  2. FPV Drones
  3. Stinger & Hadron 640r
Scheduled Pinned Locked Moved FPV Drones
7 Posts 2 Posters 3.2k Views 2 Watching
  • D Offline
    D Offline
    dstylesunf
    Is it possible to add a Hadron 640r to the Stinger? I know there are additional boards needed but is there space to add them to the Voxl2 Mini? Specficially the camera board? Also, how do I go about getting extra parts like screws, standoffs and carbon fiber frame?
    • D dstylesunf
      @dstylesunf ,
      M0188 does not have support for the Boson part of the Hadron (mainly difference in power requirements)
      However, M0195 supports Boson, which means you can also plug in the Hadron by using M0202 (or older M0159) adapter instead of M0201 (which would be used for Boson). The RGB Camera inside Hadron (which is OV64B) would be treated as an independent hires camera.
      Basically, M0202 (M0159) plugs into the back of Hadron docs and then on the other end you could connect both coax cables to M0181 straight into VOXL2 mini or using M0195 instead of M0181.
      You can also use M0194 adapter for connecting Hadron to VOXL2 mini. In the diagram above, a Boson with a high-res camera is shown, but you can replace Boson+M0201+hires with Hadron + M0202, which would plug into M0194:
      M0194 Boson + Hires Connection Example
      M0195, however, would allow you to connect one extra camera (if you are using a dual tracking camera setup) compared to individual adapters plugged in to VOXL2 J6 and J7.
      Please let us know if you have any other questions.
      D 1 Reply Last reply
      -1
        @dstylesunf ,
        D Offline
        D Offline
        dstylesunf
        @Alex-Kushleyev how do I go about buying replacement parts for the Stinger and the additional boards and cables to add the Hadron 640r?
        • D dstylesunf
          @dstylesunf , sorry for the delay. In order to buy a M0202 + M0194 + cables kit for Hadron, please send us an request : https://www.modalai.com/pages/contact-us
          Same for any replacement parts for stinger you might need, they are not up in the shop yet.
          • D Offline
            D Offline
            dstylesunf
            I have received the M0202 that goes to the M0181 via the pre-installed coax. I also received the M0194. What does the diagram look like with these boards to connect to the M0188 board on the stinger to keep the functionality of the dual tracking camera and front fpv camera? I also received a MCBL-00104-1 usbA to Boson RHP. What is this for?
            • D dstylesunf
              @dstylesunf ,
              Please check my post from January, which states that M0188 does not support a Boson sensor and you need M0195 if you want a drop-in replacement for M0188.
              https://docs.modalai.com/M0188/
              https://docs.modalai.com/M0195/
              Can you double check what you have plugged into your voxl2 mini?
              You can remove M0188 and install M0194 (which you have) as another option. You would need to transfer the ucoax connections from M0181 to M0194. The diagram above in this post shows you how to connect Boson and hires camera (essentially a Hadron combo) using M0194 to a voxl2 mini. Do you need more details on this connection?
              If you use the second option, you would lose the dual tracking capability though.
                @dstylesunf ,
                With M0195, C34 is the camera configuration that you would need. See https://docs.modalai.com/M0195/#support-camera-configs
