  2. VOXL SDK and Software
  3. Hadron ov64b snapshots have a vertical image artifact
camera
34 Posts 3 Posters 16.0k Views 2 Watching
    OK, I will test it and get back to you shortly 🙂
    C Offline
    C Offline
    cguzikowski
    @Alex-Kushleyev Some additional info: When we ran at the lower resolution and tried viewing hires_bayer in the voxl portal this error would pop up in the terminal running voxl-camera-server:
    ERROR:   Could not find frame size from the raw buffer
    ERROR:   MISP: Unexpected frame size for camera hires, width 4624, height 3472, stride 5792, alloc 20111360 bytes, calc frame size 20109824
    Thank you for your speedy response
    • C cguzikowski
      @cguzikowski , OK, yes i know what that issue is (unexpected frame size). I will that and test both resolutions.
        @cguzikowski ,
        Good news. I got it working, but there were a few things needed to update. I packaged everything into a zip : https://storage.googleapis.com/modalai_public/temp/ov64b/20260401/ov64b_20260401.zip . It contains
        • latest sensormodules for Boson and ov64b
        • voxl-camera-server conf
        • updated default tuning file (to fix the gain scale so that gain 1.0 is 100, not 54)
        • updated com.qti.chi.override.so file which contains some pipeline information, now it will allow the large raw resolutions
        (I thought the above changes were already in the latest SDK but somehow they did not make it, I will need to double check).
        I also made some changes to the ov64b driver:
        • updated frame length for the 9248x6944 mode so that it is 10fps (not 9.2) -- this is close to max
        • added modes 9216x6944@10fps and 4608x3472@30fps (slightly cropped on the right), so that these buffers can be used by MISP / gpu without doing a copy.
        I am able to capture the raw bayer at 9216x6944, 9248x6944 ,4624x3472, 4608x3472 resolutions
        voxl-inspect-cam hires_bayer
        |   Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbps  | format
        | hires_bayer |79994880 | 9216 | 6944 | 33.00 | 1594 |      130 |    157.9  | 10.0 | 6415.5 | RAW10
        In order to enable the misp support for the 4624x3472 and 4608x3472 resolutions in camera server, need a small update:
        https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/commit/389b1f4628a9b9cc0e53c43a5cf0e457717e1270
        You can save the raw bayer using the voxl-record-raw-image tool, for example:
        voxl-record-raw-image hires_bayer -d .
        You should be able to dump some raw bayer images and de-bayer them offline.
        Also, here is the contents of the README that is inside the zip:
        Supported Hardware
        • voxl2
        • Hadron plugged into VOXL2 J8 via M0181 adapter
        Instructions
        • copy Boson sensormodule to /usr/lib/camera/
        • copy ov64b sensormodule with correct id to /usr/lib/camera/
        • copy com.qti.tuned.default.bin to /usr/lib/camera to fix the gain scale (1.0x = 100)
        • back up /usr/lib/hw/com.qti.chi.override.so and replace it with com.qti.chi.override.so.20260401 (rename to com.qti.chi.override.so)
          • this updated file allows the pipeline to use the highest resolution of the ov64b camera
        • copy voxl-camera-server.conf to /etc/modalai
        Suported Resolutions
        • mode 0 : 9248x6944 10 bit 10 fps
        • mode 1 : 9216x6944 10 bit 10 fps (MISP no copy) -- crop 32 pixels on the right
        • mode 2 : 4624x3472 10 bit 30 fps
        • mode 3 : 4608x3472 10 bit 30 fps (MISP no copy) -- crop 16 pixels on the right
        • mode 4 : 3840x2160 10 bit 60 fps (MISP no copy)
        • mode 5 : 1920x1080 10 bit 240 fps
        • mode 6 : 1920x1080 10 bit 30 fps
        Notes
        • even thought the 9248x6944 and 9216x6944 modes are 10 fps, you need to specify 30fps in the camera config file. This will be investigated further.
          @cguzikowski ,
          Supported Hardware
          • voxl2
          Instructions
          Notes
          #12
          Once you confirm this working, we can discuss the options for snapshots without going through the ISP, but you can either saw the raw bayer or any of the misp outputs using voxl-record-raw-image and convert to jpg / png offline if that works for you, but we can also help add a compression option to voxl-record-raw-image.
          Please note that the current debayering algorithm in MISP does add some smoothing / interpolation, so the YUV image is not going to be as crisp as possible. You could compare it to the jpg output of the ISP (even thought it has artifacts). If you are looking for highest possible fidelity, it may be best to perform offline processing on the raw bayer, then you have more options.
          C 1 Reply Last reply
            C Offline
            C Offline
            cguzikowski
            @Alex-Kushleyev Hi Alex, thank you for the new drivers and the instructions. Unfortunately I am still having issues getting the hires_bayer pipe to appear. I followed all of the instructions in the README, and when shooting at 9216x6944, I get the following error:
            ERROR:   MISP: Unexpected frame size for camera hires, width 9216, height 6944, stride 11520, alloc 79994880 bytes, calc frame size 79994880
            Same error I was getting last week but now the allocated and calculated values are the same. Running it at 9248x6944 gives a similar error:
            ERROR:   MISP: Unexpected frame size for camera hires, width 9248, height 6944, stride 11568, alloc 80330752 bytes, calc frame size 80328192
            I do see the boson_bayer pipe, and in the portal the camera feed looks great - I believe we were getting a weird preview with the old drivers, but we didn't look too carefully as we are not using the boson yet. Here is the output of voxl-inspect-cam -a:
            |              boson |  327680 |  640 |  512 |  0.00 |  800 |      295 |     13.2  | 60.0 |  157.3 | RAW8
            |        boson_bayer |  327680 |  640 |  512 |  0.00 |    0 |      295 |     12.7  | 60.0 |  157.3 | RAW8
            |        boson_color |  983040 |  640 |  512 |  0.00 |  800 |      295 |     15.6  | 60.0 |  471.9 | RGB
            | boson_misp_encoded |      32 |  640 |  512 |  0.00 |  800 |      295 |     17.0  | 60.0 |    0.0 | H264 (P)
            |        hires_bayer |
            |   hires_misp_color |
            |    hires_misp_grey |
            Disabling MISP gives the following warning and output of voxl-inspect-cam -a:
            Received RAW10 frame from camera hires, will be converting to RAW8 on cpu
            WARNING: preview buffer pool for Cam(hires), Frame(18) has 0 free, skipping request
            |              boson |  327680 |  640 |  512 |  0.00 |  800 |      507 |     12.4  | 60.0 |  157.3 | RAW8
            |        boson_bayer |  327680 |  640 |  512 |  0.00 |    0 |      507 |     10.9  | 60.0 |  157.3 | RAW8
            |        boson_color |  983040 |  640 |  512 |  0.00 |  800 |      507 |     13.3  | 60.0 |  471.9 | RGB
            | boson_misp_encoded |      32 |  640 |  512 |  0.00 |  800 |      507 |     14.4  | 60.0 |    0.0 | H264 (P)
            |        hires_bayer |
            |        hires_color |
            |         hires_grey |64218112 | 9248 | 6944 | 12.06 | 1211 |       16 |   3720.9  |  1.8 |  945.2 | RAW8
            • C cguzikowski
              |        hires_bayer |
              |   hires_misp_color |
              |    hires_misp_grey |
              |        hires_bayer |
              |        hires_color |
              @cguzikowski , you need to update your camera server to allow misp to accept the new resolutions. You can install the latest one from voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/
                C Offline
                C Offline
                cguzikowski
                @Alex-Kushleyev Thank you! This now works great and I can save the raw files as a .bin file. Do you have tips for performing raw-jpg conversion both on and offline? I have also tried to take snapshots with the current setup, by disabling MISP and Raw preview, and enabling snapshot and setting the snapshot dimensions to 9248x6944 (9216x6944, 4624x3472, and 4608x3472 all give the error of unsupported file size). voxl-camera-server seems to start up, then immediately gets killed without an error. Here is the output of the command:
                MISP channels enabled in defaults : 0
                MISP channels enabled in config file: 0
                Setting MISP AWB to Auto
                configuration for 2 cameras:
                cam #0
                    type:                boson
                    bayer_type:          0
                    enabled:             1
                    camera_id:           0
                    camera_id_second:    -1
                    fps:                 30
                    en_rotate:           0
                    en_rotate2:          0
                    en_preview:          1
                    en_raw_preview:      1
                    preview_width:       640
                    preview_height:      512
                    en_misp:             1
                    misp_width:          512
                    misp_height:         640
                    en_small_video:      0
                    small_video_width:   640
                    small_video_height:  480
                    en_large_video:      0
                    large_video_width:   -1
                    large_video_height:  -1
                    en_snapshot:         0
                    snap_width:          -1
                    snap_height:         -1
                    exif_focal_length:   0.000000
                    exif_focal_len_35mm_format:0
                    exif_fnumber:        0.000000
                    ae_mode:             off
                    msv_exposure_min_us: 20
                    msv_exposure_max_us: 33000
                    gain_min           : 100
                    gain_max           : 100
                    standby_enabled:     0
                    decimator:           1
                    independent_exposure:0
                cam #1
                    type:                ov64b
                    bayer_type:          1
                    enabled:             1
                    camera_id:           1
                    fps:                 30
                    en_rotate:           0
                    en_rotate2:          0
                    en_preview:          1
                    en_raw_preview:      0
                    preview_width:       9248
                    preview_height:      6944
                    en_misp:             0
                    misp_width:          1280
                    misp_height:         720
                    en_small_video:      0
                    small_video_width:   1024
                    small_video_height:  768
                    en_large_video:      0
                    large_video_width:   3840
                    large_video_height:  2160
                    en_snapshot:         1
                    snap_width:          9248
                    snap_height:         6944
                    exif_focal_length:   3.100000
                    exif_focal_len_35mm_format:17
                    exif_fnumber:        1.240000
                    ae_mode:             lme_msv
                    gain_min           : 100
                    gain_max           : 1600
                    standby_enabled:     0
                    decimator:           1
                fsync_en:            0
                fsync_gpio:          109
                connected to mavlink pipe
                Connected to cpu-monitor
                Starting Camera: boson (id #0)
                ModalExposureMSV: initializing for camera name  type
                MISP Initializing for camera boson
                 Detected 1 platform(s)
                 Detected 1 GPU device(s)
                Estimated imu dt = 0.000977s
                ERROR in json_from_yaml, failed to open file
                MISP: Loading intrinsics cal file boson_intrinsics.yml for camera boson, ret -1
                WARNING: Lens calibration for camera boson is missing (boson_intrinsics.yml). Using defaults:
                Starting Camera: hires (id #1)
                ModalExposureMSV: initializing for camera name hires type ov64b
                ------ voxl-camera-server: Started 2 of 2 cameras
                Killed
                Don't necessarily need to use the snapshot command, but we want some way to get JPG images off the voxl.
                • C cguzikowski
                  cam #0
                      type:                boson
                      bayer_type:          0
                      enabled:             1
                      camera_id:           0
                      fps:                 30
                      en_rotate:           0
                      en_rotate2:          0
                      en_preview:          1
                      en_raw_preview:      1
                      preview_width:       640
                      preview_height:      512
                      en_misp:             1
                      misp_width:          512
                      misp_height:         640
                      en_small_video:      0
                      en_large_video:      0
                      en_snapshot:         0
                      snap_width:          -1
                      snap_height:         -1
                      ae_mode:             off
                      gain_min           : 100
                      gain_max           : 100
                      standby_enabled:     0
                      decimator:           1
                  cam #1
                      type:                ov64b
                      bayer_type:          1
                      enabled:             1
                      camera_id:           1
                      fps:                 30
                      en_rotate:           0
                      en_rotate2:          0
                      en_preview:          1
                      en_raw_preview:      0
                      preview_width:       9248
                      en_misp:             0
                      misp_width:          1280
                      misp_height:         720
                      en_small_video:      0
                      en_large_video:      0
                      en_snapshot:         1
                      snap_width:          9248
                      snap_height:         6944
                      ae_mode:             lme_msv
                      gain_min           : 100
                      gain_max           : 1600
                      standby_enabled:     0
                      decimator:           1
                  fsync_en:            0
                  fsync_gpio:          109
                  Killed
                  @cguzikowski , sorry for the delay.
                  Long term, our plan is to add snapshot functionality directly into misp (just like you were getting snapshots from the ISP). That is not too difficult to achieve, may be a few weeks away.
                  Also let me ask you this: would you want to save the raw bayer and get that from voxl2 and convert to jpg / png offline? That would give you maximum control over quality / processing algorithm. Alternatively, de-bayering can be done on voxl2 and saved as lossy or lossless image?
                  We do have tools to convert bayer -> yuv -> jpeg but not yet in a standalone app.
                  You you can do for now is the following:
                  • set misp output resolution equal to the raw resolution
                  • this will enable misp to publish the de-bayered yuv to the image pipe
                  • then you can use voxl-record-raw-image to save the yuv. Alternatively, you can test a WIP version of this tool which can save yuv as jpeg : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/merge_requests/37
                  • ideally this logging would be done within camera server to reduce overhead for sending these huge images over the pipe. But the approach i described should work for now.
                  I will be able to test this again mid next week, meanwhile please let me know if you run into the saving issue. I will double check the issue with snapshot resolution being too large. How large was the isp snapshot that you tested before and had artifacts?
                  C 2 Replies Last reply
                    C Offline
                    C Offline
                    cguzikowski
                    I was able to get both the full YUV and them in JPEG working. We also noticed that the vertical artifact seemed to disappear in these images. Regarding the resolution we were using when we had the artifacts, we were using 9248 × 6944 on the old drivers.
                      C Offline
                      C Offline
                      cguzikowski
                      wrote on last edited by cguzikowski
                      #18
                      @Alex-Kushleyev Hey Alex, we have been performing some tests and noticed the images we were getting were quite noisy. What are some of the settings that we can change in the voxl-camera-server to reduce the noise? I messed around with the ae_desired_msv setting and gain_max setting. I also noticed that the white balance seems to have a very visible green shift when the exposure is lower (tried to upload an image but got a "request entity too large" error)
                      Also as a side note, the metadata seems to not be recording when using voxl-record-raw-image -j
                      • C cguzikowski
                        @cguzikowski , if you want, you can attache a cropped image, so that it's smaller size.
                        In general, the pixel noise increases as you the pixel gain is increased. Part of Auto Exposure control is controlling exposure time and gain (both of which contribute to the image brightness), but higher gain has higher pixel noise and higher exposure values will result in motion blur.
                        The Qualcomm ISP has lots of liters, including noise reduction, which are applied when you use the ISP snapshot (even though they have not been tuned for the particular camera, the ISP output may result in better de-noised image). There are several types of filters, for example spatial (such as bilateral filter) and temporal (TNR - temporal noise reduction), and it's usually a combination of both with the filter weights increasing as the gain increases (more noise requires more noise reduction).
                        Currently, MISP does not have any de-noise filtering, but we are working on adding some. That is why i was discussing with you the ability to process the image offline (from the original bayer source). You could save the full raw image and perform any filtering you need in post processing. This approach is similar to using a RAW image on a fancy camera and then importing that into image processing software on a laptop / desktop, which can perform a lot more filters / effects directly on the raw image (loss-less).
                        What i suspect is that you are testing in the low-light environment and you are seeing the effects of high gain (high pixel noise). the MISP auto exposure tries to balance exposure and gain and there are a few parameters for that, but in your tests you should see what exposure and gain values the camera is at when you see the noisy image. You can use voxl-portal to control exposure and gain to see what the difference is. I believe the max gain for ov64b is 16x (1600).
                        I am about to set up your use case again for testing and i will investigate the noise and the original ISP snapshot artifact and we can also compare the image noise from the ISP snapshot and misp snapshot.
                        Unfortunately the lens for ov64b in the Hadron unit is very small, which reduces the amount of light that gets into the sensor. The sensor is 8+K resolution which means the pixel size is small, so the amount of light that gets to each pixel is small. To compensate for that, we would typically want a larger lens, but it is probably not possible to change the lens in this specific Hadron unit (we have not tried).
                        If you want to explore offline image processing, you would need:
                        • the original raw bayer (which you can already save)
                        • the gain and exposure used for that frame (i will need to check, i thin we had an option to save the exposure and gain as part of the file name).
                        • then you can have offline processing that is dependent on exposure / gain and apply the filters of your choice.
                        • the only down side is that the raw snapshots are huge, but you can probably zip them up if needed to store a lot of them on voxl2 before offloading.
                          @cguzikowski ,
                          I am testing OV64b now. I confirmed that snapshot of size 9216x6944 is not possible (i think i can enable it), but 9248x6944 works.
                          Also, please see this post, there was a bug that broke snapshot in recent releases, which i just fixed. perhaps that was an issue for you when you switched to latest camera server : https://forum.modalai.com/topic/5166/snapshot-crashes-voxl-camera-server
                          I am going to see if i can get MISP running together with ISP snapshot, right now it only runs when preview and misp are disabled and i have small_video and snapshot streams enabled and snapshot resolution set to 9248x6944 and small_video resolution to something smaller.
                            @cguzikowski ,
                            OK, some updates..
                            • the reason why the resolution 9216x6944 was not accepted for snapshot is that the camera pipeline has a list of allowed resolutions and that resolution was not one of them. I could add the resolution 9216x6944 to the list, but actually another resolution (9216x6912) was already supported, so i updated the ov64b driver to include that. The latest driver is available here : https://storage.googleapis.com/modalai_public/temp/ov64b/20260417/ov64b_20260417.zip
                              • this driver has the following resolutions : 9248x6944, 9216x6944 9216x6912 and the other lower resolutions. You can use 9216x6912 since it's compatible with misp and isp snapshot.
                            • I also added 9216x6912 resolution to the supported misp resolutions in camera server (dev branch) as well as allowed using misp with snapshot (previously it would throw an error since we thought that previously they were not compatible).
                            • Actually, snapshot does work with raw_preview + misp, but here is a warning that gets printed continuously:
                            WARNING: preview buffer pool for Cam(hires), Frame(30) has 0 free, skipping request
                            we can work around this warning by adding the following line to the voxl-camera-server.conf for the ov64b camera. this limits the number of buffers that are queued up for the streams and resolves the warning.
                            "max_request_queue_depth": 6,
                            So with these changes, you should be able to use two configurations
                            • preview + raw_preview + misp + snapshot
                            • small_video + snapshot
                            Please use the latest camera server from dev branch.
                            Right now, if you enable misp + small+video + snapshot, it does not work properly, but i will try it figure it out. Here is an example set up for small video + snapshot, but you can easily change it to use misp by disabling small_video and enabling preview + misp (and set auto exposure to "auto" from "isp" (auto will use misp auto exposure)).
                            Please try it out. I do agree that the ISP output has better overall image quality than MISP, also related to pretty significant lens shading of this small lens on ov64b. We will work on improvements of misp image processing.
                            For now, you just need to decide whether you need both RAW bayer and ISP JPG, in which case you cannot use small_video for streaming (until i resolve the issue). This means slightly worse image quality for live streaming. But if you are ok with ISP jpg, you can disable misp and use small_video stream for streaming.
                            By the way, i did not see any artifacts in the jpeg from ISP. Can you please let me know if the artifact is in every frame and where exactly it is located? or is the occurrence and location random?
                                                    "type":                 "ov64b",
                                                    "name":                 "hires",
                                                    "enabled":              true,
                                                    "camera_id":            1,
                                                    "fps":                  30,
                                                    "en_preview":           false,
                                                    "en_misp":              false,
                                                    "preview_width":        9216,
                                                    "preview_height":       6912,
                                                    "en_raw_preview":       true,
                                                    "en_small_video":       true,
                                                    "en_large_video":       false,
                                                    "en_snapshot":          true,
                                                    "ae_mode":              "isp",
                                                    "gain_min":             100,
                                                    "gain_max":             1600,
                                                    "misp_width":           1600,
                                                    "misp_height":          1200,
                                                    "misp_venc_enable":     false,
                                                    "misp_venc_mode":       "h265",
                                                    "misp_venc_br_ctrl":    "cqp",
                                                    "misp_venc_Qfixed":     38,
                                                    "misp_venc_Qmin":       15,
                                                    "misp_venc_Qmax":       50,
                                                    "misp_venc_nPframes":   29,
                                                    "misp_venc_mbps":       30,
                                                    "misp_venc_osd":        false,
                                                    "misp_awb":             "auto",
                                                    "misp_gamma":           1,
                                                    "misp_zoom":            1,
                                                    "ae_desired_msv":       110,
                                                    "exposure_min_us":      20,
                                                    "exposure_max_us":      33000,
                                                    "exposure_soft_min_us": 5000,
                                                    "ae_filter_alpha":      0.6,
                                                    "ae_ignore_fraction":   0.2,
                                                    "ae_slope":     0.05,
                                                    "ae_exposure_period":   1,
                                                    "ae_gain_period":       1,
                                                    "small_video_width":    1600,
                                                    "small_video_height":   1200,
                                                    "small_venc_mode":      "h264",
                                                    "small_venc_br_ctrl":   "cqp",
                                                    "small_venc_Qfixed":    30,
                                                    "small_venc_Qmin":      15,
                                                    "small_venc_Qmax":      40,
                                                    "small_venc_nPframes":  9,
                                                    "small_venc_mbps":      2,
                                                    "en_snapshot_width":    9216,
                                                    "en_snapshot_height":   6912,
                                                    "exif_focal_length":    3.1,
                                                    "exif_focal_length_in_35mm_format":     17,
                                                    "exif_fnumber": 1.24,
                                                    "snapshot_jpeg_quality":        75
                              OK, some updates..
                                                      "type":                 "ov64b",
                                                      "name":                 "hires",
                                                      "enabled":              true,
                                                      "camera_id":            1,
                                                      "fps":                  30,
                                                      "en_misp":              false,
                                                      "ae_mode":              "isp",
                                                      "gain_min":             100,
                                                      "gain_max":             1600,
                                                      "misp_width":           1600,
                                                      "misp_awb":             "auto",
                                                      "misp_gamma":           1,
                                                      "misp_zoom":            1,
                                                      "ae_slope":     0.05,
                              @cguzikowski ,
                              Can you please clarify what you meant by the following statement in your previous post:
                              "Also as a side note, the metadata seems to not be recording when using voxl-record-raw-image -j"
                                @cguzikowski ,
                                FYI the voxl-mpa-tools updates have been merged to dev (including the jpeg saving option and option to save timestamp, exposure, gain in the filename -- i think that is what you were referring to). One small change, the timestamp in the filename changed from milliseconds to microseconds.
                                https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/tree/dev
                                  C Offline
                                  C Offline
                                  cguzikowski
                                  @Alex-Kushleyev I have been doing some tests and the updates to the camera server and mpa tools seem to work great, thank you! What I meant about the metadata not recording is this data only shows up when using the snapshot command, and does not show up when using the jpeg flag in the voxl-record-raw-image command:
                                  Also noticed the auto exposure doesn't seem to settle unless the camera's feed is opened on the voxl-portal. Here are two images I took - voxl-camera-server was running for a considerable time before taking either one.
                                  Before looking at the live stream in the portal:
                                  After looking at the stream in the portal for a few seconds (I could see the exposure settle down)
                                  Didn't mess with voxl-camera-server at all in between taking the two images.
                                  • C cguzikowski
                                    @cguzikowski ,
                                    We can add the jpeg meta to the jpeg file saved from voxl-record-raw-image. which fields specifically are good to have?
                                    Also, regarding the exposure settling - can you please provide the exact configuration you are running? specifically, which are enabled (misp, small_video, snapshot) and is auto exposure set to "isp" or not -- maybe provide a camera server config? When using MISP, i believe there is a case that if none of the streams are being used, the AE won't run, but we can fix this for the case of enabled snapshot.
                                      @cguzikowski ,
                                      C Offline
                                      C Offline
                                      cguzikowski
                                      @Alex-Kushleyev Our application doesn't specifically need the metadata, just figured I should point it out in case it was intended to be there. It may be useful to have shutter speed, ISO, aperture, and date/time though.
                                      Ah yes that seems to be the issue, we are using MISP, preview, and snapshot. It would be useful to have the AE run without us viewing the stream. Here is the conf file:
                                      	"version":	0.1,
                                      	"fsync_en":	false,
                                      	"fsync_gpio":	109,
                                      	"cameras":	[{
                                      			"type":	"boson",
                                      			"name":	"boson",
                                      			"enabled":	true,
                                      			"camera_id":	0,
                                      			"fps":	30,
                                      			"en_preview":	true,
                                      			"en_misp":	true,
                                      			"preview_width":	640,
                                      			"preview_height":	512,
                                      			"en_small_video":	false,
                                      			"ae_mode":	"off",
                                      			"en_rotate":	false,
                                      			"misp_width":	512,
                                      			"misp_height":	640,
                                      			"misp_venc_enable":	true,
                                      			"misp_venc_mode":	"h264",
                                      			"misp_venc_Qfixed":	30,
                                      			"misp_venc_mbps":	2,
                                      			"misp_awb":	"off",
                                      			"misp_gamma":	1,
                                      			"misp_zoom":	1,
                                      			"gain_min":	100,
                                      			"gain_max":	100
                                      			"type":	"ov64b",
                                      			"name":	"hires",
                                      			"enabled":	true,
                                      			"camera_id":	1,
                                      			"fps":	30,
                                      			"en_preview":	true,
                                      			"en_misp":	true,
                                      			"ae_mode":	"isp",
                                      			"gain_min":	100,
                                      			"gain_max":	100,
                                      			"misp_width":	9216,
                                      			"misp_height":	6912,
                                      			"misp_awb":	"auto",
                                      			"misp_gamma":	1,
                                      			"misp_zoom":	1,
                                      			"ae_desired_msv":	75,
                                      			"exposure_min_us":	1000,
                                      			"exposure_max_us":	1001,
                                      			"ae_slope":	0.1,
                                      			"snapshot_jpeg_quality":	90
                                      • C cguzikowski
                                        	"version":	0.1,
                                        	"fsync_en":	false,
                                        	"fsync_gpio":	109,
                                        	"cameras":	[{
                                        			"type":	"boson",
                                        			"name":	"boson",
                                        			"enabled":	true,
                                        			"camera_id":	0,
                                        			"fps":	30,
                                        			"en_preview":	true,
                                        			"en_misp":	true,
                                        			"ae_mode":	"off",
                                        			"en_rotate":	false,
                                        			"misp_width":	512,
                                        			"misp_height":	640,
                                        			"misp_awb":	"off",
                                        			"misp_gamma":	1,
                                        			"misp_zoom":	1,
                                        			"gain_min":	100,
                                        			"gain_max":	100
                                        			"type":	"ov64b",
                                        			"name":	"hires",
                                        			"enabled":	true,
                                        			"camera_id":	1,
                                        			"fps":	30,
                                        			"en_preview":	true,
                                        			"en_misp":	true,
                                        			"ae_mode":	"isp",
                                        			"gain_min":	100,
                                        			"gain_max":	100,
                                        			"misp_width":	9216,
                                        			"misp_awb":	"auto",
                                        			"misp_gamma":	1,
                                        			"misp_zoom":	1,
                                        			"ae_slope":	0.1,
                                        @cguzikowski , got it, thanks for the clarification. I will add a camera server config param that would force the auto exposure to run all the time, regardless of whether the streams are used or not. this should be simple.
                                        Also, i was wondering if you decided that the ISP snapshot is good enough for you or you want to explore saving the RAW bayer and processing offline? We have been experimenting with some approaches for offline processing and I can share some scripts, which have some flexibility on how much to de-noise , sharpen, etc. I am also going to add the LSC (lens shading correction) for the offline processing (and later into real-time misp pipeline) to correct for those artifacts that you saw where the colors change across the image.
                                          C Offline
                                          C Offline
                                          cguzikowski
                                          #28
                                          @Alex-Kushleyev Sorry for the delayed response, but I believe the ISP snapshots are good enough quality for us, but could I still get the scripts to mess around and test with?
                                          Also is the most recent camera server here the version with the auto-auto exposure? If so, what is the parameter to use to activate that?
