    ESC Calibration issues
    29 Posts 2 Posters 7.2k Views 2 Watching
    • Riley DoveR Offline
      Riley Dove
      After following the wiki for ESC calibration, once I type Y for all of the prompts and it should run, I get an immediate error. I'm able to connect via QGC. QGC is closed out and it is able to access the port. Errors are
      line 269 in <module>
      mavcall()
      line 246 in mavcal
      if not mavshell.connect()
      line 74, in connect
      ret = selv.mav.wait_heartbeat(blocking=true, timeout=10)
      TypeError: wait_heartbeat() got an unexpected keyword argument 'timeout'
      Any ideas? From what I think I'm seeing is that there was a timeout in the connection maybe?
      • modaltbM Offline
        modaltb ModalAI Team
        Hi @Riley-Dove ,
        Do you what FW version you are using? I’ve seen some inconsistencies on v1.11. We’ll take a look, they work around we are using isn’t ideal so perhaps there’s some improvements we can make.
        Riley DoveR 1 Reply Last reply Reply Quote 0
          Riley Dove
          I just had a BEC failure, so I cant access the FC,. Will swap and let you know. I believe I updated to 1.11 via QGC.
            Riley Dove @modaltb
            @modaltb I have V1.11.3 loaded onto the Flight deck board.
            • modaltbM Offline
              Hi @Riley-Dove ,
              Ok thanks. Let me get someone to check into this this AM.
              We use the tool a lot with our production release of 1.10, https://docs.modalai.com/flight-core-firmware/#px4-v110
              We haven’t moved to 1.11 in production on our side so the tools might need an update.
              A work around should be to go back to the release in the link above, but ideally we get the tool working with 1.11.
              I’ll keep you posted.
              Travis
                Riley Dove
                I just reverted back to the ModalAI version of V1.10 and still having the same issues. It must be somehow related to my system.
                  Riley Dove
                  In the end goal, When I arm the copter, the motors stay at the ESC armed throttle level, despite seeing throttle input from the RC. Once I get this resolved, should it work, or are they unrelated?
                  • modaltbM Offline
                    ESC cal "shouldn't" matter for this (it does set min/max range, but typically bad ESC cal just results in some iffy flights).
                    I've seen throttling up occurring if the estimator isn't running. Are you using a magnetometer in the setup?
                    PX4 expects an external mag by default, our custom FW is basically to handle this use case for indoor flight without a mag, there's work arounds for this so let me know and I can show you if this is the case.
                      Riley Dove @modaltb
                      @modaltb No magnetometer. I installed the No mag params file, as well as a few others, but I'd like to get your instructions. Mavlink inspector shows it not going above 1075.
                      • modaltbM Offline
                        modaltb ModalAI Team @Riley Dove
                        @Riley-Dove ,
                        On VOXL, what happens if you run systemctl status voxl-vision-px4 ?
                        In our 1.10, to fly without mag, the system expects VIO data from VOXL. The FlightDeck should have this setup by default (e.g VOXL is sending VIO data to FlightCore). This is setup via EKF2_AID_MASK which is seems like you loaded, can you check this step to make sure PX4 is getting VIO data? https://docs.modalai.com/flying-with-vio/#confirm-px4-is-getting-vio-data
                        In our 1.11, we've reduced the requirement so simply check if EKF2_AID_MASK is configured (and doesn't care if there's actual vision data...)
                          Riley Dove
                          This is what I see. I also cannot get to QGC through VOXL.
                          ~ # systemctl status voxl-vision-px4
                          ● voxl-vision-px4.service - voxl-vision-px4
                          Loaded: loaded (/usr/bin/voxl-vision-px4; disabled; vendor preset: enabled)
                          Active: failed (Result: signal) since Thu 1970-01-01 00:44:44 UTC; 5min ago
                          Process: 3084 ExecStart=/usr/bin/voxl-vision-px4 (code=killed, signal=SEGV)
                          Main PID: 3084 (code=killed, signal=SEGV)
                          Jan 01 00:44:44 apq8096 voxl-vision-px4[3084]: "en_send_voa_to_qgc": false,
                          Jan 01 00:44:44 apq8096 voxl-vision-px4[3084]: "en_mvl_video_stream": false,
                          Jan 01 00:44:44 apq8096 voxl-vision-px4[3084]: "en_adsb" false,
                          Jan 01 00:44:44 apq8096 voxl-vision-px4[3084]: "adsb_uart_bus": 7,
                          Jan 01 00:44:44 apq8096 voxl-vision-px4[3084]: "adsb_uart_baudrate": 57600,
                          Jan 01 00:44:44 apq8096 voxl-vision-px4[3084]: "en_offboard_figure_eight": true,
                          Jan 01 00:44:44 apq8096 voxl-vision-px4[3084]: "vio_to_ned_rotation_matrix":...]
                          Jan 01 00:44:44 apq8096 systemd[1]: voxl-vision-px4.service: Main process e...GV
                          Jan 01 00:44:44 apq8096 systemd[1]: voxl-vision-px4.service: Unit entered f...e.
                          Jan 01 00:44:44 apq8096 systemd[1]: voxl-vision-px4.service: Failed with re...'.
                          Hint: Some lines were ellipsized, use -l to show in full.
                          • modaltbM Offline
                            OK without that service running, the QGC link through VOXL won't work, and this would also prevent VIO data making it's way to PX4, and then flying without a mag won't work....
                            How about systemctl stop voxl-vision-px4 and then running manually with the debug flag: voxl-vision-px4 -d
                            This service is used when we calibrate the cameras before shipping so I'm wondering what's going on.
                              Riley Dove
                              This is what I typed and what I get.
                              ~ # systemctl stop voxl-vision-px4
                              ~ # voxl-vision-px4 -d
                              loading config file
                              Error parsing config file before: en_vao": false,
                              "en_send_vio_to_qgc": false,
                              "en_adsb" false,
                              "adsb_uart_bus": 7,
                              "vio_to_ned_rotation_matrix": [[0, 1, 0], [1, 0, 0], [0, 0, -1]]
                              Segmentation fault
                              • modaltbM Offline
                                Hi @Riley-Dove , I think the config file got messed up. Perhaps around the "offboard_mode" setting.
                                This lives at /etc/modalai/voxl-vision-px4.conf
                                Here's an example, where the qgc_ip is your system with QGC's IP address:
                                	"qgc_ip":	"192.168.8.47",
                                	"en_secondary_qgc":	false,
                                	"secondary_qgc_ip":	"192.168.1.214",
                                	"offboard_mode":	"none",
                                	"en_vio":	false,
                                	"en_voa":	false,
                                	"en_adsb":	false,
                                	"adsb_uart_bus":	7,
                                	"px4_uart_bus":	5,
                                	"px4_uart_baudrate":	921600,
                                	"R_imu_to_body":	[[0, 1, 0], [1, 0, 0], [0, 0, -1]],
                                	"T_imu_wrt_body":	[0.068, -0.015, -0.008],
                                	"height_body_above_ground_m": 0.05,
                                	"T_stereo_wrt_body":	[0.10, -0.04, 0.0],
                                	"land_on_tag_id":	0,
                                	"follow_tag_id":	0,
                                	"en_apriltag_fixed_frame":	false,
                                	"fixed_apriltags":	[{
                                		"tag_id":	0,
                                		"R_tag_to_fixed":	[[0, -1, 0], [1, 0, 0], [0, 0, 1]],
                                		"T_tag_wrt_fixed":	[0, 0, 0]
                                	"en_transform_mavlink_pos_setpoints_from_fixed_frame":	true,
                                	"en_fixed_frame_pipe": false,
                                	"fixed_frame_filter_len": 5
                                • modaltbM Offline
                                  Also, if you didn't modify this file and this is how it shipped let me know so I can look into what happened. We enable VOA during flight testing and then disable so if there's a typo introduced causing this issue I want to inform the team over here. Thanks!
                                    Riley Dove
                                    Now it says only "error parsing config file before: ?
                                    Segmentation fault"
                                      Riley Dove @modaltb
                                      @modaltb I may have modified it, not even sure. I'm still learning the hardcore software side of this. I'm a hardware guy.
                                      • modaltbM Offline
                                        @Riley-Dove ok, we can reset it to factory defaults, maybe that's easiest! If you can delete that file /etc/modalai/voxl-vision-px4.conf and then run the following command: voxl-configure-vision-px4 -f it will set the factory settings.
                                        Restart the service:
                                        systemctl restart voxl-vision-px4
                                        Check status:
                                        If all looks good, you can set your IP back up:
                                        vi /etc/modalai/voxl-vision-px4.conf
                                        vi isn't easy to use. But this should get you going:
                                        • hit 'i' to enter edit mode
                                        • move cursor to text using arrows, edit the ip address following the same format that's there
                                        • hit 'esc' to exit edit mode
                                        • to save, enter :wq
                                        Check status:
                                        Then you should have a connection to QGC.
                                          Riley Dove
                                          I run into the same issue when I check the voxl vision status. Active: Failed. There is nothing on the voxl-vision-px4.conf file. It's not properly configuring that file.
                                          • modaltbM Offline
                                            Hi @Riley-Dove ,
                                            Sorry, something is happening when editing maybe... This setup is heavily used all over so trying to see what up, we can do a screen share if the following fails.
                                            What if you do the following, without editing the file at all.
                                            • systemctl stop voxl-vision-px4
                                            • voxl-configure-vision-px4 -f
                                            • cat /etc/modalai/voxl-vision-px4.conf
                                            Can you then copy paste the output of the last command here?
                                            Then if the JSON output looks OK above, try to start again... systemctl start voxl-vision-px4.
                                            This is where I'm getting the file.
