  3. Unable to access px4 with qgc in voxl 2 using usb-jst cable
15 Posts 4 Posters 2.8k Views 3 Watching
  • Tamas Pal 0T Offline
    Tamas Pal 0
    wrote on last edited by Tamas Pal 0
    I am trying to access px4 with qgc using usb-jst cable using cable no 10 by connecting the jst to J18 port of voxl 2 IMG_20220817_154802.jpg.
    The host pc is not detecting anything. What should be done to solve the issue?
      Hi @Tamas-Pal-0 ,
      On VOXL2 J18 is a UART that connects to the DSP that is used for ESCs --> https://docs.modalai.com/voxl2-connectors/#j18-uart-esc
      At this time, you need to use an IP connection to get to QGC.... Here's some options that I use on my bench:
      https://docs.modalai.com/voxl2-hardware-setup/#wi-fi-connectivity
      https://docs.modalai.com/voxl2-hardware-setup/#ethernet-connectivity
      That cable above works with the STM32 based flight controller (Flight Core and VOXL Flight) but not on J18 of VOXL2.
        Tamas Pal 0
        @MODALTB could you please share a dedicated manual for running hitl with voxl 2 only ?
        https://docs.modalai.com/voxl2-PX4-hitl/
        The docs webpage is a bit confusing
        • Zachary LowellZ Offline
          Zachary Lowell
          Hi Tamas, this video is how to get the voxl2 running with HITL: https://www.youtube.com/watch?v=ysvpJdXFWaM&ab_channel=AscendEngineering
          Also - unless you are running the voxl-dev branch, then you will not be able to do a SERIAL connection from the voxl2 to QGC, you can only leverage a UDP connection. If you are running the voxl-dev branch and flashed the board, then you can leverage the voxl-px4-hitl executable and connect to QGC. However, you cannot have gazebo open simultaneously because the serial connection will then be interrupted.
          If you wish to run HITL while running QGC, then run this using an FTDI cable and then turn on the required services (voxl-vision-px4, voxl-mavlink-server) and then connect to gazebo serially, and QGC via UDP signal.
          Let me know if this makes sense.
            Tamas Pal 0
            I have flashed the voxl-dev branch files to the voxl 2's /etc/modalai/ folder. It seems like voxl-dev branch's voxl-px4-hitl is not an executable file. I am facing this issue.
            voxl2:~$ voxl-px4-hitl
            bash: voxl-px4-hitl: command not found
            How to fix the problem?
            • Tamas Pal 0T Tamas Pal 0
              @Tamas-Pal-0 You can get a voxl-dev branch package from here: http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.4.19-202208111710_arm64.deb. Install that package instead of trying to copy files over manually.
                Tamas Pal 0
                @Eric-Katzfey
                The voxl-px4-hitl is still missing in the package. I have installed it and tried to run voxl-px4-hitl command. It is not working. I have shared the terminal syntax below. How to fix it?
                voxl2:/$ sudo dpkg -i voxl-px4_1.4.19-202208111710_arm64.deb
                (Reading database ... 81777 files and directories currently installed.)
                Preparing to unpack voxl-px4_1.4.19-202208111710_arm64.deb ...
                Unpacking voxl-px4 (1.4.19-202208111710) over (1.4.19-202208111710) ...
                Setting up voxl-px4 (1.4.19-202208111710) ...
                Found DSP signature file
                voxl2:/$ sudo apt-get install -f
                Reading package lists... Done
                Building dependency tree
                0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
                voxl2:/$ voxl-px4-hitl
                bash: /usr/bin/voxl-px4-hitl: Permission denied
                voxl2:/$ sudo voxl-px4-hitl
                sudo: voxl-px4-hitl: command not found
                  Zachary Lowell
                  Hi Tamas - please run a chmod +x /usr/bin/voxl-px4-hitl and that will enable permissions. After running that, you can run voxl-px4-hitl from any directory and it will work.
                  • Zachary LowellZ Zachary Lowell
                    Tamas Pal 0
                    #9
                    @Zachary-Lowell
                    Aftert running the voxl-px4-hitl command I am still gettting an output like this. Is it fine? If not how to solve the problem?
                    voxl2:/usr/bin$ chmod +x /usr/bin/voxl-px4-hitl
                    voxl2:/usr/bin$ voxl-px4-hitl
                    Setting GPS Parameters for HITL
                    INFO  [px4] PX4 daemon already running for instance 0 (Success)
                    voxl2:/usr/bin$
                      @Zachary-Lowell
                      voxl2:/usr/bin$
                      @Tamas-Pal-0 Looks like px4 was already running. It was probably automatically started on system bootup using the systemd service. What is the output from voxl-inspect-services?
                        Tamas Pal 0
                        #11
                        @Eric-Katzfey
                        voxl2:/$ voxl-inspect-services
                         docker-autorun       | Disabled  | Not Running |
                         docker-daemon        | Disabled  | Not Running |
                         modallink-relink     |  Enabled  | Not Running |
                         voxl-camera-server   |  Enabled  | Not Running |
                         voxl-cpu-monitor     |  Enabled  |   Running   |     0.0
                         voxl-dfs-server      |  Enabled  | Not Running |
                         voxl-imu-server      |  Enabled  |   Running   |     0.0
                         voxl-mavlink-server  |  Enabled  |   Running   |     0.0
                         voxl-px4-imu-server  |  Enabled  |   Running   |     0.0
                         voxl-px4             |  Enabled  |   Running   |     0.0
                         voxl-qvio-server     |  Enabled  | Not Running |
                         voxl-softap          | Disabled  | Not Running |
                         voxl-static-ip       |  Enabled  | Not Running |
                         voxl-streamer        |  Enabled  |   Running   |     0.0
                         voxl-tag-detector    |  Enabled  | Not Running |
                         voxl-tflite-server   |  Enabled  |   Running   |     0.0
                         voxl-vision-px4      |  Enabled  |   Running   |     0.0
                        voxl2:/$
                        As mentioned by @Zachary-Lowell the voxl-px4-hitl file is not executable as shown in the youtube video https://www.youtube.com/watch?v=ysvpJdXFWaM&ab_channel=AscendEngineering
                        how to get the voxl-px4-hitl executable file?
                          @Eric-Katzfey
                          voxl2:/$
                          @Tamas-Pal-0 sudo chmod +x /usr/bin/voxl-px4-hitl
                            Tamas Pal 0
                            @Eric-Katzfey The voxl-px4-hitl is still missing. I followed all the steps but the executable file voxl-px4-hitl is still not there
                            voxl2:/$ wget  http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.4.19-202208111710_arm64.deb
                            --2022-08-25 10:05:37--  http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.4.19-202208111710_arm64.deb
                            Resolving voxl-packages.modalai.com (voxl-packages.modalai.com)... 35.215.116.197
                            Connecting to voxl-packages.modalai.com (voxl-packages.modalai.com)|35.215.116.197|:80... connected.
                            HTTP request sent, awaiting response... 200 OK
                            Length: 5093080 (4.9M) [application/octet-stream]
                            Saving to: 'voxl-px4_1.4.19-202208111710_arm64.deb'
                            voxl-px4_1.4.19-202 100%[===================>]   4.86M  1.86MB/s    in 2.6s
                            2022-08-25 10:05:41 (1.86 MB/s) - 'voxl-px4_1.4.19-202208111710_arm64.deb' saved [5093080/5093080]
                            voxl2:/$ dpkg -i voxl-px4_1.4.19-202208111710_arm64.deb
                            voxl2:/$ apt-get install -f
                            voxl2:/$ sudo chmod +x /usr/bin/voxl-px4-hitl
                            voxl2:/$
                            how to fix this ?
                              voxl2:/$
                              how to fix this ?
                              @Tamas-Pal-0 voxl-px4-hitl isn't missing. Your screen shot shows you executing it. But as I said in the earlier response you already have px4 running and when you execute the command it won't allow you to run a second instance of px4.
                                voxl2:/$
                                how to fix this ?
                                @Tamas-Pal-0 In order to prevent px4 from running automatically in the background as a daemon on system startup use systemctl disable voxl-px4 and then sync. Reboot voxl 2 and then try voxl-px4-hitl again.
