  3. tarling - Path planning (blue line) is erratic and drone moves to wrong locations
19 Posts 2 Posters 2.9k Views
  • Cliff WongC Cliff Wong
    @DronAlan Hi there,
    Seeing the opposite direction that looks like a 100% 180 rotation is typically a sign of a reset while powering up: incorrectly detects the gravity vector. This is a common anomaly with qvio. I suggest at power up, immediately put the drone on the ground and try not to move the drone until takeoff. Try this and see if you get consistency. QVIO is sensitive to resets prior takeoff. You can edit the following in /etc/modalai/voxl-vision-hub.conf:
            "en_reset_vio_if_initialized_inverted": false,
    if your use case doesn't allow this type of procedure, you can ssh onto the drone and force reset before every takeoff by running: systemctl restart voxl-qvio-server.
    If you have not edited the extrinsic settings from factory then I would safely assume they are correct, but in case, extrinsics are stored in /etc/modalai/extrinsics.conf where you'd look for the body to imu parameter section (which should be 0,0,0 in starling's case).
    Note: these types of anomalies have been corrected in SDK 1.6.x, as the latest SDK now defaults to the new & improved openvins VIO subsystem if you're inclined to upgrade (recommended, though any custom-external apps make need to be recompiled as the MPA API has changed).
    D Offline
    D Offline
    DronAlan
    @Cliff-Wong
    Thank you for the detailed response and suggestions. I have carefully followed all the steps you mentioned, but unfortunately, the issue persists.
    Here is what I did:
    1. I edited /etc/modalai/voxl-vision-hub.conf to set the reset parameter to false. Here is my current file:
    "config_file_version": 1,
    "en_localhost_mavlink_udp": false,
    "localhost_udp_port_number": 14551,
    "en_vio": true,
    "vio_pipe": "qvio",
    "secondary_vio_pipe": "ov",
    "vfc_vio_pipe": "ov",
    "vio_warmup_s": 3,
    "send_odom_while_failed": true,
    "horizon_cal_tolerance": 0.5,
    "en_hitl": false,
    "offboard_mode": "trajectory",
    "follow_tag_id": 0,
    "figure_eight_move_home": true,
    "robot_radius": 0.300000011920929,
    "collision_sampling_dt": 0.1,
    "max_lookahead_distance": 1,
    "backtrack_seconds": 60,
    "backtrack_rc_chan": 8,
    "backtrack_rc_thresh": 1500,
    "wps_move_home": true,
    "wps_stride": 0,
    "wps_timeout": 0,
    "wps_damp": 1,
    "wps_vfc_mission": true,
    "wps_vfc_mission_loop": false,
    "wps_vfc_mission_to_ramp": 25,
    "wps_vfc_mission_to_kp": 0.10000000149011612,
    "wps_vfc_mission_cruise_speed": 1,
    "en_tag_fixed_frame": false,
    "fixed_frame_filter_len": 5,
    "en_transform_mavlink_pos_setpoints_from_fixed_frame": false,
    "vfc_rate": 100,
    "vfc_rc_chan_min": 980,
    "vfc_rc_chan_max": 2020,
    "vfc_thrust_ch": 3,
    "vfc_roll_ch": 1,
    "vfc_pitch_ch": 2,
    "vfc_yaw_ch": 4,
    "vfc_submode_ch": 6,
    "vfc_alt_mode_rc_min": 0,
    "vfc_alt_mode_rc_max": 0,
    "vfc_flow_mode_rc_min": 0,
    "vfc_flow_mode_rc_max": 0,
    "vfc_hybrid_flow_mode_rc_min": 0,
    "vfc_hybrid_flow_mode_rc_max": 0,
    "vfc_position_mode_rc_min": 0,
    "vfc_position_mode_rc_max": 2100,
    "vfc_traj_mode_rc_min": 0,
    "vfc_traj_mode_rc_max": 0,
    "vfc_yaw_deadband": 30,
    "vfc_vxy_deadband": 50,
    "vfc_vz_deadband": 150,
    "vfc_min_thrust": 0,
    "vfc_max_thrust": 0.800000011920929,
    "vfc_tilt_max": 0.43599998950958252,
    "vfc_yaw_rate_max": 3,
    "vfc_thrust_hover": 0.5,
    "vfc_vz_max": 1,
    "vfc_kp_z": 5.2899999618530273,
    "vfc_kd_z": 5.9800000190734863,
    "vfc_vxy_max": 3,
    "vfc_kp_xy": 0.63999998569488525,
    "vfc_kd_xy": 2.559999942779541,
    "vfc_kp_z_vio": 5.2899999618530273,
    "vfc_kd_z_vio": 5.9800000190734863,
    "vfc_kp_xy_vio": 3.2400000095367432,
    "vfc_kd_xy_vio": 3.9600000381469727,
    "vfc_w_filt_xy_vio": 10,
    "vfc_w_filt_xy_flow": 3,
    "vfc_vel_ff_factor_vio": 0.899999976158142,
    "vfc_xy_acc_limit_vio": 2.5,
    "vfc_max_z_delta": 3,
    "vfc_att_transition_time": 0.5,
    "vfc_stick_move_threshold": 30,
    "vfc_flow_transition_time": 1,
    "vfc_q_min": 10,
    "vfc_points_min": 7,
    "vfc_en_submode_announcement": 1,
    "vfc_disable_fallback": false,
    "vfc_traj_csv": "/data/voxl-vision-hub/traj.csv",
    "en_voa": true,
    "voa_upper_bound_m": -0.15000000596046448,
    "voa_lower_bound_m": 0.15000000596046448,
    "voa_voa_memory_s": 1,
    "voa_max_pc_per_fusion": 100,
    "voa_pie_max_dist_m": 20,
    "voa_pie_min_dist_m": 0.25,
    "voa_pie_under_trim_m": 1,
    "voa_pie_threshold": 3,
    "voa_send_rate_hz": 20,
    "voa_pie_slices": 36,
    "voa_pie_bin_depth_m": 0.15000000596046448,
    "voa_inputs": [{
    "enabled": false,
    "type": "point_cloud",
    "input_pipe": "dfs_point_cloud",
    "frame": "stereo_l",
    "max_depth": 8,
    "min_depth": 0.300000011920929,
    "cell_size": 0.079999998211860657,
    "threshold": 4,
    "x_fov_deg": 68,
    "y_fov_deg": 56,
    "conf_cutoff": 0
    "enabled": false,
    "input_pipe": "stereo_front_pc",
    "frame": "stereo_front_l",
    "max_depth": 8,
    "threshold": 4,
    "x_fov_deg": 68,
    "y_fov_deg": 56,
    "conf_cutoff": 0
    "enabled": false,
    "input_pipe": "stereo_rear_pc",
    "frame": "stereo_rear_l",
    "max_depth": 8,
    "threshold": 4,
    "x_fov_deg": 68,
    "y_fov_deg": 56,
    "conf_cutoff": 0
    "enabled": true,
    "type": "tof",
    "input_pipe": "tof",
    "frame": "tof",
    "max_depth": 6,
    "min_depth": 0.15000000596046448,
    "threshold": 3,
    "x_fov_deg": 106.5,
    "y_fov_deg": 85.0999984741211,
    "conf_cutoff": 125
    "enabled": false,
    "type": "rangefinder",
    "input_pipe": "rangefinders",
    "frame": "body",
    "max_depth": 8,
    "threshold": 4,
    "x_fov_deg": 68,
    "y_fov_deg": 56,
    "conf_cutoff": 0
    2. I forced the VIO reset right before takeoff.
    I ran systemctl restart voxl-qvio-server via SSH just as you suggested, keeping the drone perfectly still on the ground.
    3. I verified the extrinsics settings.
    I checked /etc/modalai/extrinsics.conf and confirmed that the body to imu parameter is indeed [0, 0, 0].
    Here is my current extrinsics file:
    "name": "starling_v2_voxl2",
    "extrinsics": [{
    "parent": "imu_apps",
    "child": "tracking",
    "T_child_wrt_parent": [0.0229, 0.006, 0.023],
    "RPY_parent_to_child": [0, 45, 90]
    "parent": "body",
    "child": "imu_apps",
    "T_child_wrt_parent": [0.0407, -0.006, -0.0188],
    "RPY_parent_to_child": [0, 0, 0]
    "parent": "body",
    "child": "tof",
    "T_child_wrt_parent": [0.068, -0.0116, -0.0168],
    "RPY_parent_to_child": [0, 90, 180]
    "parent": "body",
    "child": "lepton0_raw",
    "T_child_wrt_parent": [-0.06, 0, 0.01],
    "RPY_parent_to_child": [0, 0, 90]
    "parent": "body",
    "child": "ground",
    "T_child_wrt_parent": [0, 0, 0.0309],
    Despite doing all of this, the 180-degree rotation (mirror effect) is still happening.
    Given that these steps didn't resolve the issue and you mentioned that these anomalies have been corrected in newer versions, would you recommend that my best course of action right now is to flash the drone and upgrade to SDK 1.6.x (or newer) to use the new OpenVINS subsystem?
    I would also appreciate it if you could take a look at the files I sent you in this message to make sure everything is correct.
    One more thing:
    Looking at my SKU (MRB-D0005-4-V2...), is it possible that the tracking camera or the IMU was physically mounted 180° rotated at the factory?
    If this is a known hardware discrepancy for this specific batch, should I manually compensate for it in the extrinsics or will the SDK 1.6.x upgrade fix it automatically?
    Thanks again for your help!
      @DronAlan Hi there,
      D Offline
      D Offline
      DronAlan
      @Cliff-Wong please response
      • D DronAlan
        Cliff WongC Offline
        Cliff WongC Offline
        Cliff Wong
        wrote on last edited by Cliff Wong
        #11
        @DronAlan Hi there, when the camera was rotated 180, you'll have stable take off behavior, but any XY movement would cause the drone to 'fly away' quickly.
        Taking a step back with your concerns on physical mounts:
        1. checking camera orientation:
          a. bring up the front camera in portal: it should be upright orientation, e.g. top of the camera image should be from the top of the drone itself ("tops are aligned").
        2. Since you are using qvio, only 1 camera is supported. Ensure in /etc/modalai/vio_cams.conf has tracking_down disabled, It's a safeguard if qvio is accidentally using that camera (would would lead to a orientation problem).
        As for IMU, the voxl2 unit should have the USB-C port facing the bottom/ground side (and WiFi dongle on the top side). Let's force reset the imu calibration. If you run on the drone voxl-calibrate-imu and follow the directions, will reset the imu.
        Let's check these items. If they all pass and still presents the orientation problem, then it's worth moving to the SDK1.6.3 to take advantage of the advanced config installer.
        D 3 Replies Last reply
          D Offline
          D Offline
          DronAlan
          @Cliff-Wong said in tarling - Path planning (blue line) is erratic and drone moves to wrong locations:
          Hi there, thanks for the detailed suggestions!
          I have gone through all your steps to discard physical and configuration issues, but it seems I'll need to upgrade. Here is the checklist of what I tested:
          1. Camera orientation: I checked the front camera in voxl-portal and it is completely upright (tops are aligned, ceiling is up, floor is down).
          2. Physical mounts: The VOXL 2 unit is mounted correctly from the factory (USB-C port facing the ground, WiFi dongle on the top side).
          3. IMU Calibration: I ran a full 6DOF voxl-calibrate-imu on a flat surface. It completed successfully, and voxl-inspect-imu shows perfect readings now (X and Y at ~0.00, and Z gravity at exactly -9.80).
          4. VIO config: I checked /etc/modalai/vio_cams.conf. tracking_down is disabled/not present, and it is only using the front camera as expected. Here is my exact configuration:
          "cams": [{
          "enable": true,
          "name": "tracking",
          "pipe_for_preview": "tracking",
          "pipe_for_tracking": "tracking",
          "is_occluded_on_ground": false,
          "imu": "imu_apps",
          "cal_file": "opencv_tracking_intrinsics.yml"
          Since all physical and configuration checks passed perfectly, I am going to follow your advice and proceed to flash SDK 1.6.3 to take advantage of the advanced config installer and move to OpenVINS.
          Thanks again for the help, I'll keep you posted on how the 1.6.3 update goes!
            D Offline
            D Offline
            DronAlan
            @Cliff-Wong
            I have just updated to SDK 1.6.3 doing a complete wipe and applying the factory configuration, but the drone is still executing the trajectory in reverse/backwards. I really don't know what else to try at this point. Any ideas on what could be causing this inverted behavior despite the clean install?
              D Offline
              D Offline
              DronAlan
              I am experiencing a severe issue with trajectory execution in the SLAM/Mapper mode where the drone exhibits an inverted and cumulative 'mirror' behavior regarding position setpoints.
              As shown in the attached image:
              1. If I set a first waypoint directly in front of the drone (1st Point), the drone flies backward instead, covering the intended distance but in the exact opposite direction.
              2. From that new incorrect position, if I command the drone to return backward by the same distance (2nd point, aiming to return to the original starting location), the drone does not return. Instead, it flies forward, doubling the distance in the opposite direction from the newly commanded point.
              It appears as though the drone is accumulating a starting error or interpreting the coordinate frame in a completely mirrored way (FRD vs NED mismatch), where both the direction and the origin reference point are inverted. The dashed lines in the image represent the intended path, while the solid arrows represent the actual path flown. I am on SDK 1.6.3 with factory settings.
              • D DronAlan
                @Cliff-Wong
                Cliff WongC Offline
                Cliff WongC Offline
                Cliff Wong
                #15
                @DronAlan With 1.6.3 SDK upgrade, did you test against the figure 8/offboard mode? Also flying in position mode after drawing the trajectory, if you manually fly the path you created, does the drone follow correctly? If position mode manual flying is working fine and figure 8/offboard mode is working fine (a clockwise figure 😎 then we have a trajectory calculation problem on the voxl-mapper side (I'll check our code, but our QA currently show that was working properly).
                Since you're using OpenVINS vio module now, there's an unlikely chance of a reset causing a 180 orientation change by design. Also make sure qvio is disabled. You can check if it's running via voxl-inspect-services and run systemctl disable voxl-qvio-server (+reboot).
                D 1 Reply Last reply
                  D Offline
                  D Offline
                  DronAlan
                  @Cliff-Wong
                  "en_vio": true,
                  "vio_pipe": "qvio",
                  "vio_warmup_s": 3,
                  "en_hitl": false,
                  "offboard_mode": "figure_eight",
                  "follow_tag_id": 0,
                  "wps_stride": 0,
                  "wps_timeout": 0,
                  "wps_damp": 1,
                  "tracking_trigger_ch": 12,
                  "tracking_trigger_ch_thresh_temp": 1200,
                  "tracking_trigger_ch_thresh_new": 1800,
                  "en_voa": true,
                  "voa_inputs": [{
                  "enabled": true,
                  "max_depth": 8,
                  "threshold": 4,
                  "x_fov_deg": 68,
                  "y_fov_deg": 56,
                  "conf_cutoff": 0
                  "enabled": true,
                  "max_depth": 8,
                  "threshold": 4,
                  "x_fov_deg": 68,
                  "y_fov_deg": 56,
                  "conf_cutoff": 0
                  "enabled": true,
                  "max_depth": 8,
                  "threshold": 4,
                  "x_fov_deg": 68,
                  "y_fov_deg": 56,
                  "conf_cutoff": 0
                  "enabled": true,
                  "type": "tof",
                  "frame": "tof",
                  "max_depth": 6,
                  "threshold": 3,
                  "x_fov_deg": 106.5,
                  "conf_cutoff": 125
                  "enabled": true,
                  "frame": "body",
                  "max_depth": 8,
                  "threshold": 4,
                  "x_fov_deg": 68,
                  "y_fov_deg": 56,
                  "conf_cutoff": 0
                  this is my /etc/modalai/voxl-vision-hub.conf, what should i change????
                  • Cliff WongC Offline
                    Cliff WongC Offline
                    Cliff Wong
                    Hi there, just to confirm: does flying manually in position mode work and follows the XYZ position in voxl-portal's VIO page. as well as follows figure 8 mode too? This will confirm the vio pose estimate is correct and more of a issue on mapper.
                      D Offline
                      D Offline
                      DronAlan
                      @Cliff-Wong Yes, I can confirm that flying manually in Position mode works correctly and accurately follows the XYZ coordinates shown in the voxl-portal VIO page. Additionally, the drone successfully performs the figure 8 trajectories in offboard mode as expected.
                      • D DronAlan
                        Cliff WongC Offline
                        Cliff WongC Offline
                        Cliff Wong
                        #19
                        @DronAlan
                        Hi there, the configuration & extrinsics files look fine (just switch offboard mode from figure_eight back to trajectory mode. Since you confirmed figure 8 and position mode are working fine and reflect true ground truth in voxl portal, next is to dive a bit deep into the processes:
                        Just to confirm: are you using a loaded saved map? Orientation can be different in a loaded maps based on how it was saved. Going forward in debugging this I would create the map while flying, then test plan-to-point to ensure it is working properly.
                        • Before take off, if you ssh onto the drone and run voxl-vision-hub --debug_offboard and rerun the mapping test (point 1m in front of the drone hovering), and you don't need to map the entire room, just get the general area.
                        • In the ssh session, monitor the output from voxl-vision-hub.
                        • Take off and fly forward and backward in position mode, with some slight yaw motions to generate a decent map in voxl portal (recall we're generating a map in flight then plan to fly to a point, not using a old-saved map).
                        • Then switch into trajectory mode. In the ssh session, you should get a Received trajectory has duration message printed.
                        • Goto voxl-portal and plan-a-point. Then execute go-to-point. In the ssh session you should get a Received insert command. printed out on the terminal. And it will show the drone's forward commands, i..e set points, to your planned point. I expect the commanding: XYZ values to increase in the positive X direction. Please post the output of the ssh session here.
                        If the drone moves in the backwards direction as you've been seeing but the commanding XYZs are moving forward, we have found our problem (PX4 issue such that I'll need your params file). If the drone moves forward with commanding XYZs are moving forward then it's how your older maps are being saved and we can go from there.
