  3. m500 cannot hovering with VIO algorithm
m500
18 Posts 3 Posters 3.7k Views 3 Watching
  • modaltbM Offline
    modaltbM Offline
    modaltb
    Hi @Kaiba-Kun ,
    Can you perhaps attach a photo of the test frame?
    We do some specific tuning for the frame and perhaps vibration is being introduced that could cause some nasty effects?
    Travis
    Kaiba-KunK 1 Reply Last reply
    • Kaiba-KunK Offline
      Kaiba-KunK Offline
      Kaiba-Kun
      Hi. This is the base floor of us. Pls take a look.
      • modaltbM modaltb
        Hi @Kaiba-Kun ,
        Travis
        Kaiba-KunK Offline
        Kaiba-KunK Offline
        Kaiba-Kun
        @modaltb
          Kaiba-KunK Offline
          Kaiba-Kun
          and here.
            Kaiba-KunK Offline
            Kaiba-Kun
            actually the test frame is only attach in left and right side of UAV. The purpose of test frame is limits UAV in an area so we can avoid the damage when UAV loss control.
            @modaltb do you have any idea?
              The system was tested in VIO mode for 20 minutes before shipping. All drones are very sensitive to frame modifications, so this needs to be done carefully
              • Were you able to fly successfully before frame modifications?
              • How well does it fly manually? Have you looked at the logs in manual.mode for vibration?
              • Can you please share a log of the VIO output?
              • If you reset all of the software, you may need to recalibrate the cameras
              • It looks like there are loose parts hanging off of the drone. VIO is VERY sensitive to vibration. Can you revert your frame modifications and try again?
                Kaiba-KunK Offline
                Kaiba-Kun
                wrote on last edited by Kaiba-Kun
                Thank for reply,
                @Chad-Sweet when the first time our test flight with M500 everything is work properly. you can take a look in this link by the video named before reset.
                here
                • But after I reset the drone into the factory set up. It's seem the VIO is work with many vibrations, some time it be acceptable.
                • In the link above I was captured 3 videos and log file of each, for testing manual with VIO.
                • Do I needed to recalibration the camera? I see the data from VIO is quite good when we move the UAV by hand.
                • We were revert the UAV to the original state after that but the result is same.
                  Kaiba-KunK Offline
                  Kaiba-Kun
                  Also,
                  • We never try to flight in the manual mode, only use the position and offboard mode.
                  • I don't think the external material was the reason for this issue because we had attached the component in the bottom of the frame closed as much as possible.
                    Thank you.
                    A couple of ideas:
                    1. Try to calibrate the tracking camera. Instructions here: https://docs.modalai.com/calibrate-cameras/#calibrate-tracking-camera
                    2. Insert some foam, preferably memory foam, in between the "green tray" and the frame. This should help reduce vibration
                      Kaiba-KunK Offline
                      Kaiba-Kun
                      Thank for reply,
                      I'll try it in the tomorrow. We're in middle of night (GMT +7).
                        Kaiba-KunK Offline
                        Kaiba-Kun
                        if you have more advices, please tell us.
                        Best regard.
                          Can you please send the serial number of the VOXL Flight PCB? We might be able to look up the calibration files in our production database?
                            Kaiba-KunK Offline
                            Kaiba-Kun
                            #14
                            Hi @Chad-Sweet here is the serial number.
                              #15
                              Here's the test data:
                              Stereo Camera Calibration
                              left_file:
                              image_width: 640 image_height: 480 camera_name: stereo/left camera_matrix: rows: 3 cols: 3 data: [492.469682, 0.000000, 287.720563, 0.000000, 492.799801, 241.856917, 0.000000, 0.000000, 1.000000] distortion_model: plumb_bob distortion_coefficients: rows: 1 cols: 5 data: [-0.171887, 0.054112, 0.000816, 0.000653, 0.000000] rectification_matrix: rows: 3 cols: 3 data: [0.999125, 0.024029, 0.034224, -0.023993, 0.999711, -0.001454, -0.034249, 0.000631, 0.999413] projection_matrix: rows: 3 cols: 4 data: [509.343373, 0.000000, 291.779423, 0.000000, 0.000000, 509.343373, 233.497673, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000]
                              right_file:
                              image_width: 640 image_height: 480 camera_name: stereo/right camera_matrix: rows: 3 cols: 3 data: [494.055474, 0.000000, 337.960482, 0.000000, 494.170184, 223.591690, 0.000000, 0.000000, 1.000000] distortion_model: plumb_bob distortion_coefficients: rows: 1 cols: 5 data: [-0.182939, 0.076209, 0.000049, 0.002344, 0.000000] rectification_matrix: rows: 3 cols: 3 data: [0.999497, 0.010498, 0.029940, -0.010529, 0.999944, 0.000885, -0.029929, -0.001200, 0.999551] projection_matrix: rows: 3 cols: 4 data: [509.343373, 0.000000, 291.779423, -40.695510, 0.000000, 509.343373, 233.497673, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000]
                              snav_file:
                              <SnavCalibration> <SnavCalibrationStereo> <SnavCalibrationLeftStereo> <param name="calib_pixel_width" value="640" /> <param name="calib_pixel_height" value="480" /> <param name="calib_memory_stride" value="640" /> <param name="principal_point_x" value="287.720563" /> <param name="principal_point_y" value="241.856917" /> <param name="focal_length_x" value="492.469682" /> <param name="focal_length_y" value="492.799801" /> <param name="distortion_0" value="-0.171887" /> <param name="distortion_1" value="0.054112" /> <param name="distortion_2" value="0.000816" /> <param name="distortion_3" value="0.000653" /> <param name="distortion_4" value="0.0" /> <param name="distortion_5" value="0.0" /> <param name="distortion_6" value="0.0" /> <param name="distortion_7" value="0.0" /> <param name="distortion_model" value="4" /> </SnavCalibrationLeftStereo> <SnavCalibrationRightStereo> <param name="calib_pixel_width" value="640" /> <param name="calib_pixel_height" value="480" /> <param name="calib_memory_stride" value="640" /> <param name="principal_point_x" value="337.960482" /> <param name="principal_point_y" value="223.59169" /> <param name="focal_length_x" value="494.055474" /> <param name="focal_length_y" value="494.170184" /> <param name="distortion_0" value="-0.182939" /> <param name="distortion_1" value="0.076209" /> <param name="distortion_2" value="0.000049" /> <param name="distortion_3" value="0.002344" /> <param name="distortion_4" value="0.0" /> <param name="distortion_5" value="0.0" /> <param name="distortion_6" value="0.0" /> <param name="distortion_7" value="0.0" /> <param name="distortion_model" value="4" /> </SnavCalibrationRightStereo> <param name="correction_factors_0" value="0" /> <param name="correction_factors_1" value="0" /> <param name="correction_factors_2" value="0" /> <param name="correction_factors_3" value="0" /> <param name="translation_0" value="-0.0798577979308862" /> <param name="translation_1" value="-0.000838769063517393" /> <param name="translation_2" value="-0.00239214571934757" /> <param name="rotation_0" value="0.00226741960521865" /> <param name="rotation_1" value="0.00433160780762917" /> <param name="rotation_2" value="-0.0134848065488883" /> </SnavCalibrationStereo> </SnavCalibration>
                              Tracking Camera Calibration
                              cal_file:
                              image_width: 640 image_height: 480 camera_name: tracking camera_matrix: rows: 3 cols: 3 data: [277.095893, 0.000000, 324.145728, 0.000000, 277.407080, 209.238122, 0.000000, 0.000000, 1.000000] distortion_model: fisheye distortion_coefficients: rows: 1 cols: 4 data: [-0.018687, 0.034754, -0.034056, 0.011701] rectification_matrix: rows: 3 cols: 3 data: [1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000] projection_matrix: rows: 3 cols: 4 data: [303.434082, 0.000000, 333.786106, 0.000000, 0.000000, 297.322021, 188.396771, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000]
                              snav_file:
                              <SnavCalibration> <SnavCalibrationDownward> <param name="calib_pixel_width" value="640" /> <param name="calib_pixel_height" value="480" /> <param name="calib_memory_stride" value="640" /> <param name="principal_point_x" value="324.145728" /> <param name="principal_point_y" value="209.238122" /> <param name="focal_length_x" value="277.095893" /> <param name="focal_length_y" value="277.40708" /> <param name="distortion_0" value="-0.018687" /> <param name="distortion_1" value="0.034754" /> <param name="distortion_2" value="-0.034056" /> <param name="distortion_3" value="0.011701" /> <param name="distortion_4" value="0" /> <param name="distortion_5" value="0" /> <param name="distortion_6" value="0" /> <param name="distortion_7" value="0" /> <param name="distortion_model" value="10" /> </SnavCalibrationDownward> </SnavCalibration>
                                Kaiba-KunK Offline
                                Kaiba-Kun
                                Thank for answer, I've checked the test data above. Here is the list of the /etc/snav# diectory and i checked the calibration.downward.xml and calibration.stereo.xml but both of them are similar as the test data from you.
                                • For the camera matrix i've checked in the ~/.ros/root/camera_info folder and they also non change
                                  Ok, they should be exact. Did you remove vibration by adding foam?
                                    Kaiba-KunK Offline
                                    Kaiba-Kun
                                    Yes, after adding some foam, The UAV now are stable than a bit. Do you think the battery should be problem? Our 3S battery are quite old.
