  3. Mavlink messages through voxl-logging
7 Posts 4 Posters 839 Views 2 Watching
  • N Offline
    N Offline
    ndwe
    I'm trying to log mavlink messages though voxl-logger but all of the mavlink message pipes contain only i, timestamp.
    I have been able to log imu and tracking camera data but not the mavlink messages. Any ideas?
    Note: still on sdk1.3
    $ voxl-version
    system-image: 1.7.10-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Fri Sep 27 21:59:02 UTC 2024 4.19.125
    hw platform:  M0054
    mach.var:     1.0.1
    voxl-suite:   1.3.5
    voxl2:/home/starling2voxl-logger -m mavlink_attitude -t 3
    starting 3.0 second timer
    connected to ch 0 mavlink: /run/mpa/mavlink_attitude/
    stopping automatically after requested timeout
    summary of data logged:
    ch 0, type: mav, samples:      88, path: /run/mpa/mavlink_attitude/
    created new log here:
    /data/voxl-logger/log0013/
    voxl2:/home/starling2$ cat /data/voxl-logger/log0013/run/mpa/mavlink_attitude/data.csv
    i,timestamp(ns)
    0,20016407463491
    1,20016507691080
    mavlink_message_t
    	mavlink_ap_heartbeat
    	mavlink_attitude
    	mavlink_from_gcs
    	mavlink_gps_raw_int
    	mavlink_local_position_ned
    	mavlink_onboard
    	mavlink_sys_status
    	mavlink_to_gcs
    $ voxl-mavlink-server -j
    loading our own config file
    primary_static_gcs_ip:
    secondary_static_gcs_ip:      192.168.41.42
    onboard_port_to_autopilot:    14556
    onboard_port_from_autopilot:  14557
    gcs_port_to_autopilot:        14558
    gcs_port_from_autopilot:      14559
    en_external_uart_ap:          0
    autopilot_uart_bus:           1
    autopilot_uart_baudrate:      921600
    autopilot_mission_delay_start:      -1
    udp_mtu:                      0
    gcs_timeout_s                 4.50
    en_external_ap_timesync:      1
    en_external_ap_heartbeat:     1
    existing instance of voxl-mavlink-server found, attempting to stop it
    starting receive thread for onboard channel from autopilot
    starting receive thread for gcs channel from autopilot
    CONNECTED to autopilot on onboard channel
    CONNECTED to autopilot on gcs channel
    Not connecting to primary gcs ip:
    Adding secondary manual gcs IP address to udp connection list: 192.168.41.42
    Added new UDP connection to 192.168.41.42
    to ob pipe  ID: 141  compid:   1
    to ob pipe  ID:  32  compid:   1
    to ob pipe  ID: 290  compid:   1
    to ob pipe  ID: 291  compid:   1
    to ob pipe  ID:  30  compid:   1
    to ob pipe  ID: 331  compid:   1
    to ob pipe  ID:  83  compid:   1
    to gcs pipe ID:  31  compid:   1
    to ob pipe  ID:  29  compid:   1
    to ob pipe  ID:  65  compid:   1
    to ob pipe  ID:  36  compid:   1
    to ob pipe  ID:  74  compid:   1
    to ob pipe  ID: 105  compid:   1
    • N ndwe
      $ voxl-version
      hw platform:  M0054
      mach.var:     1.0.1
      voxl-suite:   1.3.5
      i,timestamp(ns)
      0,20016407463491
      1,20016507691080
      mavlink_message_t
      	mavlink_attitude
      	mavlink_from_gcs
      	mavlink_gps_raw_int
      	mavlink_onboard
      	mavlink_sys_status
      	mavlink_to_gcs
      udp_mtu:                      0
      gcs_timeout_s                 4.50
      Eric KatzfeyE Online
      @ndwe said in Mavlink messages through voxl-logging:
      Was there no raw data file in that directory? You can get verbose debug printouts in voxl-logger with the -z option to see what it is logging.
      • N Offline
        N Offline
        ndwe
        voxl-replay -p /data/voxl-logger/log0014/ -z
        voxl-replay: invalid option -- 'z'
        Replay a log
        -d, --debug enable verbose debug mode
        -h, --help print this help message
        -n, --number {number} number of log to open, e.g. 32
        -p, --path {path} complete path of log to open, e.g. /data/mylog/
        -s, --start {seconds} starts the replay (float) seconds into the log
        -f, --finish {seconds} ends the replay (float) seconds into the log
        -i, --include {name} name of pipe to publish, publish all if not specified
        -e, --exclude {name} name of pipe to not publish, publish all if not specified
        -y, --auto_kill automatically kills servers that conflict with the log
        When I use the -d flag
        voxl2:/data/voxl-logger/log0013$ voxl-replay -p /data/voxl-logger/log0013/ -d
        enabling debug mode
        opening json info file: /data/voxl-logger/log0013/info.json
        using log_format_version=1
        log contains 1 channels
        log started at 20016320271533ns
        log publish channel 0:
        type: mav
        out path: /run/mpa/mavlink_attitude/
        log path: /data/voxl-logger/log0013//run/mpa/mavlink_attitude/
        total samples: 88
        opening csv file: /data/voxl-logger/log0013//run/mpa/mavlink_attitude/data.csv
        opening raw file: /data/voxl-logger/log0013//run/mpa/mavlink_attitude/data.raw
        creating pipe: /run/mpa/mavlink_attitude/
        finding start frame for channel 0
        header for channel 0 /run/mpa/mavlink_attitude/
        i,timestamp(ns)
        log started at 20016320271533ns, shifting to 20016407463491ns
        replay start time ns: 1498719153614entering main loop
        starting to publish mavlink to: /run/mpa/mavlink_attitude/
        publishing to ch0 at 1498819501us a mavlink packet with timestamp 1498819381us
        publishing to ch0 at 1498819646us a mavlink packet with timestamp 1498819397us
        publishing to ch0 at 1498819671us a mavlink packet with timestamp 1498819400us
        • N ndwe
          Replay a log
          enabling debug mode
          type: mav
          total samples: 88
          i,timestamp(ns)
          @ndwe -z in the voxl-logger command, not the voxl-replay command. But looks like voxl-replay sees the data and there is a raw data file for it to parse. Are you still having an issue?
          R 1 Reply Last reply
          • N Offline
            N Offline
            ndwe
            wrote on last edited by ndwe
            Ok thanks, I can parse the raw data. I guess I was expecting the csv to contain the data as well
              R Offline
              R Offline
              rnunna
              wrote on last edited by rnunna
              @Eric-Katzfey said in Mavlink messages through voxl-logging:
              @Eric-Katzfey is there any way to view the mavlink messages in plaintext (not raw)? We want to plot the data on LOCAL_POSITION_NED and MAVLINK_ATTITUDE hence our need for the data in CSV.
              • Zachary Lowell 0Z Offline
                Zachary Lowell 0
                @rnunna at this point I would recommend either creating a python or cpp script that leverages mavsdk to probe the logs and get it into the format you are desiring.
                Zach
