  3. VOXL2 USB Host Port J18 Not initializing
9 Posts 2 Posters 580 Views 2 Watching
  • nickanickN Offline
    nickanickN Offline
    nickanick
    wrote on last edited by nickanick
    We bought the parts to build our own Blue UAS drone.
    When trying to connect the Wifi dongle (AWUS036ACS) using the MCBL-00009-01 cable in the VOXL 2 port J18, nothing is shown in lsusb.
    voxl-suite version 1.6.3
    kernel 4.19.125
    Error message
    dmesg | grep -i -B2 -A8 ssusb
    [ 1.862118] msm-usb-hsphy 88e4000.hsphy: Linked as a consumer to regulator.10
    [ 1.862129] msm-usb-hsphy 88e4000.hsphy: Linked as a consumer to regulator.21
    [ 1.862704] msm-dwc3 a600000.ssusb: Linked as a consumer to 15000000.apps-smmu
    [ 1.862915] iommu: Adding device a600000.ssusb to group 13
    [ 1.863060] msm-dwc3 a600000.ssusb: Linked as a consumer to regulator.66
    [ 1.863558] dwc3 a600000.dwc3: Failed to get clk 'ref': -2
    [ 1.863615] dwc3 a600000.dwc3: changing max_speed on rev 00000000
    [ 1.864445] msm-dwc3 a600000.ssusb: unable to get ssphy device
    [ 1.865469] msm-dwc3 a600000.ssusb: Dropping the link to regulator.66
    [ 1.865524] msm-dwc3 a800000.ssusb: Linked as a consumer to 15000000.apps-smmu
    [ 1.865730] iommu: Adding device a800000.ssusb to group 14
    [ 1.865884] msm-dwc3 a800000.ssusb: Linked as a consumer to regulator.67
    [ 1.866435] dwc3 a800000.dwc3: Failed to get clk 'ref': -2
    [ 1.866578] register_client_adhoc:find path.src 101 dest 512
    [ 1.866718] register_client_adhoc:find path.src 101 dest 676
    [ 1.866828] register_client_adhoc:find path.src 1 dest 751
    [ 1.866893] register_client_adhoc:Client handle 36 usb1
    [ 1.867145] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [ 1.867149] ehci-pci: EHCI PCI platform driver
    [ 1.867158] ehci-platform: EHCI generic platform driver
    [ 1.869969] i2c_geni a88000.i2c: Bus frequency is set to 400000Hz
    [ 1.870203] i2c_geni 884000.i2c: Bus frequency is set to 400000Hz
    [ 1.875097] ssusb redriver 3-001c: Could not get usb power_supply
    [ 1.875103] ssusb redriver 3-001c: failed to get phandle for redriver
    [ 1.875396] i2c_geni 884000.i2c: i2c error :-107
    [ 1.875491] i2c_geni 884000.i2c: i2c error :-107
    [ 1.875584] i2c_geni 884000.i2c: i2c error :-107
    [ 1.875678] i2c_geni 884000.i2c: i2c error :-107
    [ 1.875681] I2C PMIC: i2c_pmic_read: i2c_pmic_read failed for 3 retries, rc = -107
    [ 1.875683] I2C PMIC: i2c_pmic_determine_initial_status: Couldn't read irq data rc=-107
    [ 1.875686] I2C PMIC: i2c_pmic_probe: Couldn't determine initial status rc=-107
    [ 1.875699] i2c_pmic: probe of 3-0010 failed with error -107
    [ 1.924143] register_client_adhoc:Client handle 57 cam_ahb
    [ 1.924194] register_client_adhoc:find path.src 170 dest 512
    [ 1.924203] msm-dwc3 a800000.ssusb: DWC3 exited from low power mode
    [ 1.924258] register_client_adhoc:Client handle 58 cam_hf_0_mnoc
    [ 1.924310] register_client_adhoc:find path.src 137 dest 512
    [ 1.924371] register_client_adhoc:Client handle 59 cam_sf_0_mnoc
    [ 1.924417] register_client_adhoc:find path.src 171 dest 512
    [ 1.924449] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [ 1.924474] register_client_adhoc:Client handle 60 cam_sf_icp_mnoc
    [ 1.924479] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [ 1.924696] xhci-hcd xhci-hcd.0.auto: hcc params 0x0230ffe5 hci version 0x110 quirks 0x0000000000010810
    [ 1.962399] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.18
    [ 1.962410] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.32
    [ 1.962484] msm-dwc3 a600000.ssusb: Linked as a consumer to regulator.66
    [ 1.962839] dwc3 a600000.dwc3: Failed to get clk 'ref': -2
    [ 1.962874] dwc3 a600000.dwc3: changing max_speed on rev 00000000
    [ 1.963402] usb_bam_init: setting SPS_BAM_SMMU_EN flag with (a704000.qcom,usbbam)
    [ 1.963465] sps:BAM 0x000000000a704000 is registered.
    [ 1.963510] msm-dwc3 a600000.ssusb: unable to get ssphy device
    [ 1.964159] msm-dwc3 a600000.ssusb: Dropping the link to regulator.66
    [ 1.964223] qpnp-pdphy c440000.qcom,spmi:qcom,pm8150b@2:qcom,usb-pdphy@1700: Linked as a consumer to regulator.10
    [ 1.964711] qpnp-pdphy c440000.qcom,spmi:qcom,pm8150b@2:qcom,usb-pdphy@1700: usbpd_create failed: -517
    [ 1.964765] qpnp-pdphy c440000.qcom,spmi:qcom,pm8150b@2:qcom,usb-pdphy@1700: Dropping the link to regulator.10
    [ 1.964834] qcom,haptics c440000.qcom,spmi:qcom,pm8150b@3:qcom,haptics@c000: Linked as a consumer to regulator.89
    [ 1.965191] input: qti-haptics as /devices/platform/soc/c440000.qcom,spmi/spmi-0/spmi0-03/c440000.qcom,spmi:qcom,pm8150b@3:qcom,haptics@c000/input/input2
    [ 1.969082] ufshcd-qcom 1d84000.ufshc: ufshcd_needs_reinit: Re-init UFS host to use proper PHY settings for the UFS device. This can be avoided by setting the force-g4 in DT
    [ 1.969742] ssusb redriver 3-001c: Could not get usb power_supply
    [ 1.969746] ssusb redriver 3-001c: failed to get phandle for redriver
    [ 1.971209] Input suspended: Fake battery
    [ 1.971249] qcom,qpnp-smb5 c440000.qcom,spmi:qcom,pm8150b@2:qcom,qpnp-smb5: Linked as a consumer to regulator.86
    [ 1.973079] of_batterydata_get_best_profile: No battery data found
    [ 1.973102] pm8150b_charger: jeita_update_work: Incorrect fastchg-current-ma or max-voltage-uv
    [ 1.979101] SMB5 status - usb:present=0 type=0 batt:present = 1 health = 1 charge = 1
    [ 1.979118] QPNP SMB5 probed successfully
    [ 1.984394] Error registering TZ zone:-19 for dt_ch:77
    [ 1.987232] Error registering TZ zone:-19 for dt_ch:77
    [ 1.991538] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.18
    [ 1.991547] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.32
    [ 1.991616] msm-dwc3 a600000.ssusb: Linked as a consumer to regulator.66
    [ 1.991965] dwc3 a600000.dwc3: Failed to get clk 'ref': -2
    [ 1.991997] dwc3 a600000.dwc3: changing max_speed on rev 00000000
    [ 1.992493] usb_bam_init: setting SPS_BAM_SMMU_EN flag with (a704000.qcom,usbbam)
    [ 1.992545] sps:BAM 0x000000000a704000 is registered.
    [ 1.992586] msm-dwc3 a600000.ssusb: unable to get ssphy device
    [ 1.993223] msm-dwc3 a600000.ssusb: Dropping the link to regulator.66
    [ 1.993290] qpnp-pdphy c440000.qcom,spmi:qcom,pm8150b@2:qcom,usb-pdphy@1700: Linked as a consumer to regulator.10
    [ 1.994031] i2c_geni 884000.i2c: i2c error :-107
    [ 1.994117] i2c_geni 884000.i2c: i2c error :-107
    [ 1.994202] i2c_geni 884000.i2c: i2c error :-107
    [ 1.994287] i2c_geni 884000.i2c: i2c error :-107
    [ 1.994372] i2c_geni 884000.i2c: i2c error :-107
    [ 1.994457] i2c_geni 884000.i2c: i2c error :-107
    [ 1.994541] i2c_geni 884000.i2c: i2c error :-107
    [ 1.999438] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.18
    [ 1.999442] msm-usb-ssphy-qmp 88e8000.ssphy: No separate ID extcon device
    [ 1.999485] msm-dwc3 a600000.ssusb: Linked as a consumer to regulator.66
    [ 1.999803] dwc3 a600000.dwc3: Failed to get clk 'ref': -2
    [ 1.999828] dwc3 a600000.dwc3: changing max_speed on rev 00000000
    [ 2.000352] usb_bam_init: setting SPS_BAM_SMMU_EN flag with (a704000.qcom,usbbam)
    [ 2.000397] sps:BAM 0x000000000a704000 is registered.
    [ 2.000458] register_client_adhoc:find path.src 61 dest 512
    [ 2.000574] register_client_adhoc:find path.src 61 dest 676
    [ 2.000679] register_client_adhoc:find path.src 1 dest 583
    [ 2.000742] register_client_adhoc:Client handle 63 usb0
    [ 2.000777] msm-dwc3 a600000.ssusb: Linked as a consumer to regulator.86
    [ 2.000925] core_ctl: Creating CPU group 0
    [ 2.000928] core_ctl: Init CPU0 state
    [ 2.000930] core_ctl: Init CPU1 state
    [ 2.000931] core_ctl: Init CPU2 state
    [ 2.000932] core_ctl: Init CPU3 state
    [ 2.000997] core_ctl: Creating CPU group 4
    [ 2.000999] core_ctl: Init CPU4 state
    [ 2.001000] core_ctl: Init CPU5 state
    [ 2.045080] ALSA device list:
    [ 2.045082] No soundcards found.
    [ 2.060174] msm-dwc3 a600000.ssusb: DWC3 exited from low power mode
    [ 2.060764] msm-dwc3 a600000.ssusb: DWC3 in low power mode
    [ 2.063630] ufshcd-qcom 1d84000.ufshc: ufshcd_print_pwr_info:[RX, TX]: gear=[4, 4], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 1
    [ 2.067524] ufshcd-qcom 1d84000.ufshc: ufshcd_wb_config: Write Booster Configured
    [ 2.068150] scsi 0:0:0:49488: Well-known LUN KINGSTON CY14-128 0002 PQ: 0 ANSI: 6
    [ 2.069714] scsi 0:0:0:49476: Well-known LUN KINGSTON CY14-128 0002 PQ: 0 ANSI: 6
    [ 2.070390] scsi 0:0:0:49456: Well-known LUN KINGSTON CY14-128 0002 PQ: 0 ANSI: 6
    [ 2.079698] scsi 0:0:0:0: Direct-Access KINGSTON CY14-128 0002 PQ: 0 ANSI: 6
    [ 2.081517] scsi 0:0:0:1: Direct-Access KINGSTON CY14-128 0002 PQ: 0 ANSI: 6
    [ 2.083544] scsi 0:0:0:2: Direct-Access KINGSTON CY14-128 0002 PQ: 0 ANSI: 6
    [ 2.727663] kona-pinctrl f000000.pinctrl: invalid function func2 in map table
    [ 3.130934] msm-usb-ssphy-qmp 88e8000.ssphy: USB DP QMP PHY: Update TYPEC CTRL(2)
    [ 3.188278] msm-dwc3 a600000.ssusb: DWC3 exited from low power mode
    [ 3.968038] of_batterydata_get_best_profile: No battery data found
    [ 3.968047] QCOM-STEPCHG: get_step_chg_jeita_setting_from_profile: Couldn't find profile
    [ 4.740943] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ 4.741012] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ 4.741615] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ 4.746196] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ 4.749797] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    [ 4.750167] ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
    Please assist.
    nickanickN 1 Reply Last reply
    • nickanickN nickanick
      kernel 4.19.125
      Error message
      Please assist.
      nickanickN Offline
      nickanickN Offline
      nickanick
      @nickanick Do I need the VOXL 2 WiFi Add-on and I/O Breakout to use the WIFI Dongle?
        nickanickN Offline
        nickanick
        Second question: Can I use the USB to connect to QGroundControl instead?
          @nickanick It's best if you ask each question in a separate post. For QGC over the ADB USB: https://docs.modalai.com/qgc-via-adb/
          nickanickN 2 Replies Last reply
            nickanickN Offline
            nickanickN Offline
            nickanick
            @Eric-Katzfey Thanks Eric. I have posted the WIFI Dongle question in another post.
              nickanickN Offline
              nickanickN Offline
              nickanick
              @Eric-Katzfey can use the VOXL2 USB-C port to connect to QGroundControl, or do I need an extra component?
                @nickanick That was what I responded with previously. Did that documentation not address your question?
                  nickanickN Offline
                  nickanickN Offline
                  nickanick
                  @Eric-Katzfey Appreciate your help!
                    nickanickN Offline
                    nickanickN Offline
                    nickanick
                    @Eric-Katzfey We are experiencing connection issues between VOXL2 and QGC.
                    QGroundControl is showing disconnected after inputting the comms link with 192.168.7.2:14550 in UDP. mavlink_to_gcs and mavlink_from_gcs are both reporting data. voxl-px4 and voxl-mavlink-server are running.
                    voxl-my-ip
                    192.168.7.2 (usb0)
