    GPS not acquiring
    1055
    • Daniel RyuD
      Daniel Ryu
      Using the m500 ModalAI drone, and I cannot run "mission mode" from QGC because the GPS cannot acquire. As far as I am aware and could find, the PIXhawk 4 GPS module should acquire automatically as long as it is plugged into the Flight core. However, throughout my three hours of testing, the GPS could not acquire, with the corresponding LED light blinking blue (https://docs.px4.io/master/en/getting_started/led_meanings.html)
      I tried unplugging/replugging GPS, resetting drone and QGC, and even sending MAVLink messages to reset the GPS (both cold and hot).
      How can I get the GPS to acquire?
      • modaltbM
        modaltb ModalAI Team
        Hi @Daniel-Ryu ,
        Yes you are correct it should find the satellites after power up (within a minute or two...).
        So this is strange. Are you inside or outside? Inside our office, we have a hard time getting signal occasionally.
        Next, can you validate the GPS_1_CONFIG is default ('GPS1')?
        Here's what I see with the same setup on my end as a reference:
        • Daniel RyuD
          Daniel Ryu
          @modaltb,
          This was when I was testing outside. I will check the value of GPS_1_CONFIG and get back to you.
          Thanks for the swift response.
          • Daniel RyuD
            Daniel Ryu
            @modaltb
            gps_1_config is set to GPS1.
            I will be checking for these errors next. Please advise if there is anything else I should confirm/check
            https://docs.px4.io/v1.9.0/en/flying/pre_flight_checks.html
            • Daniel RyuD
              Daniel Ryu
              @modaltb
              Does this mean the GPS is faulty? Do I need a new one?
                Hey Daniel,
                From the GPS logs you posted, it looks like GPS is working. I see that you have a DGPS fix at 4 and 13 satellites.
                Are you using indoor or outdoor parameters? For instance, EKF2_AID_MASK can be set for indoor or outdoor; it's shipped with indoor configuration. This parameter needs GPS set.
                For updating parameters:
                https://docs.modalai.com/upload-px4-parameters/
                https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/tree/master/helpers
                  Also in the QGC MAVlink console, try gps status and see what comes up.
                  • Daniel RyuD
                    Daniel Ryu
                    • Daniel RyuD
                      Daniel Ryu
                      Resetting the parameters to outdoor mode seemed to have worked! The GPS acquired a signal and I am able to fly in Mission mode. Thank you!
