<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Traditional Helicopter Support on VOXL 2 Mini with ArduPilot]]></title><description><![CDATA[<p dir="auto">I would like to run ArduPilot Traditional Helicopter firmware on the VOXL 2 Mini, using its onboard Qualcomm flight-control architecture.</p>
<p dir="auto">I know that ArduPilot supports traditional helicopters, but I could not find any information confirming that this vehicle type has been tested on the VOXL 2 Mini.</p>
<p dir="auto">Could you please clarify the following?</p>
<p dir="auto">Can the VOXL 2 Mini QURT target compile and run the ArduPilot Traditional Helicopter (heli) firmware?</p>
<p dir="auto">Are the required swashplate servo outputs, tail rotor servo, and throttle/governor outputs supported through the VOXL 2 IO board?</p>
<p dir="auto">Are there any known limitations in the QURT hardware abstraction layer or the VOXL-specific ArduPilot integration that would prevent traditional helicopter operation?</p>
<p dir="auto">Has anyone successfully tested this configuration, or would custom code changes be required?</p>
<p dir="auto">I am willing to build ArduPilot from source and modify the platform-specific code if necessary.</p>
<p dir="auto">Thank you for your help.</p>
]]></description><link>https://forum.modalai.com/topic/5523/traditional-helicopter-support-on-voxl-2-mini-with-ardupilot</link><generator>RSS for Node</generator><lastBuildDate>Wed, 28 Oct 2026 04:36:47 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5523.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 22 Oct 2026 11:29:14 GMT</pubDate><ttl>60</ttl></channel></rss>
