  3. ESC Calibration issues
29 Posts 2 Posters 8.9k Views 2 Watching
  • modaltbM Offline
    modaltbM Offline
    modaltb
    ESC cal "shouldn't" matter for this (it does set min/max range, but typically bad ESC cal just results in some iffy flights).
    I've seen throttling up occurring if the estimator isn't running. Are you using a magnetometer in the setup?
    PX4 expects an external mag by default, our custom FW is basically to handle this use case for indoor flight without a mag, there's work arounds for this so let me know and I can show you if this is the case.
    Riley DoveR 1 Reply Last reply
    • modaltbM modaltb
      Riley DoveR Offline
      Riley DoveR Offline
      Riley Dove
      @modaltb No magnetometer. I installed the No mag params file, as well as a few others, but I'd like to get your instructions. Mavlink inspector shows it not going above 1075.
      modaltbM 1 Reply Last reply
      • Riley DoveR Riley Dove
        modaltbM Offline
        modaltbM Offline
        modaltb
        @Riley-Dove ,
        On VOXL, what happens if you run systemctl status voxl-vision-px4 ?
        In our 1.10, to fly without mag, the system expects VIO data from VOXL. The FlightDeck should have this setup by default (e.g VOXL is sending VIO data to FlightCore). This is setup via EKF2_AID_MASK which is seems like you loaded, can you check this step to make sure PX4 is getting VIO data? https://docs.modalai.com/flying-with-vio/#confirm-px4-is-getting-vio-data
        In our 1.11, we've reduced the requirement so simply check if EKF2_AID_MASK is configured (and doesn't care if there's actual vision data...)
        • Riley DoveR Offline
          Riley DoveR Offline
          Riley Dove
          This is what I see. I also cannot get to QGC through VOXL.
          ~ # systemctl status voxl-vision-px4
          ● voxl-vision-px4.service - voxl-vision-px4
          Loaded: loaded (/usr/bin/voxl-vision-px4; disabled; vendor preset: enabled)
          Active: failed (Result: signal) since Thu 1970-01-01 00:44:44 UTC; 5min ago
          Process: 3084 ExecStart=/usr/bin/voxl-vision-px4 (code=killed, signal=SEGV)
          Main PID: 3084 (code=killed, signal=SEGV)
          Jan 01 00:44:44 apq8096 voxl-vision-px4[3084]: "en_send_voa_to_qgc": false,
          Jan 01 00:44:44 apq8096 voxl-vision-px4[3084]: "en_mvl_video_stream": false,
          Jan 01 00:44:44 apq8096 voxl-vision-px4[3084]: "en_adsb" false,
          Jan 01 00:44:44 apq8096 voxl-vision-px4[3084]: "adsb_uart_bus": 7,
          Jan 01 00:44:44 apq8096 voxl-vision-px4[3084]: "adsb_uart_baudrate": 57600,
          Jan 01 00:44:44 apq8096 voxl-vision-px4[3084]: "en_offboard_figure_eight": true,
          Jan 01 00:44:44 apq8096 voxl-vision-px4[3084]: "vio_to_ned_rotation_matrix":...]
          Jan 01 00:44:44 apq8096 systemd[1]: voxl-vision-px4.service: Main process e...GV
          Jan 01 00:44:44 apq8096 systemd[1]: voxl-vision-px4.service: Unit entered f...e.
          Jan 01 00:44:44 apq8096 systemd[1]: voxl-vision-px4.service: Failed with re...'.
          Hint: Some lines were ellipsized, use -l to show in full.
          • modaltbM Offline
            modaltbM Offline
            modaltb
            OK without that service running, the QGC link through VOXL won't work, and this would also prevent VIO data making it's way to PX4, and then flying without a mag won't work....
            How about systemctl stop voxl-vision-px4 and then running manually with the debug flag: voxl-vision-px4 -d
            This service is used when we calibrate the cameras before shipping so I'm wondering what's going on.
              Riley DoveR Offline
              Riley Dove
              This is what I typed and what I get.
              ~ # systemctl stop voxl-vision-px4
              ~ # voxl-vision-px4 -d
              loading config file
              Error parsing config file before: en_vao": false,
              "en_send_vio_to_qgc": false,
              "en_adsb" false,
              "adsb_uart_bus": 7,
              "vio_to_ned_rotation_matrix": [[0, 1, 0], [1, 0, 0], [0, 0, -1]]
              Segmentation fault
              • modaltbM Offline
                modaltbM Offline
                modaltb
                Hi @Riley-Dove , I think the config file got messed up. Perhaps around the "offboard_mode" setting.
                This lives at /etc/modalai/voxl-vision-px4.conf
                Here's an example, where the qgc_ip is your system with QGC's IP address:
                	"qgc_ip":	"192.168.8.47",
                	"en_secondary_qgc":	false,
                	"secondary_qgc_ip":	"192.168.1.214",
                	"offboard_mode":	"none",
                	"en_vio":	false,
                	"en_voa":	false,
                	"en_adsb":	false,
                	"adsb_uart_bus":	7,
                	"px4_uart_bus":	5,
                	"px4_uart_baudrate":	921600,
                	"R_imu_to_body":	[[0, 1, 0], [1, 0, 0], [0, 0, -1]],
                	"T_imu_wrt_body":	[0.068, -0.015, -0.008],
                	"height_body_above_ground_m": 0.05,
                	"T_stereo_wrt_body":	[0.10, -0.04, 0.0],
                	"land_on_tag_id":	0,
                	"follow_tag_id":	0,
                	"en_apriltag_fixed_frame":	false,
                	"fixed_apriltags":	[{
                		"tag_id":	0,
                		"R_tag_to_fixed":	[[0, -1, 0], [1, 0, 0], [0, 0, 1]],
                		"T_tag_wrt_fixed":	[0, 0, 0]
                	"en_transform_mavlink_pos_setpoints_from_fixed_frame":	true,
                	"en_fixed_frame_pipe": false,
                	"fixed_frame_filter_len": 5
                • modaltbM Offline
                  modaltbM Offline
                  modaltb
                  Also, if you didn't modify this file and this is how it shipped let me know so I can look into what happened. We enable VOA during flight testing and then disable so if there's a typo introduced causing this issue I want to inform the team over here. Thanks!
                    Riley DoveR Offline
                    Riley Dove
                    Now it says only "error parsing config file before: ?
                    Segmentation fault"
                    • modaltbM modaltb
                      Riley DoveR Offline
                      Riley DoveR Offline
                      Riley Dove
                      @modaltb I may have modified it, not even sure. I'm still learning the hardcore software side of this. I'm a hardware guy.
                      • modaltbM Offline
                        modaltbM Offline
                        modaltb
                        @Riley-Dove ok, we can reset it to factory defaults, maybe that's easiest! If you can delete that file /etc/modalai/voxl-vision-px4.conf and then run the following command: voxl-configure-vision-px4 -f it will set the factory settings.
                        Restart the service:
                        systemctl restart voxl-vision-px4
                        Check status:
                        If all looks good, you can set your IP back up:
                        vi /etc/modalai/voxl-vision-px4.conf
                        vi isn't easy to use. But this should get you going:
                        • hit 'i' to enter edit mode
                        • move cursor to text using arrows, edit the ip address following the same format that's there
                        • hit 'esc' to exit edit mode
                        • to save, enter :wq
                        Check status:
                        Then you should have a connection to QGC.
                          Riley DoveR Offline
                          Riley Dove
                          I run into the same issue when I check the voxl vision status. Active: Failed. There is nothing on the voxl-vision-px4.conf file. It's not properly configuring that file.
                          • modaltbM Offline
                            modaltbM Offline
                            modaltb
                            Hi @Riley-Dove ,
                            Sorry, something is happening when editing maybe... This setup is heavily used all over so trying to see what up, we can do a screen share if the following fails.
                            What if you do the following, without editing the file at all.
                            • systemctl stop voxl-vision-px4
                            • voxl-configure-vision-px4 -f
                            • cat /etc/modalai/voxl-vision-px4.conf
                            Can you then copy paste the output of the last command here?
                            Then if the JSON output looks OK above, try to start again... systemctl start voxl-vision-px4.
                            This is where I'm getting the file.
                              Riley DoveR Offline
                              Riley Dove
                              Looks like that worked.
                              ~ # voxl-configure-vision-px4 -f
                              loading and updating config file with voxl-vision-px4 -c
                              /usr/bin/voxl-configure-vision-px4: line 120: 3072 Segmentation fault voxl-vision-px4 -c
                              ^ don't worry about the segfault ^
                              attempting to use camera configuration 3
                              adding override_cam_id value=1 to /etc/snav/camera.downward.xml
                              adding override_cam_id value=2 to /etc/snav/camera.stereo.xml
                              reloading systemd services
                              disabling all the snav services
                              starting imu_app
                              Created symlink from /etc/systemd/system/multi-user.target.wants/imu_app.service to /etc/systemd/system/imu_app.service.
                              WARNING: Missing stereo calibration file. Follow instructions here to
                              calibrate if you wish to use stereo visual obstacle avoidance.
                              https://docs.modalai.com/docs/quickstarts/calibrate-cameras/
                              DONE configuring ModalAI Vision Lib
                              enabling voxl-vision-px4 systemd service
                              Created symlink from /etc/systemd/system/multi-user.target.wants/voxl-vision-px4.service to /etc/systemd/system/voxl-vision-px4.service.
                              starting voxl-vision-px4 systemd service
                              DONE configuring voxl-vision-px4
                              ~ # cat /etc/modalai/voxl-vision-px4.conf
                              "qgc_ip": "192.168.8.60",
                              "offboard_mode": "figure_eight",
                              "en_vio": true,
                              "en_voa": false,
                              "en_adsb": false,
                              "adsb_uart_bus": 7,
                              "px4_uart_bus": 5,
                              "follow_tag_id": 0,
                              "tag_id": 0,
                              I edited the QGC IP to my laptop's IP and QGC still doesnt see it. I will try from a different computer.
                                Riley DoveR Offline
                                Riley Dove
                                wrote on last edited by Riley Dove
                                #22
                                No luck on different computer. I just tried the ESC cal as well and no luck.
                                • modaltbM Offline
                                  modaltbM Offline
                                  modaltb
                                  What kind of computer are you using, Linux, Windows?
                                  If Windows, you likely need to configure the firewall (maybe easier to just disable the windows firewall for this test).
                                  You can use the USB connection straight to the blue connector to get a connection to QGC.
                                  But, if you have QGC running, the ESC calibration tool won't work because QGC will have taken ownership of the port.
                                    Riley DoveR Offline
                                    Riley Dove
                                    I've been testing on a Macbook Pro. I can get QGC via the USB port, just not via Wifi. And the motors dont spin above minimum armed PWM.
                                    • modaltbM Offline
                                      modaltbM Offline
                                      modaltb
                                      I just went through similar yesterday on a new board we're developing. PX4 is configured to expect a magnetometer, you'll want to set the sys_has_mag param to 0, and GPS_1_CONFIG to off/none via the QGC.
                                      I can get on a screen share after a bit if needed so just let me know if you want to wait till then.
                                        Riley DoveR Offline
                                        Riley Dove
                                        I just did another test randomly while eating my lunch and it worked as expected. So I did a maiden and checked stabilize, althold, and position mode and all modes flew well. We have lots of snow here so cant test too much more outdoors.
                                        • modaltbM Offline
                                          modaltbM Offline
                                          modaltb
                                          OK great!! Please holler if you hit any other snags.
