  3. C29 Configuration
C29 Configuration
starling
4 Posts 3 Posters 1.3k Views 1 Watching
  • R Offline
    R Offline
    RoyAzriel
    You are offering C29 configuration but it is grayed out.
    Is it for a spacific reason ?
    We have order Starting-2 Max with C28 with M0177 kit to upgrade the drone ourself.
    I hope my approach is ok.
    Roy
    • R RoyAzriel
      Roy
      @RoyAzriel , we were temporarily out of stock on some components and C29 configuration of Starling 2 Max is available again.
      The TOF sensor kit (M0177 + M0171 + TOF Sensor) will plug in directly into M0173 camera front end and the Front camera mount already has a spot to mount for the TOF sensor. So you should be able to turn C28 into C29. See C27 here for reference how the TOF sensor is connected : https://docs.modalai.com/voxl2-coax-camera-bundles/#kit-pictures-and-descriptions
      J 1 Reply Last reply
        J Offline
        J Offline
        jbiscan21
        @Alex-Kushleyev said in C29 Configuration:
        The flex cable is pretty short, where does the tof sensor get mounted exactly after it is plugged in? I assume it is meant to be downward facing.
        • J jbiscan21
          @jbiscan21 , sorry i am surprised that we don't have a photo of the Starling 2 Max with the TOF mounted. Please see below. The TOF sensor is oriented vertically on the front face, right next to the front hires and tracking cameras.
          If you need to mount the sensor somewhere else, you can use an available extension flex (it only works for the TOF V2 sensor) : https://www.modalai.com/products/msu-m0170
          • Timothy ZinwotaT Timothy Zinwota referenced this topic on
