inet addr:----------  Bcast:0.0.0.0  Mask:255.255.0.0
                                              inet6 addr: ----------------/64 Scope:Link
                                              UP BROADCAST MULTICAST  MTU:1500  Metric:1
                                              TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
                                              collisions:0 txqueuelen:0
                                              RX bytes:0 (0.0 B)  TX bytes:216 (216.0 B)
                                    lo        Link encap:Local Loopback
                                              inet addr:127.0.0.1  Mask:255.0.0.0
                                              UP LOOPBACK RUNNING  MTU:65536  Metric:1
                                              TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
                                              RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
                                    wlan0     Link encap:Ethernet  HWaddr 18:47:3D:B1:BE:0F
                                              inet addr:192.168.1.230  Bcast:192.168.1.255  Mask:255.255.255.0
                                              inet6 addr: ----------------------------/64 Scope:Global
                                              UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
                                              RX packets:221 errors:0 dropped:0 overruns:0 frame:0
                                              TX packets:46 errors:0 dropped:0 overruns:0 carrier:0
                                              collisions:0 txqueuelen:3000
                                              RX bytes:45620 (44.5 KiB)  TX bytes:4536 (4.4 KiB)
                                              inet addr:--.--.--.--  P-t-P:--.--.--.--  Mask:255.255.255.192
                                              RX packets:22 errors:0 dropped:0 overruns:0 frame:0
                                              TX packets:22 errors:0 dropped:0 overruns:0 carrier:0
                                              RX bytes:2350 (2.2 KiB)  TX bytes:2164 (2.1 KiB)
                                    / # ping google.com
                                    PING google.com (142.251.40.238) 56(84) bytes of data.
                                    64 bytes from lga34s39-in-f14.1e100.net (142.251.40.238): icmp_req=1 ttl=55 time=38.8 ms
                                    64 bytes from lga34s39-in-f14.1e100.net (142.251.40.238): icmp_req=2 ttl=55 time=43.0 ms
                                    ^C
                                    --- google.com ping statistics ---
                                    2 packets transmitted, 2 received, 0% packet loss, time 1002ms
                                    rtt min/avg/max/mdev = 38.858/40.949/43.041/2.101 ms
                                    / # ip link set dev wwan0 down
                                    / # ping google.com
                                    ping: unknown host google.com
                                    / # ping 142.250.204.14
                                    PING 142.250.204.14 (142.250.204.14) 56(84) bytes of data.
                                    64 bytes from 142.250.204.14: icmp_req=1 ttl=117 time=199 ms
                                    64 bytes from 142.250.204.14: icmp_req=2 ttl=117 time=218 ms
                                    ^C
                                    --- 142.250.204.14 ping statistics ---
                                    2 packets transmitted, 2 received, 0% packet loss, time 1001ms
                                    rtt min/avg/max/mdev = 199.439/208.882/218.325/9.443 ms
                                    This is just after rebooting VOXL (I replaced some network addresses with dashes). Notice that the initial ping succeeds (using DNS), then I shut down wwan0, then second ping (using dns) fails, but when I use direct IP addess it succeeds.
                                    It seems like the DNS server configuration information in linux gets wonked after bringing wwan0 down.
                                    Any thoughts?
                                      Ed SutterE Offline
                                      Ed SutterE Offline
                                      Ed Sutter
                                      @tom One thing I just noticed...
                                      If I boot up without an LTE modem, then /etc/resolv.conf is:
                                      # Generated by dhcpcd from wlan0
                                      # /etc/resolv.conf.head can replace this line
                                      domain myfiosgateway.com
                                      nameserver 192.168.1.1
                                      # /etc/resolv.conf.tail can replace this line
                                      That (above) makes sense. That's my ISP (Fios) and wifi subnet in my home.
                                      If I boot up with the LTE modem, then /etc/resolve.conf is:
                                      nameserver 172.26.38.1
                                      Looks like something in the modem startup overwrites /etc/resolv.conf. The script "enable-dns.sh" is called by voxl-modem-start.sh, but it only writes to /etc/resolve.conf if it doesn't already exist (plus it writes 8.8.8.8, which apparently is Google dns).
                                      Any idea how this is being written?
                                        Ed SutterE Offline
                                        Ed SutterE Offline
                                        Ed Sutter
                                        @tom I'm starting a new thread on this...
                                          Ed SutterE Offline
                                          Ed SutterE Offline
                                          Ed Sutter
                                          #23
                                          @Eric-Katzfey Somehow this slipped through the cracks... I just looked in that file and I don't see the VID/PID of the EM7565 listed. So a couple of questions:
                                          1. What does this mean?
                                          2. Do you know what is involved in getting it listed?
                                          I have the latest driver files from Sierra Wireless, and they do have what I need. Is this a module that I can update on VOXL?
                                          Ed
