  2. VOXL Compute & Autopilot
  3. VOXL 2 Mini
  4. Voxl 2 Mini not detected via USB
Scheduled Pinned Locked Moved VOXL 2 Mini
10 Posts 2 Posters 1.7k Views 1 Watching
  • S Offline
    S Offline
    Sarika Sharma
    wrote on last edited by Sarika Sharma
    Hi ModalAI Team,
    I'm working on a VOXL2 Mini (M0104) and facing persistent USB connection issues.
    🖥️ Environment:
    Host OS: Ubuntu 22.04 (also tested on Windows 10)
    Cable: Known-good USB-C data cable
    Power: Board powered via ESC; LED turns on
    ❌ Issue:
    Ubuntu: lsusb shows nothing in any mode (ADB, Fastboot, or EDL)
    Windows: Device Manager shows Unknown USB Device (Device Descriptor Request Failed) with a yellow triangle
    I also tried to run flash-system-image.sh (see the attached screenshots)fails with “device not found” in fastboot mode
    ✅ Tried:
    Different cables and USB ports (USB 2.0 & 3.0)
    Different PCs (Windows and Linux)
    Turned on EDL switch
    Force Fastboot
    📌 Request:
    Looking for guidance.
    • S Sarika Sharma
      Hi ModalAI Team,
      🖥️ Environment:
      ❌ Issue:
      ✅ Tried:
      Force Fastboot
      📌 Request:
      @Sarika-Sharma If you're using a VM on windows in order to run Ubuntu you'll need to setup USB device pass-through from your host machine.
      I would recommend running linux natively if possible
      S 1 Reply Last reply
        S Offline
        S Offline
        Sarika Sharma
        @tom I am running Ubuntu natively (not inside a VM). USB passthrough is not applicable in my case.
        • S Sarika Sharma
          @Sarika-Sharma With the device powered and plugged in via USB, what do you see with lsusb?
            S Offline
            S Offline
            Sarika Sharma
            • S Sarika Sharma
              @Sarika-Sharma Interesting, is there a different USB cable / port combo you can try? It may be worth trying with a USB-A to C cable as some C to C cables don't contain the proper data lines
                S Offline
                S Offline
                Sarika Sharma
                @tom Yes, I’ve already tried using a USB-A to USB-C cable and also I used the same cable to connect VOXL2 previously, and it works perfectly — I'm able to access the ADB shell without any issues, so the cable and USB port are both functional. However, when I try to connect the VOXL2 Mini using the same cable, I’m unable to see any device listed with adb devices on Ubuntu natively(I have a dual-boot setup).I’ve also checked lsusb on Ubuntu in both normal power-on and while attempting EDL mode, but no Qualcomm device shows up.
                When I switch to Windows, the VOXL2 Mini appears in Device Manager as "Unknown USB Device (Device Descriptor Request Failed)" with a yellow warning icon (screenshot attached).
                • S Sarika Sharma
                  @Sarika-Sharma Interesting, what kind of battery are you using? What is the voltage?
                    S Offline
                    S Offline
                    Sarika Sharma
                    @tom I'm using a LiPo 3S battery with a voltage of 12V.
                    • S Sarika Sharma
                      @Sarika-Sharma Okay that should be fine, was just double checking the voltage wasn't too high for that ESC.
                      I'd recommend submitting an RMA: https://www.modalai.com/pages/rma
