    HDMI output from Seeker Vision FPV Goggles
    FPV Drones
    • David AveryD
      David Avery
      I need to get some instructions on how to plug in a USB-C to HDMI adapter to the Seeker Vision FPV Blue goggles received with our Stinger Vision 3.5 FPV kit, for exporting the video stream to external viewers: Can someone please send me a PDF or short written instructions on where on the VRX/Orga goggles set to plug the adapter into, along with any change in settings or other setup items to view the FPV video, like you did when our technical team came to your facility last fall to see your demonstrations?
        tom admin @David Avery
        @David-Avery See the following graphic. 8517d647-3a1b-452f-a269-b8e123b63957-image.png
        You can connect a USB-C to hdmi adapter to the USB-C labeled "DisplayPort Out"
        I recommend using the following adapter: https://www.amazon.com/Cable-Matters-48Gbps-Adapter-Supporting/dp/B08MSWMXT4?th=1
        No software configuration changes are needed.
        David AveryD 1 Reply Last reply Reply Quote 1
        • David AveryD
          David Avery @tom
          @tom Thank you!
