  3. autonomy stack
autonomy stack
3 Posts 2 Posters 331 Views 1 Watching
  • Gad LevinG Offline
    Gad LevinG Offline
    Gad Levin
    wrote on last edited by Gad Levin
    Hi everyone, I’m relatively new to the VOXL ecosystem and I’ve been trying to set up a workflow to develop and test changes to the voxl-vision-hub autonomy stack without flying a real vehicle.
    i loaded the qti-ubuntu-m0054-docker.tar image and get a shell inside the container and installed the voxl-suite to get all the services (sw)...
    I understand that the vision hub contains autonomy examples such as the Figure-8 demo and other tasks and that it interacts with PX4 via MAVLink.
    My main goal is to run SITL (Software-in-the-Loop) so that I can test changes to the autonomy behaviour in a simulated environment , ideally with PX4 SITL, FlightGear (or another simulator), and the vision hub all working together.
    This leaves me a bit confused about the recommended way to set up simulation for autonomy development when not using ROS. Specifically:
    Can voxl-vision-hub interact with a PX4 SITL instance running on a host machine?
    If so, what is the recommended setup and how do I link MAVLink traffic between the host SITL and the container on VOXL2?
    Or is the supported path something like HITL only?
    Thanks in advance for any guidance , I’m just getting started with this stack and would appreciate pointers to the best practices or examples.
    • Gad LevinG Gad Levin
      Eric KatzfeyE Online
      @Gad-Levin We generally use HITL. There is some documentation here: https://docs.modalai.com/voxl2-PX4-hitl/. This is the repo with the most up to date HITL driver for VOXL: https://github.com/modalai/px4-firmware/tree/voxl-fpv-dev. There is some more info in the HITL driver README: https://github.com/modalai/px4-firmware/blob/voxl-fpv-dev/boards/modalai/voxl2-slpi/src/drivers/dsp_hitl/README.md. I'm sure there's some outdated / incomplete information in those documents but it should give you a pretty good starting spot. This is the cable I use: https://www.sparkfun.com/usb-to-ttl-serial-cable.html
        @Eric-Katzfey And this is also handy: https://www.sparkfun.com/breadboard-to-jst-ghr-04v-cable-4-pin-x-1-25mm-pitch.html
