    Mavlink Telemetry Routing, port selection
    • Aldo Castro FreireA
      Aldo Castro Freire
      Hi guys,
      I was wondering if there is a way to select the port we are rerouting the mavlink messages, the documenation only says how to change the ip. or change between udp or tcp ?
      https://docs.modalai.com/voxl-vision-px4-telemetry/
      This part specifically:
      A second manual IP entry can optionally be configured and enabled. Both of these will fields will tell voxl-vision-px4 to continuously forward all mavlink trafic from PX4 to these IP addresses at port 14550 which is the default UDP port for qGroundControl.
      "en_secondary_qgc": false,
      "secondary_qgc_ip": "192.168.1.214",
      • modaltbM
        modaltb ModalAI Team
        Hi @Aldo-Castro-Freire ,
        Not via the config file, but here's where they're defined if you are able to build from source:
        https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-vision-px4/-/blob/v0.6.8/include/udp_mavlink.h#L41
        For TCP, a bit more work likely is needed, but here's the UDP implementation that could be used as a guide:
        https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-vision-px4/-/blob/v0.6.8/src/udp_mavlink.c
        -Travis
          Aldo Castro Freire
          How do I delete my current version voxl-vision-px4 to install this one ?
            Aldo Castro Freire
            One more questions, where should I change in the code to change the port using the config file. Add a new variable called port. This will help me a lot as I have more than 1 drone.
              Aldo Castro Freire
              Actually here: https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-vision-px4/-/blob/master/src/config_file.c
              is parsing and asking for the port, should I just add the variable and change the port as I want ?
              • Chad SweetC
                Chad Sweet ModalAI Team
                Have you tried changing the port number parameter in /etc/modalai/voxl-vision-px4.conf ?
                  Aldo Castro Freire
                  Yes, I tried apparently master and v0.68 of the code are different while in master is not hardcode the udp port. For v0.68 it is hardcode. So I assumed my version is hardcode because nothing seem to change.
                  Do I need to delete my voxl-vision-px4? To install a new custom version?
