voxl-mapper produces no map; VIO output rate halves to 15 Hz and does not recover until OpenVINS restart
Hardware: Starling 2 Max, SKU
MRB-D0012-4-V4-C29-T8-M36, hw platform M0054 (C29 config with PMD ToF). Received 14 Sep 2026, factory state.Software version: (
voxl-version)- system-image
1.8.08-M0054-14.1a-perf, kernel 4.19.125 - voxl-suite
1.6.4~beta5(factory; SDK not re-flashed) - voxl-mapper 0.2.4, voxl-voxblox 1.1.5, voxl-nlopt 2.5.0-5 (installed via apt)
Configuration / services: (
voxl-inspect-services)- Running: voxl-camera-server, voxl-imu-server, voxl-open-vins-server, voxl-px4, voxl-vision-hub, voxl-mavlink-server, voxl-rangefinder-server, voxl-portal, voxl-streamer, voxl-mavcam-manager, voxl-cpu-monitor
- voxl-qvio-server: disabled. voxl-mapper: started manually for these tests, otherwise disabled.
- OpenVINS config:
use_stereofalse,max_cameras2,track_frequency30.0,imu_body_frame_modetrue - voxl-mapper.conf: defaults (
voxel_size0.1,esdf_max_distance2,robot_radius0.35,tof_0_rate10, tof pipe/run/mpa/tofenabled, stereo depth pipes disabled)
What I am trying to do:
Build a map with voxl-mapper so we can move on to trajectory/planning based autonomy. VIO and manual autonomy already work on this airframe: on the same day we flew a manual Position-mode flight and an OFFBOARDfigure_eightflight, and EKF fused vision at 99-100% (cs_ev_pos/cs_ev_hgt/cs_ev_vel/cs_ev_yaw) with 0.14 m horizontal drift over 20 s of stick-neutral hover.What actually happens:
voxl-mapper starts and connects, but never produces any map output — and starting it also halves the VIO rate, which then does not recover when voxl-mapper is stopped.- With voxl-mapper stopped,
voxl-inspect-vioreports dt = 33.3 ms (30 Hz). - Starting voxl-mapper drops it to 66.7 ms (15 Hz), with almost no jitter (spread ~0.1 ms). The raw
ovpipe reads 15 Hz too, so this is not a voxl-vision-hub stage. - Stopping voxl-mapper does not restore 30 Hz. At that moment feature count (20) and quality (97%) are normal, so it is not feature starvation.
systemctl restart voxl-open-vins-serverrestores 30 Hz every time (reproduced 3x).- Running voxl-mapper in the foreground, initialisation completes normally:
Loading our own config file Loading extrinsics config file Trying to init tsdf server created tsdf server Connected to VIO server Initializing ESDF structs Connected to depth pipe ESDF Thread is now locked to the following cores: 4 5 6and then it repeats, indefinitely:
WARNING the requested timestamp was too new, VIO may have stopped ERROR in pipe_server_write_point_cloud, received NULL data pointervoxl-inspect-points voxl_mapper_aligned_ptcloudshows the header only, no data rows, while the ToF input pipetof_pcis healthy at 43,200 points.
Note: "VIO may have stopped" looks like a misdiagnosis — VIO is running the whole time, just at half rate.
What we ruled out (all measured on the vehicle):
- CPU load: voxl-mapper uses 1.9-5.7% CPU, the system is ~72% idle (8 cores), and no other service rises when it starts.
- Config drift:
voxl-camera-server.confandvoxl-open-vins-server.confare byte-identical to a snapshot taken before voxl-mapper was installed. - Camera input:
tracking_frontis a steady 30.0 fps (exposure ~7.4 ms); the processed pipes (misp_grey,misp_norm) are also 30 fps. So input is 30 Hz while only the OpenVINS output is halved. - Clock mismatch: VIO and ToF timestamps share the same monotonic base. Sampled simultaneously they differ by ~137 ms (VIO 2841.870 s, ToF 2841.733 s).
- Extrinsics:
body->tofis defined in extrinsics.conf and voxl-mapper logs no extrinsics error. - Subscriber count: two simultaneous
voxl-inspect-vioclients do not change the rate (still 30 Hz).
Steps to reproduce:
systemctl restart voxl-open-vins-server, wait ~30 s, confirmvoxl-inspect-vioshows 33.3 ms.systemctl start voxl-mapper.voxl-inspect-vionow shows 66.7 ms.systemctl stop voxl-mapper— still 66.7 ms.systemctl restart voxl-open-vins-server— back to 33.3 ms.
Questions:
- Is there a known condition under which voxl-open-vins-server latches to half its configured rate and does not return until restarted?
- Is a rate change expected when another process subscribes to the VIO pipe?
- Is the "requested timestamp was too new" failure a consequence of the 15 Hz rate, or an independent problem? If we could hold 30 Hz, would voxl-mapper work?
- Is there a supported way to detect or recover this state without restarting voxl-open-vins-server?
Logs / pictures: Happy to provide the full system snapshot (
voxl-version,voxl-inspect-services, full PX4 parameter dump) and the.ulgflight logs on request. - system-image
Hi! Planning on testing and getting into the weeds of this tomorrow to see if I can recreate and provide proper answers for this!
Zach
Can you put your voxl2 into performance mode and test the 15 vs 30hz please!
voxl-configure-cpu perf -
Ok lastly - can you please list out your OpenVINS package version? Previous versions of vins has a callback that alternates between processing and dropping frames when VIO is intiialized and its static jerk test permits throttling - so that first the 66.7 ms spacing you described. Restarting it would also bypass this throttle during init which is why it would go back to 30 hz
Hi Zach, thanks for looking into this.
voxl-open-vins-server 0.6.1— that is the only OpenVINS-related package installed on this unit (dpkg -l | grep -i vinsreturns exactly one row; there is no separate open-vins library package). Still factory voxl-suite 1.6.4~beta5, never re-flashed.Performance mode test
voxl-configure-cpudoes not exist on this image, so I usedvoxl-set-cpu-mode perf(governor wentschedutil->performance, confirmed via/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor). Please tell me if you meant a different tool.The result is that I could not reproduce the problem at all today — in either CPU mode.
Condition VIO dt voxl-mapper output Fresh boot, schedutil, mapper off 33.3 ms - schedutil, mapper off, 2 min 33.3 ms (320 samples) - schedutil, mapper on, 2 min 33.3 ms (320 samples) working performance, mapper off 33.3 ms - performance, mapper on, 90 s 33.3 ms (240 samples) working performance, restart voxl-open-vins-server x5 33.3 ms every time (400 samples) - 23 measurements, ~1,760 samples, all 33.3 ms. Not a single 15 Hz reading.
More importantly: voxl-mapper works now.
voxl-inspect-points voxl_mapper_aligned_ptcloudproduces real data — ~1,900 points per cloud, roughly every 500 ms in schedutil. On 22 Sep the same pipe showed the header and zero data rows. There are nopipe_server_write_point_cloud, received NULL data pointerand norequested timestamp was too new, VIO may have stoppedmessages in the journal at all today. voxl-mapper CPU is now ~100% of one core, versus the 1.9% I reported — it was low then because it was not actually doing any work.Performance mode does help the mapper, even though it did not change the VIO rate: the aligned point cloud comes out roughly every 95-190 ms instead of ~500 ms.
What this suggests about the causality
I think I had the direction backwards in my first post. The likely chain is:
OpenVINS comes up at 15 Hz -> mapper cannot match pose timestamps ("requested timestamp was too new") -> no map output
rather than "mapper is started -> VIO halves". That matches your static-jerk-throttle explanation: whatever decides the throttle is decided at VIO init, and on 22 Sep the vehicle happened to be in that state for the whole session (my very first reading that day, right after boot and before voxl-mapper had ever been started, was already 15 Hz).
Nothing was changed in between:
dpkgstatus andvoxl-open-vins-server.conf/voxl-camera-server.confare untouched since 21 Sep. So the difference is runtime state, not configuration.One observation that may not fit the throttle theory
Today the vehicle is completely static and
featuresreads 0, yet VIO runs at 30 Hz. On 22 Sep it was showingfeatures20 andquality97% while stuck at 15 Hz. If the throttle is permitted by a static-jerk test, I would have expected today's fully static case to be the one that throttles. Is the test based on IMU motion rather than tracked features, and is there any way to see its decision at runtime?Remaining questions
- Is there a log line, pipe field, or debug flag that shows whether the throttle is currently engaged? Right now the only way I can tell is by timing the output, and the state is invisible in
state/quality/features. - Was the throttle behaviour changed after 0.6.1? If a newer voxl-open-vins-server fixes it, which SDK version should we move to?
- Given it is intermittent, is it safe to treat "dt == 33.3 ms" as a pre-flight check, or is there a more reliable condition we should test before an autonomous flight?
I will keep the vehicle in performance mode and report back if the 15 Hz state shows up again, with the full journal from that boot.
JinHyeok - Is there a log line, pipe field, or debug flag that shows whether the throttle is currently engaged? Right now the only way I can tell is by timing the output, and the state is invisible in
Is there a log lin pipe field or debug flag that shows whether the throttle is currently engaged?
Currently if you wish to have more robust logging you can run the commands via command line with the -d flag and check the output - you can also write some burner scripts capable of subscribing to the MPA itself and outputting what you need - lastly you can use voxl-logger which is capable or recording the data coming off the raw pipes. -
you should be pulling the most recent instance of it - you can either build it from source from gitlabl OR you can run apt-get upgrade and that will auto pull the most recent deb's from our server. -
I am a bit unsure what you mean treating this as a pre flight check - either openvins is feeding odometry and local setpoint positional data to px4 or it is not - if it IS even if its running slower that 33.3ms, then I would argue you are fine to fly.
Zach -
Thanks Zach — that answers what we needed.
We will pick up the newer OpenVINS build separately — we are holding this unit at factory voxl-suite 1.6.4~beta5 for now, since it is the baseline our 22 Sep / 28 Sep comparison rests on. If the 15 Hz state shows up again before then, I will post the journal from that boot here.
Thanks again for digging into it — the static-jerk-throttle explanation was the piece we could not have found on our own.
JinHyeok
Zach, as promised, here is the follow-up on the 15 Hz state. It showed up again on 8 Oct and 13 Oct. Two corrections to what we reported in September come first, because both of them change the picture.
Correction 1 — "it only recovers via restart" was wrong.
In September we reported that stopping
voxl-mappernever restored 30 Hz and that onlysystemctl restart voxl-open-vins-serverbrought it back (3 reproductions). That conclusion was an artifact of our own method: all three times we restarted the service, so we never observed what happens if we just wait. On 8 Oct the unit went from a fully stuck state (dt 66.7 ms x 100 %, zero 33.3 samples) back to 33.3 ms on its own in about 5 minutes, withsystemctl show voxl-open-vins-serverreportingNRestarts=0and an unchangedActiveEnterTimestamp. The service was never restarted.Correction 2 — the "mapper produces zero rows" symptom was our own sequencing error.
We reported in September that
voxl_mapper_aligned_ptcloudoutput nothing while VIO ran at 15 Hz. The real cause: restartingvoxl-open-vins-serverleavesvoxl-mapperreportingactivewhile its mapping function is dead.systemctl is-activestill saysactive; only the empty point-cloud pipe reveals it. A singlesystemctl restart voxl-mapperrestores it.On 8 Oct we measured the two states side by side — fully stuck VIO with a healthy map (1,473-1,675 points, ~10 Hz), and healthy 33.3 ms VIO with zero map rows right after a VIO restart. So dt and map output are independent, and our September report conflated them. Sorry for the noise that caused.
New observation — the stuck state clears the moment the drone takes off.
This is the part we think is most useful to you. On 13 Oct the unit sat fully stuck on the ground for 5 minutes (66.7 ms x 100 %,
NRestarts=0, no self-recovery this time). It returned to 33.3 ms within one sample of takeoff and stayed there for the entire flight (44 samples, all 33.3). Feature count also rose from 19 on the ground to 30 in the air.14:07:59 dt 66.7 features 17 quality 57% on ground 14:08:07 dt 33.3 features 30 quality 75% takeoff 14:08:16+ dt 33.3 features 15-30 entire flightRelated: on the ground at rest, VIO publishes blank packets that look healthy.
Before takeoff we saw 480 consecutive samples with
features 0andT_imu_wrt_viofrozen to two decimals, whiledtread 33.3,qualityread 96 % anderror_codeswas empty. The journal explains it:[HEALTH] Publishing blank VIO packet due to missing sensors. Moving the airframe by hand for ~10 seconds started tracking immediately (features 11-30). So on a stationary unit,dtandqualityare not evidence that VIO is estimating anything.Our working hypothesis, which matches yours.
Across 8 Oct and 13 Oct, all three stuck states began immediately after we picked the drone up and walked with it. Periods where the unit sat still ran at 33.3 ms. That is consistent with the static-jerk-throttle mechanism you described: the throttle is a releasable state, hand motion during initialization keeps re-creating the condition, and sustained flight motion clears it.
Questions, if you have a moment:
- Does "clears on takeoff, never clears while stationary on the ground" fit the static jerk throttle as you understand it?
- Is the blank-packet behaviour on a stationary unit expected — i.e. is
features 0with a healthy-lookingdt/qualitythe normal pre-initialization output?
Environment unchanged: voxl-suite
1.6.4~beta5, system-image1.8.08-M0054-14.1a-perf, SKUMRB-D0012-4-V4-C29-T8-M36,voxl-mapper0.2.4. We are still holding the unit at factory SDK as the baseline for these comparisons. Journals from both boots are available if useful. -
- Yes when the drone "takes off" that is monitered as the jerk occuring that kicks off ovins
- Yes - if there is no ovins algorithm occuring due to you sitting on the ground, you need the healthy packets to allow px4 to take off to begin with even if there are no features occuring in the frame.
Zach
