    Starling 2 / VOXL2 M0129 ESC not detected during voxl-esc scan or firmware upgrade
    ESCs
    • syamala kotireddyS
      syamala kotireddy
      Hi ModalAI team,
      I am working on a Starling 2 / VOXL2 setup and I am stuck with an ESC communication / firmware issue. I would appreciate your guidance on whether this looks like a software mismatch, a known M0129 compatibility issue, or a hardware-side comms problem.
      Hardware / platform:
      • VOXL2 (M0054)
      • Starling 2 platform
      • ESC board label: M0129
      • SKU shown on device:
        MRB-D0014-4-V1-C27-T9-M22-X0
      Current software versions:
      • system-image: 1.8.06-M0054-14.1a-perf
      • voxl-suite: 1.6.3
      • voxl-esc package manually upgraded from 1.5.7 to 1.6.1
      What I did:
      1. Reflashed the board
      2. Restored / checked calibration as needed
      3. Verified Wi-Fi and internet access
      4. Confirmed newer voxl-esc was available in sdk-1.6 and manually installed:
        dpkg -i /data/voxl-esc_1.6.1_arm64.deb
      5. Checked available firmware files under:
        /usr/share/modalai/voxl-esc-tools/firmware/
      Firmware files present for M0129:
      • modalai_esc_firmware_m0129_3_v39_25_a58f5f6f.bin
      • modalai_esc_firmware_m0129_6_v39_25_a58f5f6f.bin
      Note:
      • My physical ESC only says M0129
      • I do not see a suffix like M0129-3 or M0129-6 printed on the board
      • I also do not see an m0129_1 firmware file in the installed firmware folder
      Main issue:
      • voxl-esc scan does not reliably detect any ESCs
      • voxl-esc upgrade_firmware sometimes previously said “successfully pinged ESCs” but then failed with:
        [ERROR] Unknown board detected:
      • After deeper testing, the underlying Python tools also fail to detect the ESC consistently
      Direct tool results:
      1. voxl-esc-scan.py
      • No ESCs detected at all baud rates
      • Sometimes reports:
        ERROR: voxl_uart_read_bytes: Bus '12' is not initialized
      1. voxl-esc-board-detect.py
      • Ends with:
        ERROR: No ESC(s) detected, exiting.
      1. Debug scan:
        Command used:
        python3 voxl-esc-scan.py --enable-debug True --force-scan-all-baud-rates True
      Observed behavior:
      • UART TX packets are clearly being sent
      • No valid UART RX from ESC
      • In one case RX was all zeros after:
      • Every scan ends with:
        WARNING: No ESC(s) detected
        ERROR: not all ESCs found
      Relevant logs:
      • dmesg shows SLPI restart events after reset commands, for example:
        Fatal error on slpi!
        ... Got kill command from apps processor.
      • /dev shows SLPI subsystem nodes, but the scan path still fails to get a valid ESC reply
      Important observations:
      • The VOXL side appears to be transmitting on the ESC link
      • The ESC side does not appear to respond
      • This now looks more like a low-level comms / wiring / power / bootloader issue than just a wrapper-script issue
      Questions:
      1. Is system-image 1.8.06 with voxl-suite 1.6.3 a supported combination for Starling 2 + M0129 ESC?
      2. For an ESC labeled only “M0129”, which firmware should be used:
        • m0129_3
        • m0129_6
        • or is there another variant / package expected?
      3. Is the missing response from the ESC more indicative of:
        • incorrect harness / connector / pinout
        • ESC not powered correctly
        • damaged ESC MCU
        • wrong firmware / bootloader state
      4. Is there a recommended low-level recovery path for M0129 when voxl-esc-scan.py cannot detect any ESCs?
      5. Are there any additional commands you want me to run to verify the ESC UART / SLPI bridge path on this platform?
      Example command outputs:
      system image / suite:
      • voxl-suite: 1.6.3
      voxl-esc version after manual install:
      • 1.6.1
      Direct scan result:
      • WARNING: No ESC(s) detected
      • ERROR: not all ESCs found
      Direct board detect result:
      • ERROR: No ESC(s) detected, exiting.
      Any help would be greatly appreciated. I can also provide full logs or photos of the ESC board/harness if needed.
      Thank you.
        Alex Kushleyev ModalAI Team @syamala kotireddy
        @syamala-kotireddy ,
        If your M0129 ESC only has a label that says M0129, it most likely means it is M012-3. The only difference between -3 and -6 is that -6 is rated for 6S battery voltage (which is irrelevant for Starling 2).
        Was the ESC working? How did it get into non-working state?
        Please make sure PX4 is not running before you use the voxl-esc tools : systemctl stop voxl-px4. You should reboot, disable voxl-px4 and try to use voxl-esc tools directly from /usr/share/modalai/voxl-esc/
        In order to test if the ESC itself is working, the best way to connect it directly to a Linux PC using a serial-to-usb adapter and use voxl-esc to scan, test, etc. You can make your own adapter or purchase one here.
        Also, double check if the status of ESC LEDs when you turn on the power. Additionally, does the ESC make motor sounds? See additional debugging information here : https://docs.modalai.com/voxl-escs/faq/
        syamala kotireddyS 1 Reply Last reply Reply Quote 0
          syamala kotireddy @Alex Kushleyev
          @Alex-Kushleyev Hi Alex,
          Thanks for your response.
          To answer your question - the ESC does not appear to be booting at all.
          I tested the ESC independently:
          • Connected battery directly to ESC (no VOXL connected)
          • There are no motor tones and no visible LED activity
          Additionally:
          • voxl-esc-scan.py does not detect any ESCs at any baud rate
          • UART debug shows TX packets being sent but no valid RX response
          • SLPI reports “Bus 12 not initialized”
          Since the ESC does not produce any startup tones even when powered directly, it seems the ESC MCU is not booting.
          Could this indicate a hardware failure of the ESC logic section?
          Please let me know if you would still recommend testing via USB-to-serial, or if this is sufficient to consider the ESC faulty.
          Koti.
