    How to edit full-m0052.config file?
    Qualcomm Flight RB5 5G Drone
    1228
    • D
      Djalma Ribeiro
      What do I need to do to edit the /etc/modalai/full-m0052.config file?
      I have an RB5 here, I made the settings for it to connect to our wifi network (it is connected) but I am not able to connect through the QGC. Simply nothing happens, both on pc and mobile.
      I have already disabled the firewall but it had no effect.
      • D
        Djalma Ribeiro
        Is this the contents of the file? Is correct?
        #!/bin/sh
        # PX4 commands need the 'px4-' prefix in bash.
        # (px4-alias.sh is expected to be in the PATH)
        . px4-alias.sh
        uorb start
        muorb start
        # Sleep a little here. A lot happens when the uorb and muorb start
        # and we need to make sure that it all completes successfully to avoid
        # any possible race conditions.
        sleep 1
        # IMU (accelerometer / gyroscope)
        # Start this first because it gets the high rate interrupts coming in to the
        # DSP. Without this the DSP will oversleep and miss critical timeouts.
        # TODO: Why is that the case?
        qshell icm42688p start -s
        sleep 1
        # Load in all of the parameters that have been saved in the file
        param load
          tom admin
          @Djalma-Ribeiro Can you share what version of software you're running with rb5-flight-versions?
          D 2 Replies Last reply Reply Quote 0
            tom admin
            @Djalma-Ribeiro And have you modified rb5-net-check to reflect your network's configuration:
            https://docs.modalai.com/Qualcomm-Flight-RB5-user-guide-px4/#system-bootup-behavior
            • D
              Djalma Ribeiro
              @tom said in How to edit full-m0052.config file?:
              rb5-flight-versions
              Oh my gosh! I went to check the contents of the file and to my surprise it is not as described in the documentation!
              [Unit]
              Description=rb5-net-check
              After=sscrpcd.service
              Requires=sscrpcd.service
              [Service]
              Type=oneshot
              ExecStart=/usr/bin/rb5-net-check wlan0 10.188
              RemainAfterExit=yes
              [Install]
              WantedBy=multi-user.target
              I changed it to 192,168 and now it connected!
              • D
                Djalma Ribeiro @tom
                I was unable to run this command.
                • D
                  Djalma Ribeiro @tom
                  @tom Firmware version 1.2.2alpha from QGC.
                    tom admin
                    @Djalma-Ribeiro Glad to hear you got it going!
                    rb5-flight-versions must not be included in the version of software you're on, all good
                      tom admin
                      @Djalma-Ribeiro Could you do an ls /home on your RB5 so I can see which software version is installed?
                      • D
                        Djalma Ribeiro @tom
                        linaro           rb5-flight-sdk-1.0.5  testsig-util-0.2.tar.gz
                        mavlink-routerd  rb5-flight-sdk-1.1.3
                        rb5-flight-sdk-1.1.3 = I uploaded the folder yesterday but didn't update.
                        It's very old? do i need to update?
                          tom admin
                          @Djalma-Ribeiro Awesome thank you, just wanted to make sure your RB5 had the SDK loaded properly, which it does.
                          It's not absolutely necessary to upgrade the SDK, if you do want to you can follow the steps here: https://docs.modalai.com/Qualcomm-Flight-RB5-sdk-installation/#how-to-upgrade
                          One note, if you try to upgrade the SDK while PX4 is running it will fail. So in order to upgrade the SDK you would have to disable PX4 from starting systemctl disable rb5-px4-start and then reboot your drone before upgrading your SDK.
