  3. Subscribe to voxl_mpa_to_ros topics
ros
5 Posts 2 Posters 2.3k Views
  • Isabella YuI Offline
    Isabella Yu
    wrote on last edited by Isabella Yu
    I'm writing a C++ ros node to do 3D object detection using AiDetectionMsg and the pointcloud generated from the stereo camera. How would I subscribe to the AiDetection topic in my code? I couldn't find the topic name via rostopic list. I tried doing
    #include <voxl_mpa_to_ros/AiDetection.h>
    but running catkin build gives a not found error.
    • ? Offline
      @Isabella-Yu said in Subscribe to voxl_mpa_to_ros topics:
      The topic name for AiDetectionMsgs is tflite_data, and should be published by voxl_mpa_to_ros automatically if voxl-tflite-server is running and publishing to the pipe at /run/mpa/tflite_data.
      For a custom ROS node using the AiDetectionMsg, you will have to manually copy the AiDetection.msg file that lives here and use catkin to generate the associated header file. This tutorial http://wiki.ros.org/ROS/Tutorials/WritingPublisherSubscriber(c++) covers this fairly well, but the main two additions to your CMakeLists will be adding these lines:
      add_message_files(
          DIRECTORY
          msg
          FILES
          AiDetection.msg
      generate_messages()
      Then, when you need to include this message within your project, the syntax is simply:
      #include <project_name/AiDetection.h>
      // where project_name is as whatever you define in your CMakeLists, i.e.
      // project(voxl_mpa_to_ros)
      Isabella YuI 1 Reply Last reply
        Isabella Yu
        Thanks! I'll try this out
        • ? A Former User
          add_message_files(
              DIRECTORY
              msg
              FILES
              AiDetection.msg
          generate_messages()
          Isabella Yu
          @Matt-Turi how would I manually start /run/mpa/tflite_data? I switched to a different m500 and started voxl-tflite-server, but there appears to be no /run/mpa/tflite_data pipe, only the /run/mpa/tflite pipe. The model I'm using is the default MobileNetV2 object detection model for VOXL, and I reset the drone to factory defaults using voxl-configure-tflite
          • ? Offline
            @Isabella-Yu,
            If there is no tflite_data pipe, you may be using a version of voxl-tflite-server that does not have the ai_detection_t added yet. This feature was added in v0.2.0, so make sure you are using the latest available version!
