    Unable to access px4 with qgc in voxl 2 using usb-jst cable
    1283
    • Tamas Pal 0T
      Tamas Pal 0
      I am trying to access px4 with qgc using usb-jst cable using cable no 10 by connecting the jst to J18 port of voxl 2 IMG_20220817_154802.jpg.
      The host pc is not detecting anything. What should be done to solve the issue?
      • modaltbM
        modaltb ModalAI Team
        Hi @Tamas-Pal-0 ,
        On VOXL2 J18 is a UART that connects to the DSP that is used for ESCs --> https://docs.modalai.com/voxl2-connectors/#j18-uart-esc
        At this time, you need to use an IP connection to get to QGC.... Here's some options that I use on my bench:
        https://docs.modalai.com/voxl2-hardware-setup/#wi-fi-connectivity
        https://docs.modalai.com/voxl2-hardware-setup/#ethernet-connectivity
        That cable above works with the STM32 based flight controller (Flight Core and VOXL Flight) but not on J18 of VOXL2.
        • Tamas Pal 0T
          Tamas Pal 0
          @MODALTB could you please share a dedicated manual for running hitl with voxl 2 only ?
          https://docs.modalai.com/voxl2-PX4-hitl/
          The docs webpage is a bit confusing
          • Zachary LowellZ
            Zachary Lowell ModalAI Team
            Hi Tamas, this video is how to get the voxl2 running with HITL: https://www.youtube.com/watch?v=ysvpJdXFWaM&ab_channel=AscendEngineering
            Also - unless you are running the voxl-dev branch, then you will not be able to do a SERIAL connection from the voxl2 to QGC, you can only leverage a UDP connection. If you are running the voxl-dev branch and flashed the board, then you can leverage the voxl-px4-hitl executable and connect to QGC. However, you cannot have gazebo open simultaneously because the serial connection will then be interrupted.
            If you wish to run HITL while running QGC, then run this using an FTDI cable and then turn on the required services (voxl-vision-px4, voxl-mavlink-server) and then connect to gazebo serially, and QGC via UDP signal.
            Let me know if this makes sense.
            1 Reply Last reply Reply Quote 3
            • Tamas Pal 0T
              Tamas Pal 0
              I have flashed the voxl-dev branch files to the voxl 2's /etc/modalai/ folder. It seems like voxl-dev branch's voxl-px4-hitl is not an executable file. I am facing this issue.
              voxl2:~$ voxl-px4-hitl
              bash: voxl-px4-hitl: command not found
              How to fix the problem?
                Eric Katzfey ModalAI Team @Tamas Pal 0
                @Tamas-Pal-0 You can get a voxl-dev branch package from here: http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.4.19-202208111710_arm64.deb. Install that package instead of trying to copy files over manually.
                Tamas Pal 0T 1 Reply Last reply Reply Quote 0
                • Tamas Pal 0T
                  Tamas Pal 0 @Eric Katzfey
                  The voxl-px4-hitl is still missing in the package. I have installed it and tried to run voxl-px4-hitl command. It is not working. I have shared the terminal syntax below. How to fix it?
                  voxl2:/$ sudo dpkg -i voxl-px4_1.4.19-202208111710_arm64.deb
                  (Reading database ... 81777 files and directories currently installed.)
                  Preparing to unpack voxl-px4_1.4.19-202208111710_arm64.deb ...
                  Unpacking voxl-px4 (1.4.19-202208111710) over (1.4.19-202208111710) ...
                  Setting up voxl-px4 (1.4.19-202208111710) ...
                  Found DSP signature file
                  voxl2:/$ sudo apt-get install -f
                  Reading package lists... Done
                  Building dependency tree
                  0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
                  voxl2:/$ voxl-px4-hitl
                  bash: /usr/bin/voxl-px4-hitl: Permission denied
                  voxl2:/$ sudo voxl-px4-hitl
                  sudo: voxl-px4-hitl: command not found
                  • Zachary LowellZ
                    Hi Tamas - please run a chmod +x /usr/bin/voxl-px4-hitl and that will enable permissions. After running that, you can run voxl-px4-hitl from any directory and it will work.
                    • Tamas Pal 0T
                      Tamas Pal 0 @Zachary Lowell
                      @Zachary-Lowell
                      Aftert running the voxl-px4-hitl command I am still gettting an output like this. Is it fine? If not how to solve the problem?
                      voxl2:/usr/bin$ chmod +x /usr/bin/voxl-px4-hitl
                      voxl2:/usr/bin$ voxl-px4-hitl
                      Setting GPS Parameters for HITL
                      INFO  [px4] PX4 daemon already running for instance 0 (Success)
                      voxl2:/usr/bin$
                        @Tamas-Pal-0 Looks like px4 was already running. It was probably automatically started on system bootup using the systemd service. What is the output from voxl-inspect-services?
                        • Tamas Pal 0T
                           modallink-relink     |  Enabled  | Not Running |
                           voxl-camera-server   |  Enabled  | Not Running |
                           voxl-cpu-monitor     |  Enabled  |   Running   |     0.0
                           voxl-dfs-server      |  Enabled  | Not Running |
                           voxl-imu-server      |  Enabled  |   Running   |     0.0
                           voxl-mavlink-server  |  Enabled  |   Running   |     0.0
                           voxl-portal          |  Enabled  |   Running   |     0.0
                           voxl-px4-imu-server  |  Enabled  |   Running   |     0.0
                           voxl-px4             |  Enabled  |   Running   |     0.0
                           voxl-qvio-server     |  Enabled  | Not Running |
                           voxl-softap          | Disabled  | Not Running |
                           voxl-static-ip       |  Enabled  | Not Running |
                           voxl-streamer        |  Enabled  |   Running   |     0.0
                           voxl-tag-detector    |  Enabled  | Not Running |
                           voxl-tflite-server   |  Enabled  |   Running   |     0.0
                           voxl-vision-px4      |  Enabled  |   Running   |     0.0
                          voxl2:/$
                          As mentioned by @Zachary-Lowell the voxl-px4-hitl file is not executable as shown in the youtube video https://www.youtube.com/watch?v=ysvpJdXFWaM&ab_channel=AscendEngineering
                          how to get the voxl-px4-hitl executable file?
                            @Tamas-Pal-0 sudo chmod +x /usr/bin/voxl-px4-hitl
                            • Tamas Pal 0T
                              @Eric-Katzfey The voxl-px4-hitl is still missing. I followed all the steps but the executable file voxl-px4-hitl is still not there
                              voxl2:/$ wget  http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.4.19-202208111710_arm64.deb
                              --2022-08-25 10:05:37--  http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.4.19-202208111710_arm64.deb
                              Resolving voxl-packages.modalai.com (voxl-packages.modalai.com)... 35.215.116.197
                              Connecting to voxl-packages.modalai.com (voxl-packages.modalai.com)|35.215.116.197|:80... connected.
                              HTTP request sent, awaiting response... 200 OK
                              Length: 5093080 (4.9M) [application/octet-stream]
                              Saving to: 'voxl-px4_1.4.19-202208111710_arm64.deb'
                              voxl-px4_1.4.19-202 100%[===================>]   4.86M  1.86MB/s    in 2.6s
                              2022-08-25 10:05:41 (1.86 MB/s) - 'voxl-px4_1.4.19-202208111710_arm64.deb' saved [5093080/5093080]
                              voxl2:/$ dpkg -i voxl-px4_1.4.19-202208111710_arm64.deb
                              voxl2:/$ apt-get install -f
                              voxl2:/$ sudo chmod +x /usr/bin/voxl-px4-hitl
                              voxl2:/$
                              how to fix this ?
                                @Tamas-Pal-0 voxl-px4-hitl isn't missing. Your screen shot shows you executing it. But as I said in the earlier response you already have px4 running and when you execute the command it won't allow you to run a second instance of px4.
                                  @Tamas-Pal-0 In order to prevent px4 from running automatically in the background as a daemon on system startup use systemctl disable voxl-px4 and then sync. Reboot voxl 2 and then try voxl-px4-hitl again.
