  3. mavlink peripherals
mavlink peripherals
5 Posts 2 Posters 806 Views 1 Watching
  • h3roboticsH Offline
    h3roboticsH Offline
    h3robotics
    Re: External MAVLink Connection using VOXL 2 through ttyHS1
    I am in need of integrating a mavlink gimbal and a parachute with the voxl2 autopilot. Mavlink is becoming a common protocol to communicate with a number of external peripherals like gimbal, parachute, engines etc. As such, there is a growing need to have voxl-mavlink-server be able to start a bi-directional mavlink stream on app UARTs like that on the USB3/UART Add on board (/dev/ttyHS1).
    Is this something on the roadmap? Or any work arounds at the moment?
    Thanks.
    • h3roboticsH h3robotics
      Thanks.
      @h3robotics This is the first request we've had for such a feature. It shouldn't be too hard to add that feature into voxl-mavlink-server. All of the fundamental pieces are there. It is open source and we accept PRs. If you would like to add that feature yourself and submit a PR for it that would be great!
      h3roboticsH 1 Reply Last reply
        h3roboticsH Offline
        h3roboticsH Offline
        h3robotics
        @Eric-Katzfey I would love to contribute!
        I tried setting up voxl-cross. The pre-build version of voxl-cross is v2.7 on the downloads page. But I see that the voxl-cross in the repository has reached even v4. So I wanted to build voxl-cross myself. Unfortunately, the instructions say to download these files from the modalai downloads:
        ubun1.0_1.8.04-M0054-14.1a-perf-20250421-rootfs.tar.tar
        ubun2.0_2.0.0-perf-20250421-rootfs.tar.tar
        And I can't seem to find these files. Without that, I am unable to compile. Any suggestions on how to compile the latest voxl-cross? Or should I just use v2.7?
        Thanks.
          Thanks.
          @h3robotics I'd just try with v2.7
            Thanks.
            @h3robotics I've been using v2.5 on my development machine and it works fine so v2.7 should also be fine. (Dang, I need to update 😉 )
