    Flight Deck error after arm
    1241
    • Pavel ArdashovP
      Pavel Ardashov
      After launching Flight Deck, the odometry section displays coordinates and altitude correctly.
      After ARM, the altitude and coordinates start to change, although the drone stays in place. After a few seconds, the service stops.
      What could be the reason?
      Link video:
      https://drive.google.com/file/d/1F8AQSUKgaRQQLYBb7HapdTN5cBDFk7Hk/view?usp=sharing
      • Pavel ArdashovP
        Pavel Ardashov
        During the crash voxl-inspect-qvio send
        error_code BAD_CAM_CAL
        • modaltbM
          modaltb ModalAI Team
          Hi @Pavel-Ardashov ,
          Can you please describe your setup? Is the flight deck attached to a custom vehicle? How is it mounted?
          I watched the video and saw the data rising. I couldn't tell, are the props actually moving? Or is the vehicle totally static?
          Pavel ArdashovP 1 Reply Last reply Reply Quote 0
          • Pavel ArdashovP
            Pavel Ardashov @modaltb
            Hi @modaltb
            Flight deck attached to a custom drone.
            After ARM, the propellers were spinning, but the drone remained in place, as you can see in the video. The video from the Hires camera is displayed on the monitorизображение_viber_2021-10-21_08-34-00-588.jpg .
            • Pavel ArdashovP
              Pavel Ardashov
              Thank you, the issue was resolved on my own.
              An additional box helped to close the barometer. After installing it, there is no problem with height data.
              • modaltbM
                Thank you for the information, did you FlightDeck not have a barometer cap included? We should have shipped it with a little 3D printed cap.
                • modaltbM
                  • Pavel ArdashovP
                    @modaltb my FlightDeck have a barometer 3D printed cap.
                    But it was not tight, there was a groove in it. Maybe it was planned?
                    By completely closing the barometer, we fixed the problem.
