QVIO not working
 Hi, Unfortunately we can't get QVIO to work, voxl-inspect-qvio gives 0 position values and jumps between OKAY and FAIL.
 Additionally, after we reset the drone by flashing the factory image we no longer see the "Pointclouds" tab in the portal. How do we enable this again?
 I would appreciate any tips on how to solve this.
 It is likely you need to configure the system after reflash. See voxl-configure-mpa
 Thanks for the hint, qvio is now showing correct positions.
 However, pointcloud is still not available in the portal, how to enable that again?
 The pointcloud functionality in voxl-portal is only available through the dev repo right now. To upgrade your current installation, you can run: voxl-configure-opkg devto point opkg towards our dev repository, and upgrade using: opkg upgrade voxl-portal
 Thanks, I had to upgrade other packages as well due to dependency constraints. I wasn't able to resolve all of them cleanly because it looks like opencv and voxl-opencv are both required by different packages. Unfortunately now the flight control interface seems to be broken, reporting: Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_cleanup_old, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_insert_pc, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_cleanup_old, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_cleanup_old, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_insert_pc, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_insert_pc, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_cleanup_old, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_cleanup_old, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_insert_pc, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_cleanup_old, ringbuf uninitializedBut at least pointclouds are showing now.
 Additionally, I am unable to view the pointcloud in RViz
 It connects and can show images but not spatial data:No tf data. Actual error: Fixed Frame [map] does not existMaybe there is a misconfiguration of ros on the seeker?
