    "Error battery voltage" on VOXL2
    1097
    • tanguy sagereT
      tanguy sagere
      Hi! I was setting up internet access to the VOXL2 (rather than sharing my laptop internet with it), working in root after ssh'ing into it from my laptop via my laptop Ethernet-> USB-A to JST adapter -> debug board USB2 Host-> VOXL2 when I suddenly couldnt connect anymore to the VOXL2 from my network manager (and so ssh wouldnt work).
      As that seemed weird, I rebooted the chip into normal mode and screened into it using the debug console (laptop connected to debug board with micro USB) but nothing would appear on screen. So I tried the same thing in fastboot mode; and the following happened (and keeps happening after changing cables, power socket, etc...) :
      This shortly pops up when screening the chip after fastbooting it
      Handling Cmd: getvar:version Error battery voltage: 0 Requireed voltage: 3600, can flash: 0
      Then this loops continuously :
      LmhIsenseInit Post GPU  TIME 2ms
      Entering in func1 of NPU  TIME 2ms NPU IDDQ 41 LmhIsenseSubSysEntry Post SubSysEntryCb  TIME 0ms
      LmhIsenseSubSysInit  TIME 0ms
      LmhIsenseInitSubSys Post SubSysEntry  TIME 0ms
      LmhIsenseInitSubSys Post SubSysTrim  TIME 0ms
      LmhIsenseInitSubSys Post SubSysExit  TIME 0ms
      LmhIsenseInit Post NPU  TIME 2ms
      isense  TIME 5ms ISENSE TOTAL TIME 5ms
      Disp init wait [ 1670]
      Platform Init  [ 1687] BDS
      UEFI Ver   : 5.0.220324.BOOT.XF.3.2-00354-SM8250-
      Platform           : QRD
      Chip Name          : QRB5165
      Chip Ver           : 2.1
      Chip Serial Number : 0x5A93EBEB
      Silver cluster Core 0 Freq: 1516 MHz
      UEFI Total : 524 ms
      POST Time      [ 1717] OS Loader
      Loader Build Info: Feb 18 2022 17:53:29
      VB: Non-secure device: Security State: (0xF7F)
      VB: RWDeviceState: Succeed using devinfo!
      KeyPress:2, BootReason:0
      Fastboot=1, Recovery:0
      GetVmData: making ScmCall to get HypInfo
      GetVmData: No Vm data present! Status = (0x3)
      VM Hyp calls not present
      Launching fastboot
      Fastboot Build Info: Feb 18 2022 17:53:28
      usb_shared_hs_phy_init: hs phy cfg size: 12
      usb_shared_ss_phy_init: ss phy cfg size: 143
      ssusb_phy_init_success_lane_A: 0
      Fastboot: Initializing...
      Fastboot: Processing commands
      Failed to get the graphics output protocol.
      Failed to get width or height Failed to get the graphics output protocol.
      Unable to show fastboot menu on screen: Out of Resources
      Dev_Common_Speed: Bus Speed: Super
      Dev_Common_Speed: Bus Speed: Super Handling
      Cmd: getvar:product Handling Cmd:
      getvar:version
      Upon ssh'ing to it with the debug board I get the following message :
      ssh: connect to host xx.xx.x.xxx port 22: Network is unreachable
      It should be noted that the chip still pops up in "fastboot devices" as well as in "dmesg -w", so its still alive. Whats going on and how can I fix this?
      • tanguy sagereT
        tanguy sagere
        For the sake of completeness, I flashed the modalai platform voxl2_platform_1.3.1-0.8.tar.gz on the device with the debug board disconnected (direct connection with USB-C). The flashing process completed successfully with install.sh but ;
        • The device appears in dmesg as "qcom Kona" which is correct.
        • sudo adb shell does not work.
        • sudo adb devices lists no devices.
        • I still see no output from the debug board serial debug monitor.
        • ethtool still says "no link detected" when connecting Ethernet to the debug board.
        I should also mention that I have been working with an ESD-bracelet and at no point was the VOXL2 subjected to contact with a conductive surface other than my hand, nor dropped or otherwise physically threatened.
        • modaltbM
          modaltb ModalAI Team
          Hi @tanguy-sagere ,
          We've seen this error message and have a fix in our next release, when it gets into this state we've typically been able to get out of it by reflashing following this process (which I'm sure you've done, but to be sure we want to remove USB cable when forcing into fastboot). Can you try again with the process in this video?
          https://docs.modalai.com/voxl2-system-image/#force-voxl-2-into-fastboot
          • tanguy sagereT
            tanguy sagere
            I followed the video you recommended, forcing into fastboot with USB-C disconnected at first and then flashing system image. Flashing goes well :
            |     Done installing voxl-suite for QRB5165        |
            [INFO] Done installing voxl-suite
            ----Installation Completed----
            But then when I restart the VOXL2 in normal boot and screen into it using the debug board serial debug monitor to observe the booting process; this is all that appears :
            Decompressing kernel image done: 3156 ms
            Dtbo hdr magic mismatch 0, with D7B7AB1E
            Best match DTB tags 455/0000000B/0x00000003/20001/3001E/20020/20027/20021/(offset)0x9A781B37/(size)0x0008B3AB
            Using pmic info 0x3001E/0x20020/0x20027/0x20021 for device 0x3001E/0x20020/0x20027/0x20021
            Memory Base Address: 0x80000000
            Cmdline: noinitrd  earlycon=msm_geni_serial,0xa90000 androidboot.hardware=qcom androidboot.console=ttyMSM0 androidboot.memcg=1 lpm_levels.sleep_disabled=1 video=vfb:640x400,bpp=32,memsize=3072000 msm_rtb.filter=0x237 service_locator.enable=1 androidboot.u
            RAM Partitions
            Add Base: 0x0000000080000000 Available Length: 0x000000003B800000
            Add Base: 0x0000000180000000 Available Length: 0x0000000100000000
            Add Base: 0x00000000C0000000 Available Length: 0x00000000C0000000
            ERROR: Could not get splash memory region node
            kaslr-Seed is added to chosen node
            Shutting Down UEFI Boot Services: 3227 ms
            Start EBS        [ 3228]
            BDS: LogFs sync skipped, Unsupported
            App Log Flush : 34 ms
            Exit EBS        [ 3280] UEFI End
            Is there a hardware defect with the VOXL2 or with the Debug board? Was this also part of the bug you encountered?
            Thanks for your time and help 🙂
            • tanguy sagereT
              tanguy sagere
              @tanguy-sagere said in "Error battery voltage" on VOXL2:
              Quick recap :
              • sudo adb shell works and sudo adb devices lists the VOXL2 since using a new USB-C cable.
              • In normal boot : I get a "ERROR: Could not get splash memory region node" error from the debug board serial debug monitor.
              • In forced fastboot : I get a "Unable to show fastboot menu on screen: Out of Resources" error from the debug board serial debug monitor.
              Im starting to think that the debug board failed mechanically for whatever reason. Is there a software fix for this or should I contact support personally to have the debug board replaced as per warranty?
              For information : I am using the "5G Model Carrier Board, USB HUB, I/O Breakout for VOXL 2 Carrier Board"
              • modaltbM
                Hi @tanguy-sagere ,
                OK the last part of that console output above "looks OK" for the non-debug kernel, I've captured my system here (note I'm rebooting over adb for connivence to show when thing are happening).
                Is this roughly what you see?
                https://www.youtube.com/watch?v=5axL8w-Zb6c
                The standard system image doesn't provide you a login over the debug console. You need to flash a debug kernel if you want to see the full bootup output (like dmesg but over the serial port) and you also can get a login over that same terminal, but the boot up time goes from ~10 seconds to like ~90 seconds, hence why we don't ship with a debug kernel!
                • tanguy sagereT
                  tanguy sagere
                  Yep that's what I was seeing! Ok I'm using a custom OS here with a debug kernel already included so flashing that again solved the issue. I'll make sure to have everything disconnected when I reboot it from now on. Is there any other way to prevent this from happening in the future? I mean we`d like to have the VOXL2 on a drone with all cables attached and be able to just toggle the power supply without having to dettach and reattach everything everytime. Thanks!
                  • modaltbM
                    Hi @tanguy-sagere ,
                    Generally you don't need to disconnect anything to boot successfully into fastboot using the button, but in the case where this battery warning shows up, and until we release our System Image 1.4.x which has a bootloader fix, the work around is to remove the USBC cable if this bootup issue displays.
                    wilkinsafW 1 Reply Last reply Reply Quote 0
                    • wilkinsafW
                      wilkinsaf ModalAI Team @modaltb
                      @modaltb This worked for me. Removing the USBC cable, booting up, and then plugging in.
