    RB5 motor does not spin even after successful arm
    Qualcomm Flight RB5 5G Drone
    1832
    • S
      sesajap
      ARM successfully but four motors do not spin. Was spinning yesterday.
      QGC->Vehicle Setup->Motors, slide to enable motor slider, then slide ALL motors to some level, expect motor spin under test mode but no motor spin.
      How to restore vehicle parameters back to factory default?
      What's the right sequence to load which files under https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/tree/master/platforms/v1.12/RB5_Flight and https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/tree/master/helpers/rb5
      Thank you!
      • modaltbM
        modaltb ModalAI Team
        Hi @sesajap
        You need to use command line instead of QGC for motor spin testing with this setup, checkout the video starting here: https://www.youtube.com/watch?v=4cXsuSaW-3k&t=66s
        • S
          sesajap
          Does the example of communicating ESC over UART in the video ( https://www.youtube.com/watch?v=4cXsuSaW-3k&t=66s ) require some sort of UART adapter?
          Any other way to isolate the no-motor-spin when armed issue?
          Previously, the same RB5 was spinning motors when armed right before setting
          • rb5-qvio-server-configure to yes
          • rb5-voa-server-configure to yes
          However, since then we have set both qvio and voa back to disabled, then reboot RB5, still have this no-motor-spin issue.
          • S
            sesajap
            May not be related. Does each unit of RB5 store a copy of its unique factory calibration data (such as compass, etc.) on its file system so that we can always restore such factory parameters? If so, where is path of such data?
            • S
              sesajap
              QGC does have warning messages:
              MAG #0 failed: TIMEOUT!
              • S
                sesajap
                After rebooting RB5, MAG #0 error msg is gone.
                Still no motor spin after a successful ARM.
                Another question is on vehicle setup, which sub-type should be selected for RB5? Generic Quadcopter?
                • S
                  sesajap
                  On MAVLink Console, type
                  modalai_esc
                  no response from vehicle's system shell.
                  Is this normal?
                  • modaltbM
                    Hi @sesajap ,
                    The MAVLink shell through QGC isn't functional at this time on rb5 flight, so yes at this point it's expected.
                    Are the blue LEDs on the ESC flashing? When they are talking with the flight controller they are flashing.
                    Here's information on how to load parameters:
                    https://docs.qgroundcontrol.com/master/en/SetupView/Parameters.html
                    I'd recommend using the params from our production team:
                    https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/platforms/v1.12/RB5_Flight/RB5_Flight_V1_param_rev_A.params
                    Note: the UART esc is enabled via this params:
                    https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/platforms/v1.12/RB5_Flight/RB5_Flight_V1_param_rev_A.params#L64
                    So you could quickly check right now if those ESC params are correct, if not that might be it.
                    How are you powering the vehicle?
                    • S
                      sesajap
                      Hi @modaltb
                      The vehicle was powered via benchtop/AC adapter. We have tried 4S battery as well now. Still no-motor-spin when ARM even when vehicle is battery powered. Under either powering method, the blue LEDs on the ESC always flashing.
                      There is a failure when loading https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/platforms/v1.12/RB5_Flight/RB5_Flight_V1_param_rev_A.params
                      The error message is
                      Parameters are missing from firmware. You may be running a version of firmware which is not fully supported or your firmware has a bug in it. Missing params: 1:DSHOT_TEL_CFG
                      Looks like DSHOT_TEL_CFG does not exist on the vehicle. How do we create this missing parameter? Does this parameter have anything to do with motor spin?
                      RB5 firmware info:
                      rb5-flight-versions
                      SDK version:
                      rb5-flight-sdk: [trusted=yes]
                      PX4 versions:
                      modalai-slpi: 1.0-6
                      px4-rb5-fligh: 1.4-6
                      px4-support: 1.0-4
                      libfc-sensor: 1.0-2
                      System Image:
                      1.0.5-M0052-9.1-perf
                      • S
                        sesajap
                        Hi @modaltb
                        When vehicle is armed, there is another message showing on the QGC. The message is
                        Failsafe mode activated
                        Then there is no motor spin.
                        When going to QGC->Vehicle Setup->Safety, another message shows "Missing params: 1:SDLOG_MODE"
                        • S
                          sesajap
                          Hi @modaltb
                          https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/platforms/v1.12/RB5_Flight/RB5_Flight_V1_param_rev_A.params has
                          Motors/ESCs
                          disable dshot, use uart instead
                          1 1 DSHOT_CONFIG 0 6
                          1 1 DSHOT_TEL_CFG 0 6
                          Looks like DSHOT_TEL_CFG is related to Motors. So missing that from PX4 probably relate to the no-motor-spin issue here.
                          How do we add this PX4 param? How could this parameter be missing?
                          • Adrian HidalgoA
                            Adrian Hidalgo ModalAI Team
                            Can you double check that the cable going from the esc to the RB5 is still plugged in? If this cable is unplugged the motors won't spin but QGC will say it's armed.
                            Another note is that the RB5 only gets the helper files from the px4 parameters.
                            In RB5, the helper files, load the indoor or outdoor depending where you are flying and the Spektrum dx6e if that is the transmitter you're using.
                            If the platform files were loaded you may have to flash the system image to restart the drone.
                            • S
                              sesajap
                              @Adrian-Hidalgo
                              thank you for your notes.
                              Double check the cable from RB5 to ESC per https://docs.modalai.com/images/rb5/rb5-labeled-3.png . The cable is plugged on both ends.
                              Yes, dx6e is the transmitter. Did load indoor helper (https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/helpers/rb5/ekf2_indoor_vio.params) and dx6e helper (https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/helpers/rb5/spektrum_dx6e_config.params).
                              Also did load single platform file (https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/platforms/v1.12/RB5_Flight/RB5_Flight_V1_param_rev_A.params).
                              After load above three files, we power cycle RB5 and still no motor spin on ARM.
                              Question is why we need to flash system image after loading platform file? Is this a routine thing we need to do with any platform file loading? Or we flash system image for troubleshooting purpose?
                              Any method (such as wavros?) to create the missing DSHOT_TEL_CFG ? Why would reflash system image create such missing parameter?
                              Adrian HidalgoA 1 Reply Last reply Reply Quote 0
                              • Adrian HidalgoA
                                Adrian Hidalgo ModalAI Team @sesajap
                                @sesajap perfect. Was anything changed from when the drone armed and the motors spun to the next day?
                                The RB5 platform px4 params are there mostly for reference in case other params were changed. Since they are just a reference they contain some params that will cause some interference with the flight/arming.
                                Since they were loaded, the only way to wipe those params would be to factory flash it and only load the helper files regarding the RB5.
                                Flashing the system image when loading the platform file is not a routine procedure. However, it is necessary in this case for trouble shooting.
                                • S
                                  sesajap
                                  @Adrian-Hidalgo
                                  Thank you for your patient!
                                  Recall the changes between spin and no-more-spin is active VIO and VOA services while indoor. Then disable both VIO and VOA service, but motor no longer spin after reboot.
                                  Finally found a solution without flashing the system image:
                                  Step 1: load https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/helpers/rb5/ekf2_outdoor_gps_mag.params
                                  Step 2: set vehicle param COM_ARM_WO_GPS to 1
                                  Step 3: power cycle RB5
                                  Now arm RB5 after it comes back online, motor spins. -:)
                                  Hope this helps anyone else running into same issue.
