  2. Software Development
  3. Modal Pipe Architecture (MPA)
  4. Python MPA image example
Scheduled Pinned Locked Moved Modal Pipe Architecture (MPA)
8 Posts 3 Posters 5.0k Views 1 Watching
  • D Offline
    D Offline
    david.moro
    Hi, I am working on the integration of a camera on the VOXL2. The camera acts as a USB CDC device and outputs an 8-bit greyscale image on ttyACM0. The manufacturer provides a python example to talk to the camera. I was able to deploy it on the voxl2 and read the images. Now I would like to push those to a pipeline for consumption by voxl-streamer and other processes. Do you have any sample code or guidance on how to do this on python? I would like to have a functional prototype of the whole thing before porting it to C++.
    • D david.moro
      Alex KushleyevA Online
      @david-moro , here is a complete example that receives rtsp stream and publishes images via MPA:
      Link Preview Image
      tools/python/rtsp_rx_mpa_pub.py · pympa-experimental · voxl / VOXL SDK / Utilities / voxl-mpa-tools · GitLab
      Tools and utilities specific to MPA.
      favicon
      GitLab (gitlab.com)
      You need to build voxl-mpa-tools package from this branch and install it on VOXL2. The python scripts will get installed to /usr/share/modalai/voxl-mpa-tools/, you will need at least pympa.py which provides wrappers for python bindings for the mpa functions. libpympa.so will be installed to /usr/lib which contains the C side of the bindings.
      Since you don't need opencv, you can just extract the mpa publishing part from the example and add it to your python camera code.
      • D Offline
        D Offline
        david.moro
        Awesome! Will give it a try. Thanks @Alex-Kushleyev !
        D 1 Reply Last reply
        • D david.moro
          D Offline
          D Offline
          david.moro
          @Alex-Kushleyev , it worked. Thanks!
          • D david.moro
            @david-moro , awesome! thanks for confirming.
            Meytal LempelM 1 Reply Last reply
              Meytal LempelM Offline
              Meytal Lempel
              @Alex-Kushleyev Hi!
              My team and I are working with both voxl1 and voxl2 based platforms. We used your example and changed it to publish a ros topic (Image) to pipe on voxl2. It works great. Now we try to do the same on voxl1 (compiling the same code to ipk) and encounter the problem:
                File "ros_img_mpa_pub.py", line 19, in <module>
                  from pympa import *
                File "/usr/share/modalai/voxl-mpa-tools/pympa.py", line 23, in <module>
                  pympa = ct.CDLL("libpympa.so")
                File "/usr/lib/python3.6/ctypes/__init__.py", line 348, in __init__
                  self._handle = _dlopen(self._name, mode)
              OSError: libpympa.so: wrong ELF class: ELFCLASS64
              Is there any other branch that may be suitable for voxl1 to our purpose?
              Thank you, Meytal
              • Meytal LempelM Meytal Lempel
                @Alex-Kushleyev Hi!
                    from pympa import *
                Thank you, Meytal
                Hi @Meytal-Lempel ,
                There was an issue causing a 64 bit library to be installed into /usr/lib on VOXL1. 32 bit library was never built. I fixed the issue on the pympa branch : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/commit/4e9f35ee26217e490c28cf559f4c4b33e0bacd59
                Native python3 on VOXL1 is 32 bit.
                After building and installing the ipk on voxl1, you can check the library for 32 bit:
                readelf -a /usr/lib/libpympa.so | more
                ELF Header:
                  Magic:   7f 45 4c 46 01 01 01 00 00 00 00 00 00 00 00 00
                  Class:                             ELF32
                  Data:                              2's complement, little endian
                The 64-bit libpympa.so library will now go to /usr/lib64, as it should on VOXL1
                I hope this helps!
                  Hi @Meytal-Lempel ,
                  ELF Header:
                    Class:                             ELF32
                  I hope this helps!
                  Meytal Lempel
                  @Alex-Kushleyev Thank you, it works!
