  3. Starling 2 Max: WiFi dongle USB link (error -71,) - dongle tested good on PC
Scheduled Pinned Locked Moved Solved General Questions
4 Posts 3 Posters 565 Views 1 Watching
  • K Offline
    K Offline
    kristi
    Hardware: Starling 2 Max, SKU MRB-D0012-4-V2-C29-T9-M22-X0 (V2, T-Motor)
    Software: voxl-suite 1.3.5, system image 1.7.10-M0054-14.1a-perf
    Stock RTL8821CU WIFI dongle keeps dropping off the USB bus: "device descriptor read/64, error -71", "device not accepting address", and "usb usb1-port1: Cannot enable.
    Fails with the aircraft untouched. Battery power-cycle revives it temporarily.
    Same day, I tested this same dongle on a Windows PC: clean enumeration, 0% loss ping. Fine on PC, dies in 12 s on the drone
    Is this a known issue?
      Hi @kristi ,
      Not a known issue. error -71 on the descriptor read happens before the WiFi driver loads, and getting worse over weeks with only a power cycle recovering it points to a failing part in the USB path rather than software.
      Working on a PC does not rule out the dongle, since we have seen these Alfa dongles fail in service
      (https://forum.modalai.com/topic/4538).
      On Starling 2 Max the dongle sits in the M0141 breakout on VOXL 2 J3, so the likely fix is replacing one of them:
      1. Try a new AWUS036EACS or AWUS036ACS (https://docs.modalai.com/voxl-2-wifi-setup/).
      2. If a new dongle fails the same way, open an RMA so we can inspect the board: https://www.modalai.com/rma
      Posting voxl-version and dmesg | grep -i usb from a failing boot would help us confirm.
      • E Offline
        E Offline
        electroAJ
        Hi @kristi,
        I'm experiencing a similar, though maybe not identical issue. Would you mind sharing the repeatability of your problem? is it consistent? thanks.
        • K Offline
          K Offline
          kristi
          Hi @electroaj
          It's intermittent but it's gotten worse over about three weeks. Dongle would vanished from the USB bus mid-session. And then at boot the dongle enumerated for under a second, then went into the device descriptor read/64, error -71 . No software path recovered adb reboot didn't help. Only a physical restart (unplugging and plugging back to power), would bring back now even that has been inconsistent. Sometimes it would last 30 minutes after physical restart sometimes just a few seconds.
            Hi @kristi ,
            • tomT tom has marked this topic as solved on
