  3. Traditional Helicopter Support on VOXL 2 Mini with ArduPilot
1 Posts 1 Posters 65 Views
  • B Offline
    B Offline
    batu1881
    wrote last edited by
    I would like to run ArduPilot Traditional Helicopter firmware on the VOXL 2 Mini, using its onboard Qualcomm flight-control architecture.
    I know that ArduPilot supports traditional helicopters, but I could not find any information confirming that this vehicle type has been tested on the VOXL 2 Mini.
    Could you please clarify the following?
    Can the VOXL 2 Mini QURT target compile and run the ArduPilot Traditional Helicopter (heli) firmware?
    Are the required swashplate servo outputs, tail rotor servo, and throttle/governor outputs supported through the VOXL 2 IO board?
    Are there any known limitations in the QURT hardware abstraction layer or the VOXL-specific ArduPilot integration that would prevent traditional helicopter operation?
    Has anyone successfully tested this configuration, or would custom code changes be required?
    I am willing to build ArduPilot from source and modify the platform-specific code if necessary.
    Thank you for your help.
