  2. VOXL SDK and Software
  3. Python MPA image
Python MPA image
mpa
9 Posts 2 Posters 4.5k Views 1 Watching
  • L Offline
    L Offline
    l05
    Re: Python MPA image example
    Hi, I am working on getting frames from the camera on the VOXL2 in python. I have looked at the python example at https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/blob/pympa-experimental/tools/python/rtsp_rx.py since I do not need to publish the frames. I cannot seem to install opencv properly, so it has GStreamer support. I have python 3.6 and GStreamer on the drone, has anyone been able to install opencv with GStreamer support for the VOXL2?
    • L l05
      @l05 , please see the following post, you can download the voxl-opencv library with python3 bindings from here .
      https://forum.modalai.com/topic/3519/help-with-pip-installing-opencv
      This version of opencv was used for testing the pympa-experimental tools.
      The script you were looking at is setup to receive image frames from an rtsp stream - is that what your goal is? (as opposed to receiving images from a mipi camera connected to VOXL2 (via voxl-camera-server)).
      L 1 Reply Last reply
        L Offline
        L Offline
        l05
        @Alex-Kushleyev My end goal is to receive images via voxl-camera-server, any tips or other examples on how to start to do so?
        I've taken a look at voxl-tflite-server but still having some trouble understanding how/where the service connects to one of voxl-camera-server's pipe to receive images.
        • L l05
          @l05 , can you please clarify the following: do you need to receive images from camera server in a python script or a C/C++ application?
          The recommended way is to use a C/C++ application, for which we can provide some examples. Python extension via Pympa makes it easier to quickly test / prototype something, but may have additional overhead to receive / convert images.
          For example, there is a tool voxl-inspect-cam-ascii, which is installed by default with the VOXL2 SDK, which subscribes to an image and renders the image to your terminal using ASCII. It uses opencv to downscale the image. You can find the source code here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/blob/master/tools/voxl-inspect-cam-ascii.cpp . this app also shows how to publish an image (it optionally publishes the down-scaled image as well).
          You can test this app by running voxl-inspect-cam-ascii <camera_stream> in a terminal, and you should see an ASCII version of your image. The name of the camera stream you can get from voxl-portal (camera tab), for example it would be something like tracking or hires_front_color, depending on the cameras / streams that you have enabled.
          If you wanted to develop your own application, you can start by first building the voxl-mpa-tools package from source and then add your own application into the existing build structure.
          L 2 Replies Last reply
            L Offline
            L Offline
            l05
            @Alex-Kushleyev Sorry for the confusion. I initially wanted to receive images using a Python script for prototyping, but now I plan to develop a C/C++ background service to receive images from camera server. Thank you for your advice, I will start by adding my own application into the existing build structure of voxl-mpa-tools.
              L Offline
              L Offline
              l05
              @Alex-Kushleyev I've downloaded the source code as a zip file and added my application. Trying to build the package and get an error when running make_package.sh. The error is:
              "dpkg-deb: error: maintainer script 'postinst' has bad permissions 644 (must be >=0555 and <=0755)"
              Tried to build both the source and the edited source with my application and get the same error. Do you know what could be causing this?
              • L l05
                @l05 can you try running the ./make_package.sh script inside docker? also if you are just trying to deploy your app, you can copy it directly from voxl-mpa-tools/build64/tools, to voxl2 using adb or ssh (assuming the build itself succeeded).
                  L Offline
                  L Offline
                  l05
                  @Alex-Kushleyev Sorry I am a little confused now, I thought to deploy an updated version of voxl-mpa-tools with my custom app I had to cross-compile before using adb to push to the voxl2. In general, if I were to add custom code to any voxl source code project, how do I make sure my new code is being ran and not the old code? What are you referring to above?
                  • L l05
                    #9
                    @l05 , when in doubt, you can add a print statement in your app as a sanity check to make sure you are running the correct version of the application. Then check your print statement at run time.
                    If you are modifying an existing app in voxl-mpa-tools, you just need to use the voxl-cross docker image to
                    • build the source code
                    • build the package (deb)
                    • deploy the package (either manually pushing and dpkg -i <package.deb> on target) or using a convenience script deploy_to_voxl.sh which is typically present in most voxl projects -- this script will push the deb to voxl2 and install the deb.
                    • run your new application on voxl and confirm functionality
                    If you are adding a new app to voxl-mpa-tools project, you will need to modify the CMakeLists.txt file in the tools folder, it should be self explanatory how to add a simple app. Once you build and deploy, your new app will be installed into /usr/bin on voxl2.
                    If you have any other questions, let me know.
