  2. VOXL Compute & Autopilot
  3. VOXL Flight
  4. How to enable BLSP9 for SPI usage over J7?
Scheduled Pinned Locked Moved VOXL Flight
3 Posts 2 Posters 578 Views 1 Watching
  • J Offline
    J Offline
    jrestifo
    I have modified apq8096-imu-server to add another IMU, which is going to be connected to J7, using SPI (BLSP9). However, when I try and talk to this device in my code, I can see on my scope no activity. Is there something additional I need to do?
    I've modified:
    common/voxl_imu_server.h - updated N_IMUS, added my IMU as IMU4
    server/src/imu_interface.c - Added my IMU to imu_ic_t , added it to switch statements, etc
    server/src/config_file.c - added IMU4 config entries
    And of course implemented my code as per the existing IMUs. I am passing it as bus 9, as I believe this is supposed to map to BLSP9. But I cannot see anything being clocked, chip selects changing, etc...
    • Alex KushleyevA Offline
      Hello @jrestifo,
      apq8096-imu-server (formerly voxl-imu-server) already had support for SPI imu on J7 (SPI9). That is IMU2 (where IMU0 and IMU1 are IMUs on VOXL itself). I plugged in MPU9250 into J7 via SPI, see below output:
      / # voxl-imu-server -b -i 2
      enabling basic read instead of FIFO
      Forcing imu2 on
      loading calibration file
      loading config file
      imu0_enable:                     1
      imu0_bus:                        10
      imu0_sample_rate_hz:             1000.0
      imu0_lp_cutoff_freq_hz:          92.0
      imu0_rotate_common_frame         1
      imu0_read_every_n_samples:       10
      imu1_enable:                     1
      imu1_bus:                        1
      imu1_sample_rate_hz:             1000.0
      imu1_lp_cutoff_freq_hz:          92.0
      imu1_rotate_common_frame         1
      imu1_read_every_n_samples:       10
      aux_imu2_enable:                 0
      aux_imu2_spi_bus:                9
      aux_imu2_sample_rate_hz:         1000.0
      aux_imu2_lp_cutoff_freq_hz:      92.0
      aux_imu2_read_every_n_samples:   10
      aux_imu2_enable:                 0
      aux_imu2_spi_bus:                11
      Initializing IMU0
      detected ICM42688 on spi bus[id] 10
      using ODR=1000.00hz which is the nearest the icm42688 can get to 1000.0
      Initializing IMU1
      detected ICM20948 on spi bus[id] 1
      using ODR=1125.00hz which is the nearest the icm20948 can get to 1000.0
      Initializing IMU2
      detected MPU9250 on spi bus[id] 9
      using ODR=1000.00hz which is the nearest the mpu9250 can get to 1000.0
      By the way, it looks like aux_imu2_* is mentioned twice in the config file printout, it is a bug..
      to print out raw imu data...
      voxl-imu-server -b -i 2 -p | grep imu2
      Please try it out..
      J 1 Reply Last reply
        Hello @jrestifo,
        Forcing imu2 on
        loading config file
        imu0_enable:                     1
        imu0_bus:                        10
        imu1_enable:                     1
        imu1_bus:                        1
        aux_imu2_enable:                 0
        aux_imu2_spi_bus:                9
        aux_imu2_enable:                 0
        Initializing IMU0
        Initializing IMU1
        Initializing IMU2
        Please try it out..
        J Offline
        J Offline
        jrestifo
        wrote on last edited by jrestifo
        So I have a BMI088 plugged in there, so I was adding IMU4 to not lose support for MPU as well. However, I did as you suggest as a sanity check, and yes I can see it trying to clock. I must have a problem somewhere else, thank you this was very helpful.
