    Auto-Exposure Issue with Tracking Camera
    VOXL m500 Reference Drone
    • M
      Michael Hinckley
      Hello, I am experiencing an auto-exposure issue with the tracking camera. The camera constantly flashes between bright and dim frames when it is exposed to sunlight. I recently flashed the drone with the VOXL 3.6.0 system image, but the problem still persists. Additionally, I tried sending the drone a manual gain and exposure, but the flashing continued after voxl-streamer was restarted.
        Hi Michael,
        We're aware of the flickering issue and have fixed it on our dev branch which we're planning to do a full release of in the coming weeks.
        As for the failure to set manual exposure/gain, how are you sending these instructions?
        H 1 Reply Last reply 24 Aug 2022, 05:01 Reply Quote 0
        • M
          Michael Hinckley
          Hi Alex,
          We were using:
          voxl-send-command tracking set_exp_gain <exposure> <gain>
          However, it seems that we were not setting the auto exposure mode to "off" before sending the commands.
          • H
            hmlow @Guest
            @Alex-Gardner
            I'm looking forward to the fix as well.
            Which version will it be released on? Is fix applied to voxl-camera-server or voxl-qvio-server?
            • D
              david.moro
              Hi! It has been almost a year since the last response in this thread. I assume the change made it to the full release. I just flashed a board with SDK 1.0.0 and I see the problem when flying outdoors. Can you confirm this fix got pushed? DM and I can share a link to a video.
              Cheers!
              • M
                Moderator ModalAI Team
                The AE defaults are configured for OV7251. If you are using a different sensor, you'll need to tweak the PI values yourself to achieve your desired setup
                Details here:
                https://docs.modalai.com/voxl-camera-server/#camera-server-config-file
                If there is flicker, you could probably start by turning down the P gain. Here are the relevant parameters
                ae_k_p_ns: the desired p_ns for the exposure algorithm
                ae_k_i_ns: the desired k_i for the exposure algorithm
                ae_max_i: the desired max_i for the exposure algorithm
                D 1 Reply Last reply 25 Jul 2023, 12:42 Reply Quote 0
                • D
                  david.moro @Moderator
                  @Moderator , I am using the standard OV7251 sensor. The Flicker does not happen indoors though. Happy to share a video.
                  Regards,
