  3. Unable to unbrick ModalAI Voxl m500
7 Posts 4 Posters 1.5k Views 3 Watching
  • A Offline
    ashwin-umdlife
    Hello there,
    One of our ModalAI drones is bricked and we are unable adb shell into the device. Following the instruction to unbrick given here, I am unable to find device upon sudo fastboot devices.
    Here are the instructions we followed to unbrick the device:
    • Power off the VOXL
    • Detach VOXL USB cable (to ensure USB is not supplying any power VOXL)
    • Attach the USB Expander and Debug Add-On board
    • Ensure the FASTBOOT labeled switch is set to on
    • Ensure the EMERG BOOT labeled switch is set to off
      NOTE: if your board is missing the EMERG BOOT switch, this is OK as its default un-populated state is OFF
    • Power on the VOXL
    • Reattach VOXL USB cable
    • After VOXL boots up (about 5 seconds), set the FASTBOOT back to off
    Here is a video of the attempt https://youtu.be/BDEEefeVZ20
    Please let us know if we have missed any steps. Thank you.
    Ashwin Sushil
    • modaltbM Offline
      modaltbM Offline
      modaltb
      Hi @ashwin-umdlife ,
      Sorry this post is shown as 'deleted' for some reason, testing a response.
      • modaltbM Offline
        modaltbM Offline
        modaltb
        I un-deleted this post, I'm not sure if you meant to delete but was asked from our contact email to look at this post.
        OK, I think we have some timing issues possibly happening here.
        Let's work through this and see if we need to update our documentation.... there's a couple scenarios to work through so it's a little tricky.
        The idea here is that we want to mimic "holding down the volume-down key while powering on a phone and letting go right after you power on" and then run the command.
        So, let's try this:
        • have m500 powered off
        • have fastboot switch turned ON
        • have USB cable connected to m500, not the host (because VOXL can get a little power from USB, but not enough to boot)
        • have your terminal open and ready with sudo fastboot devices command waiting
        Now:
        • plug USB power in
        • power on m500
        • turn fastboot switch off and quickly run the command (hit ENTER on the terminal that has the command waiting)
        Repeat this several times if possible. If we ever detect a device in fastboot mode then we can next attempt to update the system image.
        • A Offline
          ashwin-umdlife
          wrote on last edited by ashwin-umdlife
          @modaltb I deleted this post because I figure out the usb should be connected to the voxl board and not the expansion board. Thank you making this clear. I see that there is a video made by your team explaining the unbricking procedure. It will be great if you could add it in the office modalai unbricking documentation.
          • Roman RempelR Offline
            Roman Rempel
            @modaltb
            Hey!
            i also try to unbrick my VOXL
            adb - does not work
            but the fastboot sees the device
            Tell me how to properly flash system image using fastboot
              Can you please see try this post? https://forum.modalai.com/topic/525/voxl-adb-or-wi-fi-no-longer-communicating
              A 1 Reply Last reply
              • Chad SweetC Chad Sweet
                ashwin-umdlife
                @Chad-Sweet I think we are all commenting on the wrong post here. The issue of this post was solved by connecting to the appropriate usb cable.
                However, @Roman-Rempel I guess you are having similar problem as in this post https://forum.modalai.com/topic/520/voxl-stuck-in-waiting-after-unbricking/3 ?
