  3. HITL on VOXL 2 : Preflight fail EKF couldn't get status
10 Posts 2 Posters 2.1k Views
  • Tamas Pal 0T Offline
    Tamas Pal 0
    Re: Unable to access px4 with qgc in voxl 2 using usb-jst cable
    That problem with voxl-px4-hitl is solved. Thank you.
    When I am trying to run the voxl-px4-hitl, I am having this issue -
    INFO  [PreFlightCheck] Preflight Fail: Compass Sensor missing
    INFO  [PreFlightCheck] Failed barometer preflight check
    INFO  [PreFlightCheck] Preflight fail EKF couldn't get status
    INFO  [PreFlightCheck] Failed EKF health preflight check
    Why it is there and how to solve this issue?
    • Zachary LowellZ Offline
      Zachary Lowell
      @Tamas-Pal-0 said in HITL on VOXL 2 : Preflight fail EKF couldn't get status:
      Hi Tamas - can you please post the entire log from PX4 shell when you run hitl - my biggest inclination is that you have a bad connection or that you are not using the proper flags when you execute px4 in HITL mode.
        Zachary Lowell
        @Tamas-Pal-0 the more I think about this, the more I believe you are running HITL in VIO while the drone is expecting GPS or vice versa, you are running HITL in GPS mode but the drone is in VIO mode.
          Tamas Pal 0
          wrote on last edited by Tamas Pal 0
          I am getting this after running voxl-px4-hitl
          voxl2:/etc/modalai$ voxl-px4-hitl
          Found DSP signature file
          Setting GPS Parameters for HITL
          ______  __   __    ___
          | ___ \ \ \ / /   /   |
          | |_/ /  \ V /   / /| |
          |  __/   /   \  / /_| |
          | |     / /^\ \ \___  |
          \_|     \/   \/     |_/
          px4 starting.
          INFO  [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4-hitl-gps-parameters.config 0
            CBRK_SUPPLY_CHK: curr: 0 -> new: 894281
          ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CBRK_SUPPLY_CHK
            COM_DISARM_PRFLT: curr: 10.0000 -> new: -1.0000
          ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_DISARM_PRFLT
            COM_RC_IN_MODE: curr: 0 -> new: 1
          ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_RC_IN_MODE
            NAV_RCL_ACT: curr: 2 -> new: 0
          ERROR [parameters] Timeout waiting for parameter_client_set_value_response for NAV_RCL_ACT
            EKF2_RNG_AID: curr: 0 -> new: 1
          ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_RNG_AID
          Exiting NOW.
          ______  __   __    ___
          | ___ \ \ \ / /   /   |
          | |_/ /  \ V /   / /| |
          |  __/   /   \  / /_| |
          | |     / /^\ \ \___  |
          \_|     \/   \/     |_/
          px4 starting.
          INFO  [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4-hitl.config 0
          INFO  [muorb] SLPI: Creating qurt thread hpwork
          INFO  [muorb] SLPI: Successfully created px4 task PX4_hpwork with tid 83
          INFO  [muorb] SLPI: Creating qurt thread lpwork
          INFO  [muorb] SLPI: Successfully created px4 task PX4_lpwork with tid 82
          INFO  [muorb] SLPI: Creating qurt thread wkr_hrt
          INFO  [muorb] SLPI: Successfully created px4 task PX4_wkr_hrt with tid 81
          INFO  [muorb] SLPI: Creating qurt thread client_sync_thread
          INFO  [muorb] SLPI: Successfully created px4 task PX4_client_sync_thread with tid 80
          INFO  [muorb] SLPI: Creating qurt thread wq_manager
          INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_manager with tid 79
          INFO  [muorb] SLPI: Creating qurt thread qshell
          INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 78
          INFO  [logger] Start file log (type: full)
          INFO  [logger] [logger] /data/px4/log/sess014/log001.ulg
          INFO  [logger] Opened full log file: /data/px4/log/sess014/log001.ulg
          INFO  [muorb] SLPI: Advertising remote topic mavlink_log
          ERROR [logger] No subscriptions added
          INFO  [muorb] SLPI: Advertising remote topic logger_status
          INFO  [qshell] Send cmd: 'icm42688p start -s -h'
          INFO  [muorb] SLPI: qshell gotten: icm42688p start -s -h
          INFO  [muorb] SLPI: Creating qurt thread wq_SPI1
          INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_SPI1 with tid 77
          INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1 (devid=0x0)
          INFO  [muorb] SLPI:
          INFO  [muorb] SLPI: Ok executing command: icm42688p start -s -h
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 624404183, current timestamp 624404183
          INFO  [uorb] Advertising remote topic qshell_retval
          INFO  [qshell] qshell return value timestamp: 624404183, local time: 624407992
          ERROR [muorb] SLPI: Cannot reset all parameters on client side
          INFO  [uorb] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
          INFO  [uorb] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
          INFO  [uorb] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
          INFO  [dataman] Unknown restart, data manager file '/data/px4/dataman' size is 11798680 bytes
          INFO  [qshell] Send cmd: 'sensors start -h'
          INFO  [muorb] SLPI: qshell gotten: sensors start -h
          INFO  [muorb] SLPI: Creating qurt thread wq_nav_and_controllers
          INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_nav_and_controllers with tid 76
          INFO  [muorb] SLPI: Creating qurt thread wq_rate_ctrl
          INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_rate_ctrl with tid 75
          INFO  [muorb] SLPI: Ok executing command: sensors start -h
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 626707779, current timestamp 626707782
          INFO  [uorb] Advertising remote topic sensors_status_imu
          INFO  [qshell] qshell return value timestamp: 626707779, local time: 626711169
          INFO  [commander] Mission #2 loaded, 13 WPs, curr: 0
          INFO  [commander] LED: open /dev/led0 failed (22)
          INFO  [muorb] SLPI: Advertising remote topic mission
          INFO  [muorb] SLPI: Advertising remote topic led_control
          INFO  [muorb] SLPI: Advertising remote topic tune_control
          INFO  [PreFlightCheck] Failed EKF health preflight check while waiting for filter to settle
          INFO  [muorb] SLPI: Advertising remote topic vehicle_control_mode
          INFO  [muorb] SLPI: Advertising remote topic vehicle_status
          INFO  [muorb] SLPI: Advertising remote topic actuator_armed
          INFO  [muorb] SLPI: Advertising remote topic commander_state
          INFO  [muorb] SLPI: Advertising remote topic vehicle_status_flags
          INFO  [muorb] SLPI: Advertising remote topic vehicle_command
          INFO  [commander] Handling Commander command 176
          INFO  [muorb] SLPI: Advertising remote topic vehicle_command_ack
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 627951004, current timestamp 627951006
          INFO  [qshell] qshell return value timestamp: 627951004, local time: 627952949
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 628024288, current timestamp 628024290
          INFO  [qshell] qshell return value timestamp: 628024288, local time: 628027033
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 628121854, current timestamp 628121856
          INFO  [qshell] qshell return value timestamp: 628121854, local time: 628122930
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 628181880, current timestamp 628181882
          INFO  [qshell] qshell return value timestamp: 628181880, local time: 628183203
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 628293334, current timestamp 628293336
          INFO  [qshell] qshell return value timestamp: 628293334, local time: 628294343
          INFO  [uorb] Advertising remote topic vehicle_land_detected
          INFO  [qshell] Send cmd: 'pwm_out_sim start -m hil'
          INFO  [muorb] SLPI: qshell gotten: pwm_out_sim start -m hil
          INFO  [muorb] SLPI: Creating qurt thread wq_hp_default
          INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_hp_default with tid 74
          INFO  [uorb] Advertising remote topic test_motor
          INFO  [muorb] SLPI: Ok executing command: pwm_out_sim start -m hil
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 629365786, current timestamp 629365788
          INFO  [qshell] qshell return value timestamp: 629365786, local time: 629367822
          INFO  [qshell] Send cmd: 'mixer load /dev/pwm_output0 quad_x.main.mix'
          INFO  [muorb] SLPI: qshell gotten: mixer load /dev/pwm_output0 quad_x.main.mix
          INFO  [muorb] SLPI: Ok executing command: mixer load /dev/pwm_output0 quad_x.main.mix
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 629434024, current timestamp 629434026
          INFO  [qshell] qshell return value timestamp: 629434024, local time: 629436110
          INFO  [muorb] SLPI: Creating qurt thread wq_INS0
          INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_INS0 with tid 4170
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 630732518, current timestamp 630732521
          INFO  [qshell] qshell return value timestamp: 630732518, local time: 630734090
          INFO  [qshell] Send cmd: 'modalai_dsp start -p 2 -b 921600'
          INFO  [muorb] SLPI: qshell gotten: modalai_dsp start -p 2 -b 921600
          INFO  [muorb] SLPI: Creating qurt thread modalai_dsp__main
          INFO  [muorb] SLPI: Successfully created px4 task PX4_modalai_dsp__main with tid 73
          INFO  [muorb] SLPI: Ok executing command: modalai_dsp start -p 2 -b 921600
          INFO  [muorb] SLPI: Sending qshell retval with timestamp 631789844, current timestamp 631789846
          ERROR [muorb] SLPI: Port is open: 0
          INFO  [uorb] Advertising remote topic sensor_accel
          INFO  [uorb] Advertising remote topic sensor_gyro
          INFO  [qshell] qshell return value timestamp: 631789844, local time: 631792366
          INFO  [muorb] SLPI: Got 5 from orb_subscribe
          INFO  [muorb] SLPI: Got 6 from orb_subscribe
          INFO  [muorb] SLPI: Got 7 from orb_subscribe
          INFO  [muorb] SLPI: Got 8 from orb_subscribe
          INFO  [muorb] SLPI: Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
          pxh> INFO  [muorb] SLPI: Advertising remote topic telemetry_status
          INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
          INFO  [muorb] SLPI: Advertising remote topic offboard_control_mode
          INFO  [muorb] SLPI: Advertising remote topic timesync_status
          pxh> INFO  [PreFlightCheck] Failed barometer preflight check
          pxh> coINFO  [PreFlightCheck] Failed barometer preflight check
          pxh> commINFO  [PreFlightCheck] Failed barometer preflight check
          pxh> commanINFO  [PreFlightCheck] Failed barometer preflight check
          pxh> commandeINFO  [PreFlightCheck] Failed barometer preflight check
          pxh> commanderINFO  [PreFlightCheck] Failed barometer preflight check
          pxh> commander INFO  [PreFlightCheck] Failed barometer preflight check
          pxh> commander tINFO  [PreFlightCheck] Failed barometer preflight check
          pxh> commander takINFO  [PreFlightCheck] Failed barometer preflight check
          pxh> commander takeoINFO  [PreFlightCheck] Failed barometer preflight check
          pxh> commander takeoffINFO  [PreFlightCheck] Failed barometer preflight check
          pxh> INFO  [muorb] SLPI: Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
          INFO  [commander] Handling Commander command 22
          ERROR [commander] Takeoff denied! Please disarm and retry
          INFO  [commander] Handling Commander command 400
          INFO  [commander] Arming reason 3
          INFO  [commander] Armed by internal command
          INFO  [commander] Armed state changed. Was 0, now 1
          INFO  [muorb] SLPI: Marking DeviceNode(mavlink_log) as advertised in process_remote_topic
          INFO  [commander] Takeoff detected
          This is the gazebo terminal output
          tamas@tamas:~/Develop/PX4-Autopilot$ gazebo Tools/sitl_gazebo/worlds/hitl_iris.world
          Opened serial device /dev/ttyUSB0
          ../src/intel/isl/isl.c:2220: FINISHME: ../src/intel/isl/isl.c:isl_surf_supports_ccs: CCS for 3D textures is disabled, but a workaround is available.
          It says takeoff detected in the voxl 2 terminal but no response in gazebo simulaor. How to fix this ?
            Zachary Lowell
            Based off the terminal output, looks like you have a good connection between your computer and the voxl2 - Did you ever run the following before running gazebo:
            echo 1 | sudo tee /sys/bus/usb-serial/devices/ttyUSB0/latency_timer
            Tamas Pal 0T 1 Reply Last reply
            • Zachary LowellZ Zachary Lowell
              Tamas Pal 0
              @Zachary-Lowell Yes. I run this before running gazebo :
              The issue is that although the terminal in voxl 2 is showing takeoff detected there is no chnage in gazebo. How to fix this ?
                Tamas Pal 0
                After ruuning all the command like my previous post I opened QGC. It shows flying status but no response in gazebo simulator. I have tried HITL with Jmavsim; here also the simulator not responding. And everytime when I open QGC after running voxl-px4-hitl it some popup comes like like some parameters are missing (SYS_AUTOSTART, SYS_AUTOCONFIG, BAT_V_LOAD_DROP, BAT_SOURCE, SDLOG_MODE). How to get the simulator running ?
                  Zachary Lowell
                  wrote on last edited by Zachary Lowell
                  Those parameters are expected to be missing. Inside the hitl_iris.world file what sdf model are you leveraging? Also I always use PX4 v1.12.3 when running simulation with gazebo and almost never got this issue you are saying above and usually the echo 1 sudo tee line tends to fix that as it relays data as fast as possible. Are you trying to run the voxl2 in VIO or GPS mode for hitl?
                  Also is there a specific baudrate max on your FTDI cable?
                    Tamas Pal 0
                    #9
                    @Zachary-Lowell
                    I am using PX4 v1.13.0 because in PX4 v1.12.3 the Tools/setup_gazebo.bash file is missing.
                    This is the hitl_iris.world file
                    <?xml version="1.0" ?>
                    <sdf version="1.5">
                      <world name="hitl_iris_world">
                        <scene>
                          <ambient>0.7 0.7 0.7 1</ambient>
                          <background>0.7 0.7 0.7 1</background>
                          <shadows>false</shadows>
                        </scene>
                        <gui fullscreen='0'>
                          <camera name='user_camera'>
                            <pose>-12.0 -3.0 10.0 0 0.5 0.2</pose>
                            <view_controller>orbit</view_controller>
                            <projection_type>perspective</projection_type>
                          </camera>
                        </gui>
                        <include>
                          <uri>model://sun</uri>
                        </include>
                        <physics name='default_physics' default='0' type='ode'>
                          <gravity>0 0 -9.8066</gravity>
                          <ode>
                            <solver>
                              <type>quick</type>
                              <iters>10</iters>
                              <sor>1.3</sor>
                              <use_dynamic_moi_rescaling>0</use_dynamic_moi_rescaling>
                            </solver>
                            <constraints>
                              <cfm>0</cfm>
                              <erp>0.2</erp>
                              <contact_max_correcting_vel>100</contact_max_correcting_vel>
                              <contact_surface_layer>0.001</contact_surface_layer>
                            </constraints>
                          </ode>
                          <max_step_size>0.004</max_step_size>
                          <real_time_factor>1</real_time_factor>
                          <real_time_update_rate>250</real_time_update_rate>
                          <magnetic_field>6.0e-6 2.3e-5 -4.2e-5</magnetic_field>
                        </physics>
                        <include>
                          <uri>model://ground_plane</uri>
                        </include>
                        <include>
                          <uri>model://asphalt_plane</uri>
                        </include>
                        <include>
                          <uri>model://iris_hitl</uri>
                          <pose>1.01 0.98 0.83 0 0 1.14</pose>
                        </include>
                      </world>
                    </sdf>
                    I have tried to run this with both gps and vio mode, both having similar issues. The ftdi cable I am using is TTL-232R-3V3. is it fine ?
                      Tamas Pal 0
                      The problem is solved. The problem was in FTDI cable. I changed the cable and it worked
