MAVLink custom port to GCS
I'm trying to send telemetry data from multiple VOXL 2 drones to a single GCS IP.
Is there a way to set a custom UDP port for
secondary_static_gcs_ip(other than 14550) on each individual VOXL 2 drone so I can guarantee which drone is connecting? Essentially something like:- drone 1 (MAV_SYS_ID = 1):
drone.connect(system_address="udp://:14551") - drone 2 (MAV_SYS_ID = 2):
drone.connect(system_address="udp://:14552") - drone 3 (MAV_SYS_ID = 3):
drone.connect(system_address="udp://:14553") - etc.
I'm able to view multiple unique drones in QGroundControl, uniquely identified by setting a unique
MAV_SYS_IDon each drone first. However, I'm trying to connect using mavsdk now instead, but I haven't had any luck using the sysid arg, so it's always a random gamble on which drone actually connects when I try system address ofudp://:14550. - drone 1 (MAV_SYS_ID = 1):
MAV_SYS_IDon each drone first. However, I'm trying to connect using mavsdk now instead, but I haven't had any luck using the sysid arg, so it's always a random gamble on which drone actually connects when I try system address ofudp://:14550.@dan64 That port number is hardcoded in voxl-mavlink-server. You can modify that source code and add a configurable GCS port number to do what you want. But QGroundControl typically only opens one port and listens for connections only on that one port. How are you making it open multiple different ports? https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mavlink-server/-/blob/master/src/gcs_io.c?ref_type=heads#L59
@Eric-Katzfey thanks for the quick reply. Since 14550 is hard-coded into voxl-mavlink-server service, that answers my question re: customizing this port.
For additional context, I'm interested in replicating QGC's behavior of connecting to multiple UAVs simultaneously, each identified by their MAV_SYS_ID. As an example:
- Set
MAV_SYS_IDto "42" on one VOXL - Leave
MAV_SYS_IDas "1" on another VOXL - Set
secondary_static_gcs_ipto your GCS IP on both (/etc/modalai/voxl-mavlink-server.conf) - QGC automatically connects to both and shows "Vehicle 42" and "Vehicle 1" in the dropdown in the top menu bar
I'm able to connect to my UAV using mavsdk at
udp://:14550but I can't tell which one connects since both are sending telemetry to my Mac's 14550.Since posting this, I discovered https://github.com/mavlink-router/mavlink-router which may be what I'm looking for, but I'm still trying to get it working with my docker-compose setup. I was just wondering if there was a simpler configuration onboard the VOXL that I could easily change.
- Set
- Set
@dan64 Unsure if you have resolved this issue, but I am going to add some more information to anyone that stumbles across this. There was a bug in the voxl-mavlink-server setting and sending all System ID numbers to 1. The deb file below should solve this issue where the MAV_SYS_ID can be changed an reflected on the VOXL2.
- Set
