  3. VOXL2 Mini – Royale createDevice failed when starting ToF camera
4 Posts 2 Posters 399 Views 1 Watching
  • P Offline
    P Offline
    Piyush Singh
    wrote on last edited by Piyush Singh
    Hi ModalAI team,
    I am working with a VOXL2 Mini test fixture (TF-M0104) and encountering an issue when starting the ToF camera.
    The voxl-camera-server starts successfully and all cameras initialize, but it crashes when the ToF bridge attempts to initialize the Royale device.
    Additional details:
    • Platform: VOXL2 Mini (TF-M0104)
    • Camera server starts all 4 cameras
    • The crash occurs right after the ToF bridge initialization.
    Could you please advise what might cause Royale createDevice to fail in this situation?
    I have attached a screenshot of the full terminal output for reference.
    Thanks in advance for your help.
    • P Piyush Singh
      Hi ModalAI team,
      Additional details:
      @Piyush-Singh ,
      Which TOF sensor do you have plugged into VOXL2 Mini (there are two options) and what is the camera type listed for the TOF entry in voxl-camera-server.conf? there may be a mismatch..
      Config file TOF options are :
      • pmd-tof for the (EOL) TOF V1 : https://docs.modalai.com/M0040/
      • pmd-tof-liow2 for the new TOF V2 : https://docs.modalai.com/M0169/ (https://docs.modalai.com/M0178/) - two different variants that differ in the connector type that connects them to VOXL2
      P 1 Reply Last reply
        @Piyush-Singh ,
        P Offline
        P Offline
        Piyush Singh
        @Alex-Kushleyev I am using second one i.e. TOF V2 and defined it in custom_camera_config.txt file as given below:
        • P Piyush Singh
          @Piyush-Singh , can you please provide more details
          • how exactly all cameras are connected to VOXL2 mini (including interposers, flexes), etc. A diagram would help a lot
          • which kernel variant are you running on your voxl2 mini (2.0.0 or 2.0.2).
          Are all the other cameras working if you disable the TOF sensor in the camera server config?
