  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. Trigger Hadron camera with DO_SET_CAM_TRIGG_DIST
6 Posts 2 Posters 994 Views 1 Watching
  • R Offline
    R Offline
    restore
    I have a VOXL2 running ardupilot and have a Hadron camera connected and configured with voxl-camera-server. I can take snapshots successfully.
    I am trying to configure our drone to capture images at a specific distance interval during flight with the DO_SET_CAM_TRIGG_DIST parameter. Is there a way to do this with VOXL2 and ardupilot?
    • R restore
      @restore I don't think this is possible today. How did you set it up to take the snapshot? How is it triggered?
      R 1 Reply Last reply
        R Offline
        R Offline
        restore
        @Eric-Katzfey We have the Hadron configured with voxl-camera-server.conf
        "type": "ov64b",
        "name": "hires",
        "en_snapshot": true,
        so we can take images with voxl-send-command hires_snapshot snapshot
        I would love to configure the camera in Ardupilot with CAM1_TYPE and set DO_SET_CAM_TRIGG_DIST to a distance interval that I will capture images at.
        If that is not directly possible, could you help me with a way to create a sort of interface script that sits on VOXL2 that listens for GPIO relay triggers or something like that? Then I can just call the snapshot command when triggered.
        • R restore
          "type": "ov64b",
          "name": "hires",
          @restore Are there any Mavlink messages coming out of ArduPilot that you could use to know when to take the snapshot? If so, create a new application that listens, via voxl-mavlink-server, to Mavlink and the message(s) you need. Then trigger the snapshot when it's needed. ArduPilot's external interface is Mavlink so it would be good to leverage Mavlink messages for this.
            R Offline
            R Offline
            restore
            @Eric-Katzfey I configured the drone to have servo5 trigger the camera. When idle, servo 5 shows 1100. When triggered, it goes up to 1300. In the Mavlink messages I can now watch for SERVO_OUTPUT_RAW msg.servo5_raw and detect the rising edge which emulates the trigger.
            msg = master.recv_match(type='SERVO_OUTPUT_RAW', blocking=True, timeout=2)
            if not msg:
                continue
            pwm = msg.servo5_raw
            I have done this on a ground station using pymavlink to listen for messages. What is the best way to listen for this mavlink message on the VOXL2? Reminder - I am using Ardupilot.
            • R restore
              if not msg:
                  continue
              @restore There are a few examples of code that listens for Mavlink messages in our SDK. For example, in voxl-mpa-tools, take a look at the source code for voxl-inspect-mavlink.c. https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/blob/master/tools/voxl-inspect-mavlink.c?ref_type=heads
              Probably would be a good idea to run voxl-inspect-mavlink on the mavlink_onboard and mavlink_to_gcs pipes to see which one has the desired Mavlink message in it. Then create your own application that listens for the Mavlink message on that pipe.
