  3. Turtle mode compatibility with non Modalai ESC
17 Posts 4 Posters 1.7k Views 3 Watching
  • Jetson NanoJ Jetson Nano
    @Alex-Kushleyev Thank you for the support.
    Also I noticed only the VOXL-FPV-DEV version only have the voxl_esc_t_on option to control the esc through the joystick, The main version of modalai PX4 fork do not have them, is it under development.
    The FPV-dev version do not support collision prevention, so i had to roll up to the main version, which gave me this issue.
    @Jetson-Nano This is a feature that was designed specifically for our FPV drones so that is the only branch that has it supported.
      Jetson NanoJ Offline
      Jetson Nano
      Veteran
      #9
      @Eric-Katzfey Thank you for reverting back, why does collision prevention not working with this px4 version.
      The obstacle_distance topic is not showing in any mpc_pos_mod
        Jetson Nano
        Veteran
        @Eric-Katzfey hey, if I would like to implement the same in the main px4 fork (modalai) what all would i have to change.
          Jetson Nano
          Veteran
          @Eric-Katzfey Hey, could you please help me with this issue?
            @Jetson-Nano This is where the logic for turtle mode can be found in the voxl-esc driver: https://github.com/modalai/px4-firmware/blob/voxl-dev/src/drivers/actuators/voxl_esc/voxl_esc.cpp#L330
            You'd have to modify px4 to pull this logic into the driver you're using
              Jetson Nano
              Veteran
              @tom I am using the Modalai Main fork of PX4 which already have the turtle mode, I just want the turtle mode to be enabled through joystick.
                @Jetson-Nano It's hard to follow what you are asking. Are you trying to add turtle mode to another ESC driver? Are you trying to get turtle mode working with a joystick and VOXL ESC?
                  Jetson Nano
                  Veteran
                  I am sorry for the confusion , I started the thread for another ESC, that is cleared.
                  Now I am asking with respect to modal ai FPV ESC.
                  The issue I am facing now is, the VOXL-FPV-DEV fork of px4 has turtle mode for joystick and button.
                  The Main fork of the PX4 do not carry this feature.
                  I would like to incorporate this feature in the Main fork.
                  The reason I switched from fpv-dev to main, was collision prevention error. The VOXL-FPV-DEV do not have collision prevention working properly.
                  I hope my questions are clear now.
                    @Jetson-Nano Okay, well we don't support that right now. If you want to make your own build then you can probably just replace all of the files in the src/drivers/actuators/voxl_esc with the files from the voxl-fpv-dev branch.
                      Jetson Nano
                      Veteran
                      Thank you for reverting back. I am trying to proceed with the same approach.
                      I am facing some errors while going with this approach , I am trying to debug them.
                      Another approach :-
                      I am also thinking to hardcode the joystick based turtle mode to the voxl_esc.cpp.
                      The manual control values will be monitored and once the value of the assigned button is clicked, the turtle mode will be enabled.
                      Do you think it is a good approach?
